Okuma Mill Macro help
Mr.ZX
I have an Okuma mill with a OSP control. I need a macro that I can use for tool length measurement. Are there any Okuma Macro Gurus out there that can help? I can program macros on Fanuc and Hass all day long, but do not have time to learn the "Okuma" way right now.
Let me know
No tool presetter, I am going to make a preset post that will use an indicating type of presetter. I want to be able to type a command, have the tool put into the spindle, and go to the preset point. Also it must set G15H0. I wrote a couple of them for Fanucs and Hass, but the Okuma language is different.
Control type OSP-U100M
oh ok
are you going to use G15 H0 as your position for the presetter.
I would probably use VC1 and VC2
you could say in the macro
N01
IF [VC1 LE VC2] GOTO N10
GOTO NEND
N10
IF [VATOL EQ VC1] N20
T=VC1 M6
N20G00 X0. Y0. G15 H0
M0(measure tool use mid auto manual)
G00 Z20.0
VC1=VC1+1
GOTO N01
NEND M30
its been awhile and I dont have my manual here with me but that should get you close.
so you would set VC1 to your starting tool number and VC2 to your ending tool number
then it will run the loop till it reaches there.
you could assign this macro to an MCODE then fire it from MDI also.
yes, you can even do it with slide hold.
(caution you must get the tool close to wear you left off or it will cut right through your part!)
you just hit slide hold or M0 press mid auto manual
run your table around
put it back roughly where you left it
press mid auto off
Do Not hit cycle start
push sequence restart I am going off an old memory but it is something like that smile.gif
hey if the power goes out you know you can restart your Okuma exactly where you left off?
pretty handy for a huge stitching job
Here ya go
OTOOL (PROGRAM NAME)
(************TO CALL**********)
(G111 MEASURES THE TOOL IN THE SPINDLE)
(G111 T1 [sELECTS THE TOOL AND MEASURES IT])
(NOTE: THE TIP OF THE CUTTER MUST BE IN LINE WITH THE KEY)
(AND THE CUTTER RADIUS MUST BE SET)
(SET CUTTER RADIUS FOR BORING BAR TOOLS ALSO)
(TIPPED TOOLS CAN BE MESURED WITH G111 PA=??)
(G15 H20)
IF [PA NE EMPTY] N1
PA=0
N1
IF [PT EQ EMPTY] N4 (IF T IS NOT SET GOTO LINE 4)
IF [VTLCN EQ PT] N4 (IF T=TOOL IN THE SPINDLE GOTO LINE 4)
IF [VNTOL EQ PT] N3 (IF T=NEXT TOOL GOTO LINE 3)
IF [VNTOL EQ 0 ] N2 (IF NEXT TOOL IS VACANT GOTO LINE 2)
M64 (CANCEL PRE-SELECT TOOL)
N2
T=PT (PRE-SELECT COMMANDED TOOL)
N3
M06 (TOOL-CHANGE)
N4
CALL OO30 PX=[VTOFD[VTLCN]] VFST=#81H PRS=PA
(TOOL GAUGE CYCLE)
RTS (END)
