Number of decimal places
maestro
Hi, I don't have experience with the Hurco post, but below is how I would change the mpfan.pst from 4 to 3 dec places. The 'Format statements' list show the numbers and what they stand for. The lines changed are noted by: <<<<<<.
Example - 11 was 2 and 14 was 3.
BE SURE TO BACK UP YOUR POST FIRST!!
Hope this helps- BerTau
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
# -------------------------------------------------Default english/metric position format statements
fs2_1__ 0.7 0.6 #Decimal, absolute, 7 place, default for initialize ( :)
fs2_ 2__ 0.4 0.3 #Decimal, absolute, 4/3 place
fs2_ 3__ 0.4 0.3d #Decimal, delta, 4/3 place
#Common format statements
fs2_ 4__ 1 0 1 0 #Integer, not leading
fs2_ 5__ 2 0 2 0l #Integer, force two leading
fs2_ 6__ 3 0 3 0l #Integer, force three leading
fs2_7__ 4 0 4 0l #Integer, force four leading
fs2_ 9__ 0.1 0.1 #Decimal, absolute, 1 place
fs2_ 10__ 0.2 0.2 #Decimal, absolute, 2 place
fs2_ 11__ 0.3 0.3 #Decimal, absolute, 3 place
fs2_ 12__ 0.4 0.4 #Decimal, absolute, 4 place
fs2_ 13__ 0.5 0.5 #Decimal, absolute, 5 place
fs2_ 14__ 0.3 0.3d #Decimal, delta, 3 place
fs2_ 15__ 0.2 0.1 #Decimal, absolute, 2/1 place
fs2_ 16__ 1 0 1 0n #Integer, forced output
_______BEFORE_________
# -------------------------------------------------# Toolchange / NC output Variable Formats
# -------------------------------------------------fmt T 4 t #Tool No
fmt T 4 first_tool #First Tool Used
fmt T 4 next_tool #Next Tool Used
fmt D 4 tloffno #Diameter Offset No
fmt H 4 tlngno #Length Offset No
fmt G 4 g_wcs #WCS G address
fmt P 4 p_wcs #WCS P address
fmt S 4 speed #Spindle Speed
fmt M 4 gear #Gear range
fmt_ N_ 4_ n __ #Sequence number
fmt_ X_ 2_ xabs __ #X position output
fmt_ Y_ 2_ yabs __ #Y position output
fmt_ Z_ 2_ zabs __ #Z position output
fmt_ X_ 3_ xinc __ #X position output
fmt_ Y_ 3_ yinc __ #Y position output
fmt_ Z_ 3_ zinc __ #Z position output
fmt_ A_ 11_cabs __ #C axis position
fmt_ A_ 14_ cinc __ #C axis position
fmt_ A_ 4 _ indx_out__ #Index position
fmt_ R_ 14_ rt_cinc__ #C axis position, G68
fmt_ I_ 3 _ i __ #Arc center description in X
fmt_ J_ 3 _ j __ #Arc center description in Y
fmt_ K_ 3 _ k __ #Arc center description in Z
fmt_ R_ 2 _ arcrad __ #Arc Radius
fmt_ F_ 15_ feed __ #Feedrate
fmt_ P_ 11_ dwell __ #Dwell
fmt_ M_ 5 _ cantext __ #Canned text
_________AFTER____________________
fmt T 4 t #Tool No
fmt_ N_ 4_ n _ #Sequence number
fmt_ X_ 11_ xabs _ #X position output <<<<<<
fmt_ Y_ 11_ yabs _ #Y position output <<<<<<
fmt_ Z_ 11_ zabs _ #Z position output <<<<<<
fmt_X _14 _ xinc _ #X position output <<<<<<
fmt_Y _14_ yinc _ #Y position output <<<<<<
fmt_Z _14_ zinc _ #Z position output <<<<<<
fmt_ A_ 11_ cabs _ #C axis position
fmt_ A_ 14_ cinc _ #C axis position
fmt_ A_ 4 _ indx_out _ #Index position
fmt_ R_ 14_ rt_cinc _ #C axis position, G68
fmt_ I_ 14_ i _ #Arc center description in X <<<
fmt_ J_ 14_ j _ #Arc center description in Y <<<
fmt_ K_ 14_ k _ #Arc center description in Z <<<
fmt_ R_ 11_ arcrad _ #Arc Radius <<<<<<
fmt_ F_ 15_ feed _ #Feedrate
fmt_ P_ 11_ dwell _ #Dwell
fmt_ M_ 5 _ cantext _ #Canned text
I had to add a bunch of 'underscores' to keep the lines from running together. Hope it's clear.
[ 04-27-2002, 08:11 PM: Message edited by: BerTau ]
