3-d Broach in 3 axis mill
Hi,
This is a little over my head.
I have a difficult electrode to make and decided that the best way to proceed would be to scrape the detail into my electrode with a custom broach.
This broaching motion does not go straight inline with the z axis. I have lines in the .z2g file that show the actual required motion. The broaching would take place at 8 locations around the electrode (45 deg spacing).
My goal is to program this with "multi-passes" and to be able to use comp to adjust the exact size of the cut.
Hopefully the file is pretty self-explanatory. It shows the electrode, the broach tool, and the desired tool motion (orange lines).
I have trouble with the ftp site so I uploaded it to my "box.net" account.
The file is a .z2g and for those that don't know it can be opened by unzipping with winzip or any other compression utility.
download my file here
MAtt,
May I suggest you wire your electrode lying on its side. I do realize it's on an angle.
So you could wire it with it angled @ 5 degrees or straight . If straight the steel will be on a 5 deg. angle when it is burned.
Make it a single sided trode on it's top edge only or you can wire the shape with one wired contour on ea. side for a 2 sided electrode. Shoot for a .002 to .0025 spark gap.
You could side burn the steel or use a right angle head on the edm machine.
EDIT:
Just reread your post Matt. 50 or 60 of these?
Ok my suggestion would be too time consuming.
Matt,
You could get wear by using the actual geometry instead of offsetting it out like I did, chain the one, set finish multi-passes, turn your lead in/lead out off and add 1/2 the diameter of your tool into the XY stock on box.
See if that gives you what you need.
