fanuc wire subprogram post
fuzzy71e
I want to post out my burn call settings in a seperate subprogram. Anyone have any luck doing this? I have three Fanuc Robocut wires and am trying to do this with X2 software. Want code to look like this:
O1234
N5M31
N10G90G00X-1.875Y2.25
N15G92X-1.875Y2.25
N20G90
N25M98P1235 (.1250 DIA.)
N30M50
N35G90G00X-1.875Y1.25
N40G92X-1.875Y1.25
N45G90
N50M60
N55M98P1235 (.1250 DIA.)
N60M50
N65M45
N70M30
O1235
M37
D1S1
M98P1236
M38
D2S2
M98P1236
D3S3
M98P1236
D4S4
M98P1236
M29
M99
O1236
N75G91
N80G01G41X.0625Y0.0
N85G3I-.0625J0.0
N90G1G40X-.0625Y0.0
N95G90
M99
fuzzy71z,
i have 3 fanuc wires also but i don't use subs.ijust window contour all of the geometry using the color mask and write the entire program.the reason i do that is because i don't want to have to figure out what main program goes with what sub.
another way to do multiple geometrys that are identical is at the end of the first one,put a rapid move to your next wire position at the end of of your program before the m30. then insert a g74 p1.this will reset your measure pt. and all you have to do is hit cycle start.put a m01 on the line after the rapid move and turn that on in your machine when you get to your last geometry so that it will stop and not rapid tothe next point.
EXAMPLE OF A 1.00 DIA HOLE SPACED 1.0 APART
O1500
( 1.00 HOLE )
G0 G90
M31
G77 P1
M15 P0
G92 X0. Y0.
M60
M37
S1 D1
G41 G1 X.5
G3 X-.5 I-.5
X.5 I.5
M00
G40 G1 X0.
M38
S2 D2
G41 G1 X.5
G3 X-.5 I-.5
X.5 I.5
G40 G1 X0.
M38
S3 D3
G41 G1 X.5
G3 X-.5 I-.5
X.5 I.5
G40 G1 X0.
M38
S4 D4
G41 G1 X.5
G3 X-.5 I-.5
X.5 I.5
G40 G1 X0.
M50
M01 (TURN ON AT LAST HOLE)
G0 X1.0 Y0.(RAPIDS TO NEXT HOLE)
G74 P1(STORES MEASURE PT)
M29
Del,
I see how this works, pretty cool. My concern is would I have to repeat all the burn settings for each new location? If so, that becomes a problem for me because I often wire parts with over 300 holes. I have been doing this with V7.2 mill,for making the main or position program. Then adding the necessary subs. I would think x2 should be able to seperate the burn sets as well as the geometry into different subprograms. It does create the main position program and will put the hole or contour geometry into a sub but wants to repeat the burn sets for each hole or contour. This uses alot of unnecessary code, and if I needed to run the last skim cut for any reason block deleting the subprogram is very simple.
Fuzzy
here is how mine post out a sub program.
6 1.00 dia holes spaced 1.5apart
i window contour all holes,check use sub programs and all contours use same sub.
you will have to save the main as one program and the sub as another one to put into machine. does this work for you
01500
G0 G90
M31
G77 P1
M15 P0
G92 X0. Y0.
M60
M37
S1 D1
M98 P0001
M38
S2 D2
M98 P0001
M38
S3 D3
M98 P0001
M38
S4 D4
M98 P0001
M50
G0 X1.5 Y0.
G92
M60
M37
S1 D1
M98 P0001
M38
S2 D2
M98 P0001
M38
S3 D3
M98 P0001
M38
S4 D4
M98 P0001
M50
G0 X3. Y0.
G92
M60
M37
S1 D1
M98 P0001
M38
S2 D2
M98 P0001
M38
S3 D3
M98 P0001
M38
S4 D4
M98 P0001
M50
G0 X4.5 Y0.
G92
M60
M37
S1 D1
M98 P0001
M38
S2 D2
M98 P0001
M38
S3 D3
M98 P0001
M38
S4 D4
M98 P0001
M50
G0 X6. Y0.
G92
M60
M37
S1 D1
M98 P0001
M38
S2 D2
M98 P0001
M38
S3 D3
M98 P0001
M38
S4 D4
M98 P0001
M50
G0 X7.5 Y0.
G92
M60
M37
S1 D1
M98 P0001
M38
S2 D2
M98 P0001
M38
S3 D3
M98 P0001
M38
S4 D4
M98 P0001
M50
M29
O0001
G92 X0. Y0.
G90
G41 G1 X.5
G3 X-.5 I-.5
X.5 I.5
G40 G1 X0.
G90
M99
Del,
The code that I have posted is what I use in our Fanucs. The one you sent me would work but repeating the burn settings is what I would like to not have to do. Putting them into their own subprogam and then calling the geometry from there will reduce the amount of code greatly. Just like you have done by putting the hole geometry into a subprogram
Fuzzy
fuzzy, if you don't want all of the code then you can loop it like this.
you will have 2 main prgs. and 1 sub.
example of a 1.0 hole spaced 1.5 inches apart 6 times.
THE LOOP NUMBER REPRESENTS THE TOTAL NUMBER OF COPIIES INCLUDING THE ORIGINAL
THE SECOND MAIN CALLS THE SUB
01111 (MAIN PRG)
n1 g40 g50 g90
n2 g92 x0. y0.
n3 m31
n4 m98 p2222 L6
N5 M30
02222 (SECOND MAIN)
N6 M60
N7 M37
N8 G10 P9 B0 (READ BLOCK 27 )
N9 D1 S1
N10 M98 P3333
N11 M38
N12 G10 P9 B1 (SKIP BLOCK 27 )
N13 S2 D2
N14 M98 P3333
N15 D3 S3
N16 M98 P3333
N17 D4 S4
M98 P3333
N19 M29
N20 M50
N21 G0 X1.5 Y0.
N22 M99
(PART GEOMETRY) SUB PROGRAM
03333
N23 G92 X0. Y0.
N24 G1 G41 X.5
N25 X-.5 I-.5
N26 X.5 I.5
N27 /9 M00 (REMOVE SLUG)
N28 G0 G40 X0.
N29 M99
Del,
If you did post this from x2 then the loop call could be removed and more locations could be added to the main which would give me almost what I am looking for. Removing the "G92 X0 X0" line from the geometry subprogram I think would be it.
Let me know .
Fuzzy
fuzzy, the only way i know to do this is manually write the the two mains.
i usually just post all of the code no matter how long it is.
the thing i don't like about the loop is that it will rapid to a phantom position at the very end.i would put an m01 at that rapid move block and turn the m01 on in the machine at the last contour.
the loop has to be manually written. i would think your post could be modified to write only one set of
power settings and offsets when using subs, but that is over my head.i'm sure there are people here who could help you with that.
Del,
Thank you very much for your time with this problem. It looks like using x2 to do this will be a step backwards from how I have been doing it with v7 mill. I do like your loop program for doing holes that are the same distance from each other, and will give it a try.
Thanks Again
Fuzzy
your welcome,
like i said i am sure hat you can get your post to output it like you like with some post guru's.
as long as all of your geometry is the same you should be able to window contour all geometry,even is spacing is varied, create a main with only one set of offset calls and one set of power settings,and only one subprogram of your geometry. x2 will do that now,but it still writes multiple d1 s1 for each move.
