3d contour multi pass
Tim Pruett
I can't seem to get this to work. I'm turning an electrode in the mill and I usually use depth cuts, but in this case the trode is a hooker and if I use depth cuts it will turn off the hooker. How do I get the multi pass funtion to work. Or is there a better way to turn this trode in the mill?
Not sure what a trode is but try this:
Project the geometry you want above the part,
Do a 2d toolpath with that geometry and gost it out,
Do surface finish project, select NCI projection type, source operations select the 2d toolpath you just create.
edmbosto,
I tried that and it still wouldn't work.
Santa Fe,
If I use a surface project toolpath it won't mill the undercut for the hooker. I need to use a lollipop mill or something to that effect and we don't have enything like that.
Anyway, I figured out a differen't way of doing it. I had to create my toolpath from the front construction plane and then edit my nc file. I changed all of the "Y"s to "Z"s. Then I could use multi passes like I wanted. I just wondered why the multi pass function wouldn't work in a 3d contour toolpath. Thanks for the input though. It's nice to have all of you gurus to talk to whenever I want.
