X3 Rigid tap...
?Mark
Mark,
First thing make sure the use_pitch variable is set in the post
If it is and it's not working then you have to do 1 of two things, either code your post to calculate for metric taps or save your metric tap to the inch library and calculate the TPI.
I've done this to read it out of the metric library
pdrlcommonb
pbld, n$, "G95", e$
pbld, n$, "M29", *speed, e$
pitch = (feed / sav_ss)
#if met_tool, pitch = n_tap_thds #Tap pitch (mm per thread)
#else, pitch = 1/n_tap_thds #Tap pitch (inches per thread)
pcan1, pbld, n$, *sgdrlref, *sgdrill, pxout, pyout, pfzout,
prdrlout, *pitch, !feed, strcantext, e$
pcom_movea
I create the sav_ss variable and plug it in in the tool change section
sav_ss = speed
right undert he G43 line.
pbld, n$, "G43", ptlngno, pfzout, scoolant, e$
sav_ss = speed
if you use it don't forget to format the sav_ss vaibale
sav_ss   : 0
I added it to the drill variables section
Something has changed with the way mc is calculating/reading the numbers from the metric tool library.
It worked well for me before and I thought switching to fpr messed it up for me, but just now switched back to ipm and the output is still wrong.
John, thanks very much for the help. I'll play with the post when I have some breathing room here hopefully later today.
Regards, Mark
