Backplot Tool Not Right.
McRae
Ying,
As I wipe the dust and pick the gravel out of my body from falling off the turnip truck - wait... Of Coarse I had the "As Defined" switch set. The problem is that the tool has a taper side to it 12mm cut diameter and a 16mm shank over a 3" length (76mm if you need to stay in metric reading my post...) I need to check the side clearance of this taper against the part model.
This just in...
**Problem with Tool File
Redraw the tool MC9 to be a single chain starting at CL and finishing at CL and making it a function (Single Solution across the CL)
error writing tool path
bnci_section(): Cannot delete section
Now I have corrupted my file. - TGFB (Thank Goodness For Backups)
Looking for help...
[ 06-07-2002, 12:22 PM: Message edited by: MfgEng ]
As I wipe the dust and pick the gravel out of my body from falling off the turnip truck - wait.......
ROFLMAO
That was hilarious!!!!!!
Andrew,
Just got back from some service calls, I don't look at the Forum everyday, sorry for the late reply.
I've tried your file, and it works just fine. I did some screen shots of the backplot and posted on IHS ftp site at where you put last time. (It's called Tool_No_Prob.zip).
All I did was copy your tool file (BULLMILL_12MM_7MM.MC9) to Mcam9MillTools, and in "Operations Manager", under "Define tool" --> "Profile", I selected "Custom file" instead of "Auto". Also used the backplot display settings as I mentioned in the last message.
Your custom tool showed up in backplot without any problem!
