Tool in Spindle Macro Variable
Grumpy Guy
then I believe I need to have the line #149=#4120 in the tool change macro (our posted code stages a tool immediately after the tool change line M6T#)
which I already thought of. unfortunately I cannot access the tool change macro on this particular old machine. I believe its hard coded onto a flash card or some such thing. or am I missing something?
I added the same line to my tool change macro, I used #500 instead of a 100 number. The value is retained at power off and reset, not always the case with the 100 number range.
The macro I wrote will retract, and also has other tidbits to measure and set tool lenghts, go to a specific area to measure on specific pallets, or just do a retrack routine. It works great for opperators who do not understand G code.
no its a modal information variable
you could use it to check that the right h code was called or is currently active if you want to change it you need to pass it to a local or common variable
T2 example
#100=#4111 (#100 = 2)pass it to the common table
IF[#4111NE2]GOTO100 (check T2 H code number)
prog
N100#3000=101 (Wrong H offset)
if you want to check tool offset values depends on what offset memory you have for memory type c tool 1 (geometry offset) starts at #2201 cool.gif
