Dynamic Fixture Offset
X-L Engineering Corp
This is my first time using this so thats why I need help.
I'm showing you a portion of my program to see if I'm doing it right.
I have this in a Mori Seiki NV5000@40 with a Tsudakoma Tilt Rotary and a Renishaw MP700.
I'm aligning the "A" first then establishing my "X" with the "B" at -90. then stand it up at "A0.B0." do a Boss Bore. the thing I'm unclear on is how do input that in to the fixture offset to use for the Dynamic Fixture Offsets?
Thanks in advance
G80
G91G28Z0.T30
M11("A" UNLOCK)
M69("B" UNLOCK)
G0G90G17G94G54Y0.
G40G49
N1G90T30M6(RENISHAW TOUCH PROBE .1181 DIA,)
G0G90G54G17G94X-7.7734Y0.B-90.A0.T2
G43H30Z2.5
M68(B LOCK)
M144(PROBE ON)
G65P9810Z2.5F200.
G65P9818Y0.8971Z.6S1(4TH AXIS MEASURE)
G65P9810Z2.5F200.
G0G90G55X-7.7734Y0.A0.
G9(EXACT STOP)
M10(A LOCK)
G0G90G54X-10.Y0.
G65P9810Z.3624F200.
G65P9811X-9.6651S1(SINGLE SURFACE MEASURE)
G65P9810Z2.5F200.
G0G90G54X-9.6651Y0.
G9(EXACT STOP)
#7141=#7121("X" TRANSFER)
#7161=#7121
#7181=#7121
#7201=#7121
M69(B UNLOCK)
G91G28Z0.
G0G90G55X0.Y0.B0.
G65P9810Z10.F200.
G65P9814D.89Z9.0538S2(BOSS BORE MEASURE)
G65P9810Z10.F200.
G0G90G55X0.Y0.
G9(EXACT STOP)
#7121=#7161("X" TRANSFER)
#7141=#7161
#7181=#7161
#7201=#7161
#7122=#7162("Y" TRANSFER)
#7142=#7162
#7182=#7162
#7202=#7162
M145
G91G28Z0.M5
G40G49
M1
N1T2M6(4.5 CENTERDRILL)
G0G90G17G94G10L21P1X#135Y#136S1300M3T3
G11(3D ARC)
G54.2P0
G55X.23Y0.B0.A0.
G54.2P1
G43H2Z11.125M88
M10("A" LOCK)
M68("B" LOCK)
G98G73Z6.4851R6.8901Q.005F1.
G80
G54.2P0
M11("A" UNLOCK)
M69("B" UNLOCK)
M89S200
G91G28Z0.M5
G40G49
M1
N2T3M6(9.5MM DRILL C.F.)
G0G90G17G94G10L21P1X#135Y#136S1685M3T4
G11(3D ARC)
G54.2P0
G55X.23Y0.B0.A0.
G54.2P1
G43H3Z11.125M88
M10("A" LOCK)
M68("B" LOCK)
G98G73Z5.7324R6.8901Q.5F3.7
G80
G54.2P0
M11("A" UNLOCK)
M69("B" UNLOCK)
M89S200
G91G28Z0.M5
G40G49
M1
N3T4M6(3/8 SPOTDRILL)
G0G90G17G94G10L21P1X#135Y#136S1300M3T5
G11(3D ARC)
G54.2P0
G55X0.Y0.B0.A0.
G54.2P1
G43H4Z11.125M8
M10("A" LOCK)
M68("B" LOCK)
G98G73Z6.7151R6.8901Q.005F1.
G80
G54.2P0
M11("A" UNLOCK)
M69("B" UNLOCK)
M9S200
G91G28Z0.M5
G40G49
M1
N4T5M6(3/8 ENDMILL FLAT BOTTOM)
G0G90G17G94G10L21P1X#135Y#136S1426M3T6
G11(3D ARC)
G54.2P0
G55X0.Y0.B0.A0.
G54.2P1
G43H5Z11.125M8
M10("A" LOCK)
M68("B" LOCK)
G98G73Z6.7151R6.8901Q.005F1.5
G80
G54.2P0
M11("A" UNLOCK)
M69("B" UNLOCK)
M9S200
G91G28Z0.M5
G40G49
M1
N5T6M6(#3 CENTERDRILL)
G0G90G17G94G10L21P1X#135Y#136S1200M3T7
G11(3D ARC)
G54.2P0
G55X-6.3451Y0.B-90.A0.
G54.2P1
G43H6Z1.125M8
M10("A" LOCK)
M68("B" LOCK)
G98G73Z.32R.625Q.005F1.
G80
G54.2P0
M11("A" UNLOCK)
M69("B" UNLOCK)
M9S200
G91G28Z0.M5
G40G49
M1
Not 100% sure on your machine, but on a mazak running G-code there is a page for offsets G54.1 etc. If one of these is called in the programme then the machine calculated the position relative to COR for you. Should be something similar for the Mori. From your code it looks like you are just calling a standard G54, which might not be what you need if you want dynamic comp. If you have a table that you bolt on then the COR would need to be entered as a parameter each time I would imagine so that the machine knows where it is relative to home.
Bruce
+1 Bruce... My comments pertain to Mazak also. I will also add that I like to keep the pivot point center in 2 places (just in case). We never have had a reason to use G54.1P300 therefore that is where I put my pivot point center. I could now put the same # into any work offset I please and have something to go back to if fat fingers get in a way.
Another critical part is that your pivot point values MUST be the same as the values from the calibration cycle. In Mazak's case those are S5 (XY Values) and S12 (Z value).
