Sinumerik 840D Probing Help
Devin M
well, we have the renshaw probe for the machine, but it's never been used. What i would like to do, is setup my trim tool on the machine, probe it to find its actual location, then translate my trim program so it matches where the tool actuly is. i need some help as to how we would use the renshaw probe to find the location of my tools.
that sounds completly doable, below is a routine that changes the programs zero (based on variables). is there training available to you? it would make things alot easier.
thanks,
jg
note: parenthesis were changed to [], bbs said they are not allowed in a html tag??
IF[R16<2]
GOTO N100
ENDIF
IF[R13
GOTO N100
ENDIF
IF[R19==1]
R9=.5
ENDIF
IF[R19==2]
R9=-.5
ENDIF
R4=1
R0=20
R18=R12/2
T999
M6
M27
G0 C0
IF[R15<>9999]
A=R15
ENDIF
TRANS X=R10 Y=R11 Z=0 ;<<<<<<<<<<< shift zero
TRAORI
X=0 Y=R18+R9
Z=R13
G1 Z=R14 F300.
WHILE[R4<=R16]
IF[R17==1]
G1 Z=R14
ENDIF
MEAS=1 G1 Y=R18-R9 F15.
STOPRE
R[R0]=$AA_MW[Y];R[R0]+$AA_MW[Y]
R0=R0+1
Y=R18+R9 F300.
IF[R17==1]
Z=R13
ENDIF
AROT Z=[360/R16];*R4
G3 X0 Y=R18+R9 C=IC[[360/R16]] CR=R18+R9
R4=R4+1
ENDWHILE
G1 Z=R13
R4=R16
R0=20
R2=R[R0]
R3=R[R0]
R1=0
WHILE[R4>0]
IF[R[R0]>R2]
R2=R[R0]
ENDIF
IF[R[R0]
R3=R[R0]
ENDIF
R1=R1+R[R0]
R4=R4-1
R0=R0+1
ENDWHILE
R1=R1/R16
R2=R2-R1
R3=R3-R1
R1=R1*2
IF[R15<0]
R4=SIN[R15]*R8
R8=R8+R4
ENDIF
IF[R19==1]
R1=R1-[R8*2]
ENDIF
IF[R19==2]
R1=R1+[R8*2]
ENDIF
TRAFOOF
ROT
G0 C0
N100 M30
Can you clarify to me what the variables stand for? also, do you have a complete coded program for probign a strait line (probe 2 points, find the angle, rotate by that angle)
These are the things I need clarification with:
- TRAORI
- MEAS
- STOPRE
- $AA_MW[Y]
- AROT
- TRAFOOF
- ROT
What are the variables initialized to at the beginning and which ones?
Also, how can you check if the probe is activated (ready to be used)?
How do you turn it on/off?
Devin,
I don't think I can give you all that you are asking but....
On this particular machine it is turned on automatically when called, it can also be turned on by a M27 code.
That depends on the program and what you need, I did not list the ones that were preset, this was meant as an example.
- TRAORI
- MEAS
- STOPRE
- $AA_MW[Y]
- AROT
- TRAFOOF
- ROT
TRAORI = TRAnsformation and ORIentation (dynamically), it is tool point programming, if you rotate the table
(on a head/table config for example) the tool tip will "follow" automatically maintaining the same relative position.
-MEAS = enables measuring mode on the control (G31 skip signal)
-STOPRE = STOPREading ahead, prevents the control from buffering to far ahead.
-$AA_MW[Y] = reading the Y axis position after the probe triggered.
-AROT = Additive ROTation of the WCS
-TRAFOOF = shuts traori off
-ROT = ROTation of the WCS
I would have to go thru and re-figure them myself, this macro was used to probe dia's that the machine could not reach using X and Y, it rotated the part instead.
do you have a complete coded program for probing a strait line (probe 2 points, find the angle, rotate by that angle)
I don't, that was a canned routine in the control (I no longer have access to the control)
hope this helps, I'll look and see if I have any other info.
thanks,
jg
  • 4 months later...
