depth cut order
belearner
Hi all.
I just try out with X3 on a simple contour toolpath depth cut mark( 2 steps down)and 2 rough path around a 2 by 2 square part. As a result, i always get 2 rough path with same z depth and 2 rough path at final z depth. i can't get the tool path " by contour "
Any idea would be appriciate.
If I am not mistaken the only way to accomplish this would be to Transform - Offset Contour the desired stepover.
Chain the offset contour first then desired contour when chaining toolpath. Using no multi pass and "by contour" in depth cuts.
"By contour" will cut the first chain to full depth then go to the next chain.
If by depth is selected in depth cuts it will cut as you are already getting using multi pass, each chain will be cut in order but one depth cut at a time.
Select a new layer before creating offset geometry and it can be blanked in level manager to get it out of the way after used.
Have a good weekend
