Post Help
mtnflyr
Hi All,
I'm looking for post help for a Kitamurea with Fanuc 16IMB control.
The program needs to have G05.1Q0 followed on the next line by G05.1Q1, at the top of the program.
I've added the this (See below) to my post from mpmaster but I'm missing something.
The G05.1 lines are not posting.
Please help...
#added on 09/14/09 for Kitamura
plast
last_op_id = op_id$
last_cuttype = cuttype
last_rotary_type = rotary_type$
last_tlplnno = tlplnno$
last_mr1 = mr1$
last_mr2 = mr2$
phsm1_on #High speed functions before G43
if opcode$ = 3 | opcode$ = 16,
mr1$ = 0
mr2$ = 0
if mr1$ = 1 & mr1_flg <> 1, #Advanced Preview (look-ahead) control - G08 P1
pbld, n$, "G08", "P1", e$
mr1_flg = 1
if mr1$ = 2, #AI-NANO 2, AI(nano)CC output (Artificial Intelligence Contour Control) - G05.1 Q1
pbld, n$, *sg49, e$ #Must be in G49 and remain before G43
if ipr_type > 1, ipr_type = 0 #Must be in G94
pbld, n$, sgfeed, e$
pbld, n$, "G05.1", "Q1", [if mr2$, "R", no_spc$, *mr2$], e$ #Mr2 gives accel/decel value/coefficient, usually R or P
mr1_flg = 2
# HPCC is working when called before G43.4 on Fanuc 31i
# if mr1$ = 3 & mr1_flg <> 3, #AI-HPCC and AI-nanoHPCC (High Precision Contour Control) - G5 P10000
# if ipr_type > 1, ipr_type = 0 #Must be in G94
# pbld, n$, sgfeed, e$
# pbld, n$, "G05", "P10000", [if mr2$, "R", no_spc$, *mr2$], e$
# #pbld, n$, "G05.1", "Q2", e$ #auto arc filtering
# mr1_flg = 3
phsm2_on #High speed functions after G43
mr1$ = 0
mr2$ = 0
# HPCC is working when called before G43.4 on Fanuc 31i, see phsm_1 above
mr1_flg = 3
if mr1$ = 4 & mr1_flg <> 4, #Mazak Geometry Compensation/Accuracy G61.1, Mazak High Speed Machining Mode - G05 P2
pbld, n$, sgfeed, e$ #Mazak can be in G94 or G95 but it must be called before G05 P2
if mr2$, pbld, n$, "G61.1", ",K", no_spc$, *mr2$, e$ #Mr2 gives accel/decel value/coefficient, K
else, pbld, n$, "G61.1", e$
pbld, n$, "G05", "P2", e$
mr1_flg = 4
!convert_rpd$ #Mazak Fusion requires high feed motion only, comment out for Matrix
convert_rpd$ = one #Mazak Fusion requires high feed motion only, comment out for Matrix
phsm_off #High speed functions off
if mr1_flg = 1, #Advanced Preview (look-ahead) control - G08 P1
pbld, n$, "G08", "P0", e$
mr1_flg = 0
if mr1_flg = 2, #AI-NANO 2, AI(nano)CC output (Artificial Intelligence Contour Control) - G05.1 Q1
pbld, n$, "G05.1", "Q0", e$
mr1_flg = 0
if mr1_flg = 3, #AI-HPCC and AI-nanoHPCC (High Precision Contour Control) - G5 P10000
#pbld, n$, "G05.1", "Q0", e$ #auto arc filtering
pbld, n$, "G05", "P0", e$
mr1_flg = 0
if mr1_flg = 4, #Mazak Geometry Compensation/Accuracy G61.1, Mazak High Speed Machining Mode - G05 P2
pbld, n$, "G64", e$
mr1_flg = 0
convert_rpd$ = prv_convert_rpd$ #Mazak Fusion requires high feed motion only, comment out for Matrix
this is how i have our kitamura 4XiF setup
no i meant in the operation i have all our defaults set to MR1=3
is this what you trying to do
AI NANO
O0000 (TKTK)
(KITAMURA 4XiF)
(MCX FILE - TONY FORGOT TO SAVE)
(DATE - SEP-14-2009)
(PROGRAMMER - )
(REV LEVEL )
N1G0G17G20G40G80G90
N6G91G28Z0.
N11M28 (CHIP CONVEYER ON)
(3/4 SUNAMI VARIMILL IN THRU COOLANT HOLDER - 900 SFM TOOL - 13 DIA. OFF. - 13 LEN. - 13 DIA. - .75)
N16(TEST G5 Q1)
N21T13M6
N26M50 (CHIP FLUSH ON)
N31S4584M3
N36G0G17G90G54X-.8678Y1.2918
N41G40G80G49
N46G990 Q1.F128.35
N51G05.1Q1
N56G43H13Z3.
N61Z.1
N66G94G1Z-1.F100.
N71G41D13Y1.1418F128.35
N76G3X-.7178Y.9919I.15J0.
N81G1X.7151Y.9918
N86G2X1.0901Y.6169I0.J-.375
N91G1Y-.7097
N96G2X.7151Y-1.0846I-.375J0.
N101G1X-.7178Y-1.0847
N106G2X-1.0928Y-.7097I0.J.375
N111G1Y.6168
N116G2X-.7178Y.9919I.375J0.
N121G3X-.5678Y1.1419I0.J.15
N126G1G40Y1.2918
N131G0Z3.
N136G05.1Q0
N141G990 Q0.
N146G91G28Z0.
N151G28Y0.
N156M29
N161M30
HPCC
O0000 (TKTK)
(KITAMURA 4XiF)
(PROGRAMMER - )
(REV LEVEL )
N1G0G17G20G40G80G90
N6G91G28Z0.
N16(TEST G5 Q1)
N21T13M6
N31S4584M3
N41G43H13Z3.
N46G94
N51G5P10000
N56Z.1
N61G1Z-1.F100.
N66G41D13Y1.1418F128.35
N71G3X-.7178Y.9919I.15J0.
N76G1X.7151Y.9918
N81G2X1.0901Y.6169I0.J-.375
N86G1Y-.7097
N91G2X.7151Y-1.0846I-.375J0.
N96G1X-.7178Y-1.0847
N101G2X-1.0928Y-.7097I0.J.375
N106G1Y.6168
N111G2X-.7178Y.9919I.375J0.
N116G3X-.5678Y1.1419I0.J.15
N121G1G40Y1.2918
N126G0Z3.
N131G5P0
N136G91G28Z0.
N141G28Y0.
N146M29
N151M30
I've just started at this company today. They have been using Gibbscam. I need to duplicate how their programs post or as a reasonably close to that as possible in Mastercam.
This is an example of how the programs are posted here.
N1G17G40G80G49
N2G05.1Q0
N3G05.1Q1
N4G54
N5T1
N6M6
( OPERATION 1: HOLES )
( MILL C'BORE .256 X .118 DEEP )
( TOOL 1: .125 COUNTERSINK )
( CS#1 - XY PLANE )
N7T002
N8S6000M3
N9G90G0X.0044Y0.
N10G43Z1.H1
N11M8
N12Z.1
N13G82G99X.0044Y0.Z-.0625R.1P200F30.
N14G80
N15M9
N16G91G28Z0.
N17M5
N18M1
Every tool starts with the lines:
G17G40G80G49
G05.1Q0
G05.1Q1
Well that is very off. What do those codes do for that machine? I would just hard code it for now if it is a requirement, but would research what they do since it seems like they are turning it on and off with those 2 lines. Also if memory serves me correct you are not suppose to use it for drilling cycles and that would include tapping.
im confused why they would have it setup like that...bad gibbs cam post maybe
look in the kitamura book it will tell you how G5 Q1 works and when the machine will just shut it off (drilling/tapping/toolchange/etc)i dont know why you would make sure it is off just to turn it on
i ran into a similar problem here with edgecam they wanted the code just like so out of MC i told them you got more BS in the program then is needed
here is what it should look like they fought it in the beginning but now they are use to it change can be a hard pill to swallow
if they are dead set on it hard code it like ron said
good luck
Agreed. It probably doesn't need to post as the example shows. It would be more effecient if it only turned on when needed.
I don't think they'll have a problem if it isn't exactly like the Gibbs programs as long as it works. So far none of the test programs I've posted is putting in the code anywhere. Does the command only come up with certain kinds of contour cuts or should it post with any contour cut?
