Work Offset outputs 54=G54, 55=G55
Newbeeee™
Hi All,
This query has grown from an earlier post ref G54 output.
Big thanks to ColinG@Boeing for pointing me in the right direction, but I'm not quite there.
What I want is to be able to enter 54/55/56/57/58/59 accordingly into the work offset box, and have it output G54/G55/G56 etc.
I have left the existing part of the post to allow -1 and 0 for G54, 1 for G55 etc so this will allow us to either work as we always have, and have the option of working this new way.
Below is the PWCS section (fanuc4axis):
pwcs #G54+ coordinate setting at toolchange
if mi1$ > one,
sav_frc_wcs = force_wcs
if sub_level$, force_wcs = zero
if sav_mi9 = 1, workofs$ = sav_workofs
if workofs$ <> prv_workofs$ | (force_wcs & toolchng),
if workofs$ < 6,
g_wcs = workofs$ + 54
*g_wcs
else,
if workofs$ = 6 to 53, pwcs_error<<<<<<[HOW DO I WRITE THIS CORRECTLY?]
if workofs$ = 54, g_wcs = workofs$, *g_wcs
if workofs$ = 55, g_wcs = workofs$, *g_wcs
if workofs$ = 56, g_wcs = workofs$, *g_wcs
if workofs$ = 57, g_wcs = workofs$, *g_wcs
if workofs$ = 58, g_wcs = workofs$, *g_wcs
if workofs$ = 59, g_wcs = workofs$, *g_wcs
if workofs$ >= 60, pwcs_error
force_wcs = sav_frc_wcs
!workofs$
pwcs_error # Sends an error message to the screen if the programmer enters 6>53 & 60> in the work offsets parameter in the Planes dialog box.
result = mprint(spwcserror)
e$
"$$$$$$$$$$$$$$$$$$$$$$$$$$$$$" ,e$
" ERROR - SET WORK OFFSET CORRECTLY AND RE-POST ", e$
"$$$$$$$$$$$$$$$$$$$$$$$$$$$$$", e$
exitpost$
What it currently does is work correctly for -1 to 5 (outputting G54 to G59), and then posts Error when entering 6 and above.
I know the format is incorrect for one of the lines highlighted, and if I # it out, it works as it should when entering 54/55/56 etc.
However, it doesn't output an error message when entering 6 to 53.
60 and above outputs an error, so I assume it's the format for the one highlighted line that is incorrect?
Appologies for the long post, but hopefully this will help someone if they want to be able to work the same way (providing I can get this working!)
Many thanks in advance for any pointers.
Cheers,
Terry
I did some testing over the weekend and this doesn't work.
With the post changed as per guru's suggestion, -1 to 5 input = 54 to 59 output (correct).
6 to 53 input = error output (correct).
54 to 59 input = error output (incorrect).
60 and above input = error output (correct).
So I can only assume that the format of the line
if workofs$ = > 5 & workofs$ < 54, pwcs_error
is not correct?
If I # out the line, then 54 to 59 input = 54 to 59 output. But the error message doesn't then show for the incorrect input values.
Anyone got any thoughts?
Terry
This is working fine for me.
e$
exitpost$
if wcstype = two | wcstype > three,
if sub_level$ > zero, force_wcs = zero
if workofs$ < 0, workofs$ = 0
if workofs$ <> prv_workofs$ | (force_wcs & toolchng) | sof,
if workofs$ < 6,
g_wcs = workofs$ + 54 #0-6 G54-G59
*g_wcs
else,
if workofs$ > 5 & workofs$ < 54, pwcs_error
if workofs$ = 54, g_wcs = workofs$, *g_wcs #54-59 G54-G59
if workofs$ > 59, pwcs_error
!workofs$
Here's another variation with extended offsets. G54.1 P1 and up.
spwcserror  "WARNING - WCS OUT OF RANGE 0-6 = G54-G59, 54-59 = G54-G59, 101 AND UP = G54.1 P1 AND UP"
pwcs_error # Sends an error message to the screen if the programmer enters 6 thru 53 or 60 thru 100 in the work offsets parameter in the Planes dialog box.
e$
exitpost$
if workofs$ < 6,
*g_wcs
if workofs$ > 53 & workofs$ < 60,
g_wcs = workofs$ #54-59 G54-G59
*g_wcs
if workofs$ > 59 & workofs$ < 101, pwcs_error
if workofs$ > 100,
p_wcs = workofs$ - 100 #101+ G54.1 P1+
"G54.1", *p_wcs
!workofs$
[ 11-09-2009, 07:54 AM: Message edited by: Mastercam Guru ]
As you can see, I had the format wrong by adding the = to the statement.
Funny thing was when testing I looked and looked and didn't see it...
Anyway, yes it works like a charm. So BIG thanks Guru and Colin G [boeing] for initially pointing me in the right direction.
HTH someone else.
Cheers,
Terry
