Plunge Roughing
Marker
I am plunging out material for a motorcycle seat base mold. The Surface Rough Plunge operation is generating an unnecessary toolpath that cuts air at Z0, or whatever I set my minimum cut depth to, before it cuts to the appropriate depths relative to the surfaces and stock to leave. I am using a NCI generated toolpath. I can get it to work correctly if the surface is flat and I set my absolute cut depths to the same value, but when the surfaces are not flat, I can't keep the cut depths the same because it plunges out material that I want to keep.
Any ideas?
Accu-Molder,
I tried your suggestion. The tool stayed the same depth through the hole toolpath. So then I put the same value in the "adjustment to other cuts", but made it a negative and it worked for this particular situation. I'll keep "playing" with the incremental side of cut depths. I am still learning that side of it.
Thanks.
