Can D (tool dia) number be set by the post?
millman2002
Hi all:
I hope I can describe what I need so you can under stand it. I have to program the same parts to run on three different machines. Fadal, Mazak, Matsuura.
What I am want to do is make one MC9 file with the tool dia. offset and tool length offset set the same as the tool no. (under Job setup, Tool Offset Registers, Add checked, length and diameter set to 0). Then, when I run the post for Fadal and Mazak, it will out put T1 - D1 - H1.
Can I change the mpfan.pst so that I can use the same MC9 file (with tool dia. offset set same as tool number) but have the post output T1 - D41 - H1 ?
Basically take the tool dia. offset and add 40 to in the post..
I hope I haven’t confused everyone..
Thank
Gary
It's pretty easy to add a statement in the post to add 40 to the offset.
I'd recommend creating a new variable (tloffno40), and then set this variable to the tloffno + 40, and output it in place of tloffno in the pccdia section.
You need to define the tloffno40 variable first:
fmt D 4 tloffno40
Just search for tloffno in the post, and you'll see the right format and what needs to be replaced.
You may want to enlist your dealer to help, but this should not be a difficult change.
Thanks All:
The post is working with one problem. After a tool change the first D outputs OK. G41 D41 X0 y0. But the rest of the G41s have no D. G41 X0 Y0.
Sample code:
T19M6
G0G90G54X-10.0708Y-3.154A0.S2139M3
G43H19Z2.M8
Z.1
G1Z-.27F6.42
G41D59X-9.9626Y-3.2165(has 40 added to D. OK)
G3X-9.5876Y-3.R.25
X-10.6956R.554
G1G40X-9.6621Y-2.8202
G0Z2.
X-.0533Y-3.154
Z.1
G1Z-.27
G41X.055Y-3.2165 (Does not put D for each G41
G3X.43Y-3.R.25
Here’s what I changed
# Toolchange / NC output Variable Formats
fmt T 4 t #Tool Number
fmt T 4 first_tool #First Tool Used
fmt T 4 next_tool #Next Tool Used
fmt D 4 tloffno #Diameter Offset Number
fmt D 4 tloffno40 #Diameter Offset Number + 40 #added this line
fmt H 4 tlngno #Length Offset Number
pccdia #Cutter Compensation
#Force Dxx#
tloffno40 = tloffno + 40
if prv_cc_pos <> cc_pos & cc_pos,
prv_tloffno = c9k
sccomp
if cc_pos, tloffno40 #Changed from tloffno # Changed this line
Is there something I need to change?
Thanks again
Gary
Original Code...
#Force Dxx#
prv_tloffno = c9k
sccomp
Change "prv_tloffno = c9k"
to be "prv_tloffno40 = c9k"
Altered Code...
#Force Dxx#
prv_tloffno40 = c9k
sccomp
