Post question on staging tools
Davidgil
I have modified the MPMASTER post to work with my FADAL 4525, but I'm having a little trouble with staging tools. The command for staging on the fadal needs to have a '-' minus sign in it, example: T-23 instead of T23. I can't figure out how to get the minus sign in. One idea I had would be to take the next_tool variable, strip off the T, and add back a T-, however I'm not familiar enough with the syntax for commands in the post. Any ideas or suggestions?
Dave
David,
Easy to modify:
# Toolchange / NC output Variable Formats
fmt T- 4 t #Tool No
fmt T 4 first_tool #First Tool Used
fmt T 4 next_tool #Next Tool Used
fmt D 4 tloffno #Diameter Offset No
fmt H 4 tlngno #Length Offset No
fmt G 4 g_wcs #WCS G address
fmt P 4 p_wcs #WCS P address
fmt S 4 speed #Spindle Speed
fmt M 4 gear #Gear range
Just add the dash right after the T with no spaces
and it should work.
If I understood your description correctly, it is T-4 to stage tool 4 (next tool), and T4 to load tool four for use. If that is the case, than the correct syntax is:
fmt T 4 t #Tool No
fmt "T-" 4 first_tool #First Tool Used
fmt "T-" 4 next_tool #Next Tool Used
I am fairly certain the double quotes are necessary, but I am not 100% certain of that.
If they are not necessary, all they do is make your post processor 4 bytes larger, which should not be an issue with the size of today's hard disks cool.gif
