Vector Length in Surfacing Toolpaths
McRae
It matters, because that is what gets output to the NCI file. Your post uses these vectors to calculate the angles. If the vector is too small you will loose some accuracy.
You might want to try turning off the toolpath on the backplot menu and just show the tool.
[ 12-04-2002, 12:08 PM: Message edited by: Rich Taft from CNC Software ]
Like Rich said, it affects the data passed to the post via the NCI file. May lose accuracy as the tool vector is decreased below 1 unit - a 'unit vector' is used in the post.
I posted out a sample file with a 1" vector, then the same file with a .25" vector. Angular moves were affected by +/-.001 deg in 1/6 or less of the file.
The tool vector is used in Lathe C axis, 4 axis Mill/Lathe and 5 axis Mill/Lathe toolpaths.
In other toolpaths, it is the number of decimals in the NCI file that determines the accuracy, through the contruction plane / tool plane matrices.
The number of decimals in the NCI file also affects the accuracy of the tool vectors, of course.
I hope this answers your question.
