vb problem in output to excel file
Hi All;
i have a problem in vbs output to excel file,when i open the excel file and use the print preview function,the graphic box become large and change to orginal size.
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
' -- Add code here...
' -- Start ScriptCall Main()
' Sub Declaration
Dim intLevelNumber
Dim strMc
Dim strOriginalPath
Dim DataPoint
Dim Cpoint
Dim datax
Dim datay
Dim dataz
'-- Loop all levels, hide all except the one the user wants
Dim lv_app
Dim lv_excel
Dim graphic
Dim lv_text
Dim Picture
Set lv_app = CreateObject("Excel.Application")
Set lv_excel = lv_app.workbooks.open ( "C:XYZ.XLS")
Dim i
Dim j : j = 1
Dim k : k = 16.5
For i = 1 To 100
If i <> intLevelNumber Then
Call SetLevelVisibleByNumber(i,True)
If IsDrawing() Then
SetLevelByNumber(i)
strOriginalPath = GetCurrentFileName()
'renname with LevelNumber
strMC= Replace(LCase(strOriginalPath), ".mc9", "-" & i & ".mc9")
Call RunMastercamCommand("fit")
'look for alive points
datapoint = StartDBSearch(mc_alive, mc_pointtype)
If (DataPoint = False) Then
ShowString "nil"
lv_excel.saveas( "C:XYZ.XLS")
CloseExcelFile
Exit Sub
End If
Set CPoint = New McPt
' -- Get this point x,y,z
If GetPointData(GetEntityEptr, cpoint) Then
'ShowString i
'get point data
datax=Round(cpoint.x,3)
datay=Round(cpoint.y,3)
dataz=Round(cpoint.z,3)
lv_excel.sheets(1).cells((j-1)*15+1,1) = datax
lv_excel.sheets(1).cells((j-1)*15+1,2) = datay
lv_excel.sheets(1).cells((j-1)*15+1,3) = dataz
j = j + 1
End If
graphic= Replace(LCase(strOriginalPath), ".mc9", "-" & i & ".emf")
' save emf file
DoMetafile graphic
'Height = 2000: Width = 1000
'Picture = LoadPicture(graphic)
' lv_excel.sheets(1).Shapes.AddPicture(Filename, LinktoFile, SavewithDocument, Left, Top, Width, Height)
Set lv_text = lv_excel.sheets(1)
lv_text.Shapes.AddPicture graphic, False , True , 0,k, 200, 160
k= k + 247.5
' save file
Call SaveMCAs(strmc,True)
Call SetLevelVisibleByNumber (i,False)
End If
End If
Next
Call RepaintScreen(True)
'End If
ShowString "complete"
lv_excel.Close
lv_app.quit
Set lv_app = Nothing
End Sub
'entity serach
Function IsDrawing()
Dim Ret
Ret = StartDBSearch(mc_alive, -1)
IsDrawing = Ret
End Function
' Function Declaration
Public Sub ShowAllLevels
'-- Loop all levels and show them
Dim i
For i = 1 To 255
Call SetLevelVisibleByNumber(i,False)
Next
End Sub
thanks
Maks
 DoMetafile graphic
I would look here may need to put control in here to allow the user to isze it to there needs. That Seems very big but since I can not test the code at home will have to wait till tommorrow if I go in to change out parts or for one of the VB kings like Rekd, Chris, Mick or others.
For our Excel set-up Sheets I use Clipboard. Do a search and There is a quick a easy script for doing Scren to white open up clipboard then change screen back to black again. rekd help me out with that one it is a real time saver.
I've seen Excel have that problem with EMFs and it is quite weird. Excel appears not to like embedding resized EMF files into a spreadsheet. But BMPs seem to work ok. Try replacing this:
with this:
graphic= Replace(LCase(strOriginalPath), ".mc9", "-" & i & ".bmp")
And replace this:
' save emf file
DoMetafile graphic
with this:
' save bmp file
Call DoBitmapfile(strOriginalPath, graphic)
Hope this helps.
