In the help file it mentions the Mastercam.txt file (Mill9.txt). It says we have access to every function that is "keymappable". It says they start on line #9001. But when I go to that line it is on the middle of group. Could someone guide me to the correct spot in the file? I would like to print them out to help make it easier to look up.
Here is a file with all the commands, and a few examples at the bottom.
'// Author: PCR
'// Date: 11/02/2003 03:19 PM
'// File Name: RunCommand.vbs
'// Description: Runs a mastercam menu command and creates a rectangle from to user defined points.
'// Press ESC key when done.
'// Comments: Run almost any Mastercam command - this gives access To every Function
'// that Is ‘keymappable’. This list appears when F10 Is hit. The input character
'// ‘codes’ are listed In the Mastercam .TXT File For the product you’re running,
'// (i.e. Mill9.txt, Router9.txt, etc) starting at Line #9001
'// ****** Router Commands ********
''9001. "zoom: Screen-Zoom"
''9002. "unzoom: Screen-Unzoom"
''9003. "repaint: Screen-Repaint"
''9004. "analyze: Analyze"
''9005. "delete: Delete"
''9006. "file: File"
''9007. "modify: Modify"
''9008. "create: Create"
''9009. "dispinfo: Screen-Display info"
''9010. "help: Help"
''9011. "fit: Screen-Fit"
''9012. "unzoom8: Screen-Unzoom by 0.8"
''9013. "curpos: Cursor Tracking (Toggle)"
''9014. "delwndw: Delete-Window"
''9015. "editfile: File-Edit"
''9016. "blank: Screen-Blank"
''9017. "config: Screen-Configure"
''9018. "drwaxes: Screen-Draw axes"
''9019. "rundll: Execute C-Hook"
''9020. "draftpm: Draft-Globals"
''9021. "font: Menu Font"
''9022. ""
''9023. "mmalloc: List Memory"
''9024. "mfile: List Files"
''9025. "undo: Undo"
''9026. "surfdisp: Screen-Surf Disp"
''9027. "drawnc: Screen-Draw Toolpath"
''9028. "vwports: Screen-Viewports"
''9029. "version: Version"
''9030. "xform: Xform"
''9031. "autosave: File-AutoSave"
''9032. "group: Groups"
''9033. "chgcolrs: Screen-Change Colors"
''9034. "chglevs: Screen-Change Levels"
''9035. "autocl: Automatic Centerlines"
''9036. "color: Main Color"
''9037. "level: Levels-Main"
''9038. "mask: Levels-Mask"
''9039. "tplane: Tplane"
''9040. "cplane: Cplane"
''9041. "gview: Gview"
''9042. "zdepth: Cplane-Depth"
''9043. "levdlg: Levels-Dialog"
''9044. "vislev: Levels-Visible"
''9045. "toolbar: Toolbar Visible (Toggle)"
''9046. "dbstats: Screen-Statistics"
''9047. "endpts: Screen-Endpoints"
''9048. "clrcolrs: Screen-Clear Colors"
''9049. "shade: Screen-Surf Disp-Shading"
''9050. "crpoint: Create-Point"
''9051. "crptpos: Create-Point-Position"
''9052. "ptalong: Create-Point-Along Entity"
''9053. "nodepts: Create-Point-Node Points"
''9054. "ctrlpts: Create-Point-Cpts NURBS"
''9055. "ptdynmic: Create-Point-Dynamic"
''9056. "crptlen: Create-Point-Length"
''9057. "ptsrfprj: Create-Point-Surface Project"
''9058. "crline: Create-Line"
''9059. "clhorz: Create-Line-Horizontal"
''9060. "clvert: Create-Line-Vertical"
''9061. "clepts: Create-Line-Endpoints"
''9062. "clmulti: Create-Line-Multi"
''9063. "clpolar: Create-Line-Polar"
''9064. "cltan: Create-Line-Tangent"
''9065. "cltanang: Create-Line-Tangent-Angle"
''9066. "cltan2a: Create-Line-Tangent-2 Arcs"
''9067. "cltanpt: Create-Line-Tangent-Point"
''9068. "clperp: Create-Line-Perpendicular"
''9069. "clparal: Create-Line-Parallel"
''9070. "crarc: Create-Arc"
''9071. "capolar: Create-Arc-Polar"
''9072. "cactrpt: Create-Arc-Polar-Center Point"
''9073. "casktch: Create-Arc-Polar-Sketch"
''9074. "castart: Create-Arc-Polar-Start Point"
''9075. "caend: Create-Arc-Polar-End Point"
''9076. "caepts: Create-Arc-Endpoints"
''9077. "ca3pts: Create-Arc-3 points"
''9078. "catan: Create-Arc-Tangent"
''9079. "catan1: Create-Arc-Tangent-1 Entity"
''9080. "catan3: Create-Arc-Tangent-3 Entities"
''9081. "catanpt: Create-Arc-Tangent-Point"
''9082. "ca2ptcir: Create-Circle-2 Points"
''9083. "ca3ptcir: Create-Circle-3 Points"
''9084. "captrad: Create-Circle-Point/Radius"
''9085. "captdia: Create-Circle-Point/Diameter"
''9086. "captedge: Create-Circle-Point/Edge"
''9087. "crfillet: Create-Fillet"
''9088. "crspline: Create-Spline"
''9089. "crcurve: Create-Curve"
''9090. "ellipse: Create-Ellipse"
''9091. "ccconst: Create-Curve-Const Parameter"
''9092. "ccedge: Create-Curve-One Edge"
''9093. "ccinter: Create-Curve-Intersect"
''9094. "ccpatch: Create-Curve-Patch Boundaries"
''9095. "ccflow: Create-Curve-Flowline"
''9096. "ccproj: Create-Curve-Project"
''9097. "ccdynmic: Create-Curve-Dynamic"
''9098. "ccpart: Create-Curve-Parting Line"
''9099. "crsurf: Create-Surface"
''9100. "csloft: Create-Surface-Loft"
''9101. "cscoons: Create-Surface-Coons"
''9102. "csruled: Create-Surface-Ruled"
''9103. "csrev: Create-Surface-Revolved"
''9104. "csswept: Create-Surface-Swept"
''9105. "csdraft: Create-Surface-Draft"
''9106. "csfillet: Create-Surface-Fillet"
''9107. "csofst: Create-Surface-Offset"
''9108. "cstrim: Create-Surface-Trim"
''9109. "csblend: Create-Surface-2 Surface Blend"
''9110. "crrec: Create-Rectangle"
''9111. "rec1pt: Create-Rectangle-1 Point"
''9112. "rec2pts: Create-Rectangle-2 Points"
''9113. "crdraft: Create-Drafting"
''9114. "cddim: Create-Drafting-Dimension"
''9115. "crnote: Create-Drafting-Note"
''9116. "crlabel: Create-Drafting-Label"
''9117. "crleader: Create-Drafting-Leader"
''9118. "crwit: Create-Drafting-Witness Line"
''9119. "eddraft: Create-Drafting-Multi edit"
''9120. "crhatch: Create-Drafting-Hatch"
''9121. "chamfer: Create-Chamfer"
''9122. "crlets: Create-Letters"
''9123. "pattern: Create-Pattern"
''9124. "anzpt: Analyze-Point"
''9125. "anzonly: Analyze-Only"
''9126. "anzbpts: Analyze-Between points"
''9127. "anzang: Analyze-Angle"
''9128. "anzdynm: Analyze-Dynamic"
''9129. "anzarea: Analyze-Area Calculations"
''9130. "eamod: Entity Attributes (Apply)"
''9131. "anzscurv: Analyze-Surfaces-Curvature"
''9132. "anznorm: Analyze-Surfaces-Test Normals"
''9133. "anzbase: Analyze-Surfaces-Base Surfs"
''9134. "delchain: Delete-Chain"
''9135. "deldup: Delete-Duplicate"
''9136. "delonly: Delete-Only"
''9137. "delall: Delete-All"
''9138. "delgrp: Delete-Group"
''9139. "delreslt: Delete-Result"
''9140. "crptperp: Create-Point-Perpendicular"
''9141. "crptcirc: Create-Point-Small Circles
''9142. "undelete: Delete-Undelete"
''9143. " "
''9144. "filemrg: File-Merge"
''9145. "filesave: File-Save"
''9146. "fileget: File-Get"
''9147. "hardcopy: File-Hardcopy"
''9148. "browse: File-Browse"
''9149. "communic: File-Communications"
''9150. "convert: File-Convert"
''9151. "ascii: File-Convert-ASCII"
''9152. "cadl: File-Convert-CADL"
''9153. "dxf: File-Convert-DXF (pre-V9)"
''9154. "iges: File-Convert-IGES"
''9155. "vda: File-Convert-VDA"
''9156. " "
''9157. "renumber: File-Renumber"
''9158. " "
''9159. "shell: File-DOS Shell"
''9160. "levelrep: Levels-Report"
''9161. "trim: Modify-Trim"
''9162. "trim1: Modify-Trim-1 Entity"
''9163. "trim2: Modify-Trim-2 Entities"
''9164. "trim3: Modify-Trim-3 Entities"
''9165. "trim2pt: Modify-Trim-To Point"
''9166. "trimmany: Modify-Trim-Many"
''9167. "closearc: Modify-Trim-Close Arc"
''9168. "divide: Modify-Trim-Divide"
''9169. "break: Modify-Break"
''9170. "brkarcs: Modify-Break-Arcs"
''9171. "brkmany: Modify-Break-Many Pieces"
''9172. "brk2pcs: Modify-Break-2 Pieces"
''9173. "brklen: Modify-Break-At Length"
''9174. "brknote: Modify-Break-Draft/Line"
''9175. "brkhatch: Modify-Break-Hatch/Line"
''9176. "brkcdata: Modify-Break-Cdata/Line"
''9177. "join: Modify-Join"
''9178. "modnorm: Modify-Normal"
''9179. "modnbs: Modify-Cpts NBS"
''9180. "x2nbs: Modify-X to NBS"
''9181. "extend: Modify-Extend"
''9182. "drag: Modify-Drag"
''9183. "scrnctr: Screen-Center"
''9184. "initscrn: File-New"
''9185. "combvws: Screen-Combine Views"
''9186. "plot: Screen-Plot"
''9187. "xfmmir: Xform-Mirror"
''9188. "xfmrot: Xform-Rotate"
''9189. "xfmscale: Xform-Scale"
''9190. "xfmsqsh: Xform-Squash"
''9191. "xfmtrans: Xform-Translate"
''9192. "xfmofst: Xform-Offset"
''9193. "xfmoctr: Xform-Offset Contour"
''9194. "tpmenu: Toolpaths"
''9195. "contour: Toolpaths-Contour"
''9196. "drill: Toolpaths-Drill"
''9197. "pocket: Toolpaths-Pocket"
''9198. "ncflow: Toolpaths-Flowline"
''9199. "ncmsurf: Toolpaths-Surface"
''9200. "ncproj: Toolpaths-Project"
''9201. "nctrim: Toolpaths-Trim"
''9203. "nccoons: Toolpaths-Coons"
''9204. "ncruled: Toolpaths-Ruled"
''9205. "ncswept: Toolpaths-Swept"
''9206. "ncrev: Toolpaths-Revolution"
''9208. "manent: Toolpaths-Manual Entry"
''9209. "ncpoint: Toolpaths-Point"
''9215. "filter: NC Utils-Filter"
''9216. "pstmenu: NC Utils-Post"
''9217. "pstchg: NC Utils-Post-Change"
''9218. "pstrun: NC Utils-Post-Run"
''9219. "pstrev: NC Utils-Post-Reverse"
''9220. "deftls: NC Utils-Define Tools"
''9221. "setsht: NC Utils-Setup Sheet"
''9223. "exefunc: Execute Function"
''9224. "prompt: Prompt Visible (Toggle)"
''9225. "gvtop: Gview-Top"
''9226. "gvfront: Gview-Front"
''9227. "gvside: Gview-Side"
''9228. "gviso: Gview-Isometric"
''9229. "gvnum: Gview-Number"
''9230. "gvlast: Gview-Last"
''9231. "gvent: Gview-Entity"
''9232. "gvrot: Gview-Rotate"
''9233. "gvmouse: Gview-Mouse"
''9234. "gvdymic: Gview-Dynamic"
''9235. "cporgn: Cplane-Origin"
''9236. "cp3d: Cplane-3D"
''9237. "cptop: Cplane-Top"
''9238. "cpfrnt: Cplane-Front"
''9239. "cpside: Cplane-Side"
''9240. "cpnum: Cplane-Number"
''9241. "cplast: Cplane-Last"
''9242. "cpent: Cplane-Entity"
''9243. "cprot: Cplane-Rotate"
''9244. "cpnorm: Cplane-Normal"
''9245. "cpmouse: Cplane-Mouse"
''9246. "cppxz: Cplane-XZ(+)"
''9247. "cpnxz: Cplane-XZ(-)"
''9248. "cppdz: Cplane-DZ(+)"
''9249. "cpndz: Cplane-DZ(-)"
''9250. "eamgr: Entity Attributes Manager"
''9251. "extsrf: Modify-Surface-Extend"
''9252. "clipbrd: Screen-To Clipboard"
''9253. "regen: Screen-Regenerate"
''9254. "slccrvs: Create-Point-Slice"
''9255. "slcsrfs: Create-Curve-Slice"
''9256. "catan2: Create-Arc-Tangent-2 Entities"
''9257. "circmill: Toolpaths-Circle Mill"
''9258. "sprlhlx: Create-Spiral/Helix
''9259. "crptgrid: Create-Point-Grid"
''9260. "crptbcir: Create-Point-Bolt Circle"
''9261. "fillet: Create-Fillet-2 Entities"
''9262. "filletc: Create-Fillet-Chain"
''9263. "mcplay: Macro-Playback (Toggle)"
''9264. "mcrec: Macro-Record (Toggle)"
''9265. "mcstop: Macro-Pause (Toggle)"
''9266. "anzsnrms: Analyze-Surfaces-Set Normals"
''9267. "crpolyg: Create-Polygon"
''9268. "clprppt: Create-Line-Perpendicular-Pt"
''9269. "clprpar: Create-Line-Perpendicular-Arc"
''9270. "clplldst: Create-Line-Parallel-Dist/Side"
''9271. "clpllpt: Create-Line-Parallel-Point"
''9272. "clpllar: Create-Line-Parallel-Arc"
''9273. "clbisect: Create-Line-Bisect"
''9274. "catancl: Create-Arc-Tangent-Center Line"
''9275. "undelent: Delete-Undelete-Single"
''9276. "hide: Hide"
''9277. "gridprms: Screen-Grid"
''9278. "catadyn: Create-Arc-Tangent-Dynamic"
''9279. "ramsaver: File-RAMsaver"
''9280. "chgattrs: Screen-Change Attributes"
''9281. "jobsetup: Toolpaths-Job Setup"
''9282. "oplist: Toolpaths-Operations Manager"
''9283. "namview: WCS / View Manager"
''9284. "cnv2arcs: Modify-Convert to Arcs"
''9285. "ccedges: Create-Curve-All Edges"
''9286. "studio: Screen-Surf Disp-Studio"
''9287. "clclose: Create-Line-Closest"
''9288. "autocur: AutoCursor (Toggle)"
''9289. "shadetog: Fulltime Shading (Toggle)"
''9290. "quitop: Delete-Last Operation"
''9291. "editlast: Modify-Last Operation"
''9292. "grnamed: Gview-Named"
''9293. "cpnamed: Cplane-Named"
''9294. "tpnamed: Tplane-Named"
''9295. "multiax: Toolpaths-MultiAxis"
''9296. "curve5ax: Toolpaths-Curve 5 Axis"
''9297. "drill5ax: Toolpaths-Drill 5 Axis"
''9298. "swarf5ax: Toolpaths-Swarf 5 Axis Floor"
''9299. "flow5ax: Toolpaths-Flow 5 Axis"
''9300. "rotary4x: Toolpaths-Rotary 4 Axis"
''9301. "grnormal: Gview-Normal"
''9302. "greqcpln: Gview-Equals Cplane"
''9303. "greqtpln: Gview-Equals Tplane"
''9304. "autodesk: File-Convert-AutoDesk"
''9306. "dfregen: Draft-Regenerate-All"
''9307. "dfrgsel: Draft-Regenerate-Selected"
''9308. "dfrgaut: Draft-Regenerate-Auto (Toggle)"
''9309. "crdmhz: Create-Dimension-Horizontal"
''9310. "crdmvt: Create-Dimension-Vertical"
''9311. "crdmpll: Create-Dimension-Parallel"
''9312. "crdman: Create-Dimension-Angular"
''9313. "crdmdia: Create-Dimension-Circular"
''9315. "crdmbsln: Create-Dimension-Baseline"
''9316. "crdmchn: Create-Dimension-Chained"
''9317. "crdmord: Create-Dimension-Ordinate"
''9318. "crdmpt: Create-Dimension-Point"
''9319. "dfvdate: Draft-Regenerate-Validate"
''9320. "sldhist: Create-Solids-History"
''9321. "sldmake: Create-Solids"
''9322. "hidemore: Hide-Hide More"
''9323. "unhdsome: Hide-Unhide Some"
''9324. "makebbox: Create-Bounding Box"
''9325. "setmain: Levels-Main (from entity)"
''9326. "gvbottom: Gview-Bottom"
''9327. "gvback: Gview-Back"
''9328. "gvleft: Gview-Left"
''9350. "gvdypan: Gview-Dynamic Pan"
''9351. "gvdyzum: Gview-Dynamic Zoom"
''9352. "attribs: Attributes"
''9353. "anznumbr: Analyze-Number"
''9354. "anzchain: Analyze-Chain"
''9355. "anzckmdl: Analyze-Surfaces-Check Model"
''9356. "anzsmall: Analyze-Surfaces-Small Surfs"
''9357. "anzcksld: Analyze-Surfaces-Check Solid"
''9358. "xfmstrch: Xform-Stretch"
''9359. "xfmroll: Xform-Roll"
''9360. "sldext: Solids-Extrude"
''9361. "sldrev: Solids-Revolve"
''9362. "sldsweep: Solids-Sweep"
''9363. "sldloft: Solids-Loft"
''9364. "sldflt: Solids-Fillet"
''9365. "sldchmfr: Solids-Chamfer"
''9366. "sldshell: Solids-Shell"
''9367. "sldbool: Solids-Boolean"
''9368. "sldprim: Solids-Primitive"
''9369. "slddrfac: Solids-Draft face"
''9370. "sldtrim: Solids-Trim"
''9371. "sldlayot: Solids-Layout"
''9372. "sldfeat: Solids-Find features"
''9373. "sldthick: Solids-Thicken"
''9374. "sldrmfac: Solids-Remove faces"
Const DEF_DOS = "shell"
Const DEF_CREATE_REC_2_POINTS = "rec2pts"
Const DEF_ZOOM_ALL = "fit"
'///////////////// My Global Variables //////////
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Call RunMastercamCommand(DEF_CREATE_REC_2_POINTS)
Call RunMastercamCommand(DEF_ZOOM_ALL)
End Sub
OK, I hope this doesn't sound to stupid. You can use VBS to access all of these commands but how do you get the data entered into the command.
Let me give an example of what I am trying to do. I want to Create-Drafting-Note. How do I automatically get it to enter the data into the form and select some of the functions in the form? Is this even possible? Or does it have to be done manually?
  • 1 year later...
I found this out while writing a Python script for something totally unrelated:
'// Author: Chris Bellini [email protected]
'// Copyright © 2005 In-House Solutions Inc.
'// Date: 05/31/2005 4:47 PM
'// File Name: mcam_clipboard.vbs
'// Description: an example of copying text to-and-from the Windows clipboard
'// from Mastercam
'// Comments:
'// - 05/31/2005 <cvb>: initial version
'// This library is free software; you can redistribute it and/or
'// modify it under the terms of the GNU Lesser General Public
'// License as published by the Free Software Foundation; either
'// version 2.1 of the License, or (at your option) any later version.
'// This library is distributed in the hope that it will be useful,
'// but WITHOUT ANY WARRANTY; without even the implied warranty of
'// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
'// Lesser General Public License for more details.
'// You should have received a copy of the GNU Lesser General Public
'// License along with this library; if not, write to the Free Software
'// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
'// MA 02110-1301, USA
' call the main subroutine
Call Main()
' Purpose: The main subroutine
Sub Main()
Dim strCurrClipboard ' text we'll retrieve from the clipboard
Dim strTestString : strTestString = "Copied from Mastercam VBS"
' copy some text to the Windows clipboard
Call SendTextToClipboard(strTestString)
' retrieve what's currently copied to the Windows clipboard
strCurrClipboard = GetTextFromClipboard()
' let's see if it actually worked (it damn-well better have)
If (Len(strCurrClipboard) < 1) Then
ShowString "Error: Unable to retrieve text from Windows clipboard."
Else
ShowString strCurrClipboard
End If
End Sub
' Purpose: Send text to Windows clipboard
' I: text to be "copied" to the Windows clipboard
' O: (none)
Sub SendTextToClipboard(strCopiedText)
Dim objIE ' IE object
Dim objData ' object to hold clipbaord data
' Create an Internet Explorer object
Set objIE= CreateObject("InternetExplorer.Application")
' Stall IE and allow it to be our yellow-brick road to the clipboard.
' Quit IE once the data has been copied.
With objIE
Do
.Navigate "about:clipdata"
Loop While .busy
Set objData = .Document.ParentWindow.ClipboardData
End With
objData.SetData "text", strCopiedText
objIE.Quit
' cleanup
Set objIE = Nothing
Set objData = Nothing
End Sub
' Purpose: Retrieve text data currently on Windows clipboard
' I: (none)
' O: current Windows clipboard text
Function GetTextFromClipboard()
Dim objHTML ' MS HTML object
' Create an MS HTML object
Set objHTML = CreateObject("htmlfile")
' Retrieve the data from the clipbaord and return it.
GetTextFromClipboard = objHTML.ParentWindow.ClipboardData.GetData("text")
' cleanup
Set objHTML = Nothing
End Function
However, it will only copy text. The SetData() method can only take text or a URL (perhaps a URL to an image would work...never tried). Otherwise, you could try AutoIT's DLL that you can use from VBS; I've only heard about it...never used it.
HTH.
