VbScript Excel McPt.
Sorry 1st post was incomplete
I have used vb6 in athe past and now have .net.
My question is?? Is there anywhere i can fine examples of MasterCam's vbscript. I'm having trouble with the correct format i need to use when coding.
I am trying to get all points on a drawing and list there "x" and "Y" coordinate in Excel. These will be points on a spline every 1". Thes poins are needed for Inspection. Customer wants Variance Listed in Excel. I could manually type them in, but There are about 1216 points.
Here's a quick sample I whipped up in no time. The script will prompt for an XLS file that already exists:
'// Author: Chris Bellini [email protected]
'// Date: 26/08/2004 10:54 AM
'// File Name: PointsToExcel.vbs
'// Description: For bgm
'// Comments:
'//////////////////// My Constants /////////////////////
'///////////////// My Global Variables /////////////////
' call the main sub
Call Main()
' Purpose: The main sub, our script's entry point
Sub Main()
Const DEF_X_COLUMN = "A" ' X column name
Const DEF_Y_COLUMN = "B" ' Y column name
Dim bSuccf ' success flag
Dim strXLSPath ' path to the XLS file
Dim objCurrPoint ' current point
Dim iRow : iRow = 1 ' row
' prompt for XLS file
bSuccf = AskForFileName("*.xls", "r", strXLSPath)
' did the user cancel
If bSuccf = False Then
ShowString "No file selected. Exiting..."
Exit Sub
Else
' try to open the file
bSuccf = OpenExcelFile(strXLSPath)
If (bSuccf = False) Then ' couldn't open the file
ShowString "An existing Excel file was not selected. Exiting..."
Exit Sub
End If
End If
' look for alive points
bSuccf = StartDBSearch(mc_alive, mc_pointtype)
If (bSuccf = False) Then Exit Sub
' loop through the database
Do
' create a point object for the current point
Set objCurrPoint = New McPt
If (GetPointData(GetEntityEptr, objCurrPoint)) Then
' store X
Call WriteExcelValue(DEF_X_COLUMN & iRow, objCurrPoint.X)
' store Y
Call WriteExcelValue(DEF_Y_COLUMN & iRow, objCurrPoint.Y)
End If
' get the next point
bSuccf = NextDBSearch()
' increment the row counter
iRow = iRow + 1
Loop While (bSuccf = True)
' close the file
CloseExcelFile()
' cleanup
Set objCurrPoint = Nothing
End Sub
Well I am trying to make a set-up sheet using a Word Vb script that one of the members developed. I need ot make it output to Excel not word. I have got the Excel Book and getting all the information for the Excel output so think I have my answer ot that part. The problem is that the script is using arrays for seperation of tool data information. The script only reads the whole program and not reading it on a opertaion group way. I looked through all the Mc commands and do not see a sort through operations groups way so trying to make my set-up sheet output the tools based on a operation group per tools used then output all the data I want to the Excel all seperated from the Mastercam file and save me the time from having to make each set-up sheet for all the information I need.
Hope that is clear enough.
Are you refering to this thread and that thread?
If so, then it wouldn't be a problem to get the operation names from the returned operation IDs. Just use the GetOperationNameFromID() function. Keep an array of operation names. Then the array index would correspond to the tools of each operation. Alternatively, it may be better to create a Class of operations and make tool data and operation name part of the member variable. Use you can then store it all in an array of objects of your class.
Yes the Very Threads and John was the source of my attempt. I still not up to speed on classes and get the understanding of what you are saying just have ot get all the excel stuff down while trying to get the Mastercam stuff down at the same time. We have a pretty extensive set-up sheet at my new place and be very cool to get this VB script worked out to make my and others life a whole lot easier. I am going to keep pluging awya at it and see here I get. I appercate your thought Bulliness and will see where I get in the coming weeks.
Well, if you want to continue from where the previous script left off, you could create a new array to contain the name of the operation:
Dim arrOpNames()       ' array of operation names
Then add to the code from the other thread to load operation names into an array. For each index (0, 1, 2...n-2, n-1) you can access operation info in all of the arrays per operation. So 0 is for the operation name and tool data of the first op, 1 is for the operation name and tool data of the second op, etc. It's not fancy, but it should do the trick.
' get the number of operations
nCount = GetOperationCount("")
' resize the arrays
ReDim Preserve arrOpNames(nCount) ' <-- Ron, this is new
ReDim Preserve arrToolNumber(nCount)
ReDim Preserve arrToolComment(nCount)
ReDim Preserve arrToolDiameter(nCount)
ReDim Preserve arrToolFluteLength(nCount)
ReDim Preserve arrToolLength(nCount)
' init the index
nIdx = 0
' get the id of the first operation
nOpNum = GetFirstOperationID("")
' loop as long as there are operations to get
Do
' get the tool number using the current operation
nToolNum = GetToolNumberFromOperationID("", nOpNum)
' copy tool data into our individual arrays
arrOpNames(nIdx) = GetOperationNameFromID("", nOpNum) <-- Ron, this is new
arrToolNumber(nIdx) = nToolNum
arrToolComment(nIdx) = GetToolComment(nToolNum)
arrToolDiameter(nIdx) = GetToolDiameter(nToolNum)
arrToolFluteLength(nIdx) = GetToolFluteLength(nToolNum)
arrToolLength(nIdx) = GetToolLength(nToolNum)
' increment the index
nIdx = nIdx + 1
' get the next operations
nOpNum = GetNextOperationID()
Loop While(nOpNum <> -1)
Then for testing purposes, you can see what you have with this:
' let's see what we have up in here so print out the info
Dim nX
For nX = 0 To (nCount - 1)
ShowString "Operation Name: " & arrOpNames(nX) & vbLf & _
"Tool Number: " & arrToolNumber(nX) & vbLf & _
"Tool Comment " & arrToolComment(nX) & vbLf & _
"Tool Diameter " & arrToolDiameter(nX) & vbLf & _
"Flute Length: " & arrToolFluteLength(nX) & vbLf & _
"Tool Length: " & arrToolLength(nX)
Next
