For Mick MCX VB script question
Thanks for the reply in an earlier post. I am having a problem with a script that you wrote for me a while back now that I am using V10. The script will run, but when I am promped for an entity I cannot select one. Not to be too forward but if you could look at the code and mabey tell me what to change I would appreciate it. Here is the code:
'// Author: Mick George [email protected]
'// Date: 05/11/2003 04:42 PM
'// File Name: Copy Entities to Level.vbs
'// Description:
'// Comments: Select an entity to get its level, prompt for a new level and copy all
'// entities from current level to new level.
Const DEF_GIVE_ME_EVERYTHING = -1
Public Const DEF_PANEL = "MAND FACE"
Public Const DEF_PANELA = "MAND BACK"
Public Const DEF_PANELB = "CAP FACE"
Public Const DEF_PANELC = "CAP BACK"
Public Const DEF_PANELD = "BACKER FACE"
Public Const DEF_PANELE = "FEEDER BACK"
Public Const DEF_LEVEL_NUMBER = 10
Public Const DEF_LEVEL_NUMBERA = 11
Public Const DEF_LEVEL_NUMBERB = 12
Public Const DEF_LEVEL_NUMBERC = 13
Public Const DEF_LEVEL_NUMBERD = 14
Public Const DEF_LEVEL_NUMBERE = 9
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Dim CArc, CLine, CPoint, CRect
Dim CArcCopy, CLineCopy, CPointCopy, CRectCopy
Dim intOriginalLevel, intNewLevel
Dim bRet
Dim intColor,intNewColor
Dim intlevel
Call SetLevelName(DEF_LEVEL_NUMBER, DEF_PANEL)
Call SetLevelName(DEF_LEVEL_NUMBERA, DEF_PANELA)
Call SetLevelName(DEF_LEVEL_NUMBERB, DEF_PANELB)
Call SetLevelName(DEF_LEVEL_NUMBERC, DEF_PANELC)
Call SetLevelName(DEF_LEVEL_NUMBERD, DEF_PANELD)
Call SetLevelName(DEF_LEVEL_NUMBERE, DEF_PANELE)
If Not IsDrawing Then ShowString "We need a drawing": Exit Sub
If AskForEntity("**** SELECT AN ENTITY ****", mc_arctype + mc_linetype + mc_recttype + mc_pointtype) Then
' -- Store this entities level for eval
intOriginalLevel = GetEntityLevel
intnewlevel = 10
If (intNewLevel) Then
' -- Loop through all entities on original level and
' -- make a copy of it on the new level.
bRet = StartDBSearch(mc_alive, DEF_GIVE_ME_EVERYTHING)
Do
Select Case GetEntityType
Case mc_arctype
' -- Is this arc on the same level?
If intOriginalLevel = GetEntityLevel Then
Set CArc = New McAr
Set CArcCopy = New McAr
' -- Get this arc
If GetArcData(GetEntityEptr, CARC) Then
' -- Copy properties to our new arc
With CArcCopy
.X = CArc.X
.Y = CArc.Y
.Z = CArc.Z
.R = CArc.R
.SA = CArc.SA
.SW = CArc.SW
.VIEW = mcVIEW_TOP ' -- Bug Alert!! hard code for now fix pending
End With
' -- Create our new arc on our new level
intColor = GetEntityColor()
If CreateArc(CArcCopy, intColor, intNewLevel) = mcENTITY_INVALID Then
' -- Call the police, we have a situation...
ShowString "Could not create copy of Arc"
Exit Sub
End If
Else
' -- OMG
ShowString "Could not get current Arc"
Exit Sub
End If
End If
Case mc_linetype
' -- Is this line on the same level?
Set CLine = New McLn
Set CLineCopy = New McLn
' -- Get this line
If GetLineData(GetEntityEptr, CLine) Then
' -- Copy properties to our new line
With CLineCopy
.X1 = CLine.X1
.Y1 = CLine.Y1
.Z1 = CLine.Z1
.X2 = CLine.X2
.Y2 = CLine.Y2
.Z2 = CLine.Z2
End With
If CreateLine(CLineCopy, intColor, intNewLevel) = mcENTITY_INVALID Then
ShowString "Could not create copy of Line"
Exit Sub
End If
Else
' -- OMG
ShowString "Could not get current Line"
Exit Sub
End If
End If
Case mc_pointtype
' -- Is this point on the same level?
Set CPoint = New McLn
Set CPointCopy = New McLn
' -- Get this point
If GetPointData(GetEntityEptr, CPoint) Then
' -- Copy properties to our new point
With CPointCopy
.X = CPoint.X
.Y = CPoint.Y
.Z = CPoint.Z
End With
If CreatePoint(CPointCopy, intColor, intNewLevel) = mcENTITY_INVALID Then
ShowString "Could not create copy of Point"
Exit Sub
End If
Else
' -- OMG
ShowString "Could not get current Point"
Exit Sub
End If
End If
Case mc_recttype
' -- Is this rectangle on the same level?
Set CRect = New McLn
Set CRectCopy = New McLn
' -- Get this rect
If GetRectangleData(GetEntityEptr, CRect) Then
' -- Copy properties to our new rect
With CRectCopy
.X1 = CRect.X1
.Y1 = CRect.Y1
.X2 = CRect.X2
.Y2 = CRect.Y2
.Z = CRect.Z
End With
If CreateRectangle(CRectCopy, intColor, intNewLevel) = mcENTITY_INVALID Then
ShowString "Could not create copy of Rectangle"
Exit Sub
End If
Else
' -- OMG
ShowString "Could not get current Rectangle"
Exit Sub
End If
End If
End Select
bRet = NextDBSearch
Loop While bRet
Call UnselectAll
Call RepaintScreen(True)
Else
' -- Bail...
Exit Sub
End If
Else
End If
End Sub
' Function Declaration
Function IsDrawing()
Dim Ret
Ret = StartDBSearch(mc_alive, -1)
UnselectAll
IsDrawing = Ret
End Function
I did revise it a little to get my colors to stay the same. I am not sure if I got all of it as I copied it several times to copy to several levels. Any help would be great! Thanks
It appears that there is something wrong with the AskForEntity() function. I tested it with a simple script:
Call Main()
Sub Main()
ShowString "Start"
If AskForEntity("Select an entity", mc_arctype + mc_linetype + _
ShowString "Yay, we picked something"
Else
ShowString "Something bad happened."
End If
ShowString "End"
End Sub
It never allows you to acually select an entity like you mentioned. Strangely enough, I looked in nethook.dll and there aren't any entity types or methods to allow the user to select an entity other than AskForPoint() eek.gif
Hello guys,
I wanted to ask you if you a method that I could use to hide the work coordinates from displaying on the screen of any given job?
I use Fanuc 16I and I know how to hide program 8000-9000 series, but I was thinking if is there any way to also "block" the option of the operators having the chance of macking the wrong adjustment that could cause many bad parts.
Maybe ther is a parameter that will allow you to do something like that. I've tried taking the keys out of the control but then is always missing when you need them.
your advices will be greatly appreciated.
Benito
www.Matech.net
  • 2 months later...
