VBScript RunMasterCamCommand ?
confused.gif Is there an easy way to script responses to recurring menu prompts.
For example graphics view only arcs or mask arcs of a color or level. No logical decisions involved just a scripted response to imitate a mouse click or keyboard button.
Thanks in advance Charlie
There is no such thing as a five minute job. :
Do a search Matt aka Rekd has covered this well. I know you have to define some of the 9000 constants as they are called. I was doing a fit screen to clipboard script and he helped me by showing me that I had to define the clipboard at the beginning of the script.
But incase you can not find it here is the 9000 list from the Mill9.TXT file This is from MR105:
(function name: description [maximum length: 8:30])
9000. "12345678: 123456789012345678901234567890"
9001. "zoom: Screen-Zoom" _
9002. "unzoom: Screen-Unzoom" _
9003. "repaint: Screen-Repaint" _
9004. "analyze: Analyze" _
9005. "delete: Delete" _
9006. "file: File" _
9007. "modify: Modify" _
9008. "create: Create" _
9009. "dispinfo: Screen-Display info" _
9010. "help: Help" _
9011. "fit: Screen-Fit" _
9012. "unzoom8: Screen-Unzoom by 0.8" _
9013. "curpos: Cursor Tracking (Toggle)" _
9014. "delwndw: Delete-Window" _
9015. "editfile: File-Edit" _
9016. "blank: Screen-Blank" _
9017. "config: Screen-Configure" _
9018. "drwaxes: Screen-Draw axes" _
9019. "rundll: Execute C-Hook" _
9020. "draftpm: Draft-Globals" _
9021. "font: Menu Font" _
9022. "" _
9023. "mmalloc: List Memory" _
9024. "mfile: List Files" _
9025. "undo: Undo" _
9026. "surfdisp: Screen-Surf Disp" _
9027. "drawnc: Screen-Draw Toolpath" _
9028. "vwports: Screen-Viewports" _
9029. "version: Version" _
9030. "xform: Xform" _
9031. "autosave: File-AutoSave" _
9032. "group: Groups" _
9033. "chgcolrs: Screen-Change Colors" _
9034. "chglevs: Screen-Change Levels" _
9035. "autocl: Automatic Centerlines" _
9036. "color: Main Color" _
9037. "level: Levels-Main" _
9038. "mask: Levels-Mask" _
9039. "tplane: Tplane" _
9040. "cplane: Cplane" _
9041. "gview: Gview" _
9042. "zdepth: Cplane-Depth" _
9043. "levdlg: Levels-Dialog" _
9044. "vislev: Levels-Visible" _
9045. "toolbar: Toolbar Visible (Toggle)" _
9046. "dbstats: Screen-Statistics" _
9047. "endpts: Screen-Endpoints" _
9048. "clrcolrs: Screen-Clear Colors" _
9049. "shade: Screen-Surf Disp-Shading" _
9050. "crpoint: Create-Point" _
9051. "crptpos: Create-Point-Position" _
9052. "ptalong: Create-Point-Along Entity" _
9053. "nodepts: Create-Point-Node Points" _
9054. "ctrlpts: Create-Point-Cpts NURBS" _
9055. "ptdynmic: Create-Point-Dynamic" _
9056. "crptlen: Create-Point-Length" _
9057. "ptsrfprj: Create-Point-Surface Project" _
9058. "crline: Create-Line" _
9059. "clhorz: Create-Line-Horizontal" _
9060. "clvert: Create-Line-Vertical" _
9061. "clepts: Create-Line-Endpoints" _
9062. "clmulti: Create-Line-Multi" _
9063. "clpolar: Create-Line-Polar" _
9064. "cltan: Create-Line-Tangent" _
9065. "cltanang: Create-Line-Tangent-Angle" _
9066. "cltan2a: Create-Line-Tangent-2 Arcs" _
9067. "cltanpt: Create-Line-Tangent-Point" _
9068. "clperp: Create-Line-Perpendicular" _
9069. "clparal: Create-Line-Parallel" _
9070. "crarc: Create-Arc" _
9071. "capolar: Create-Arc-Polar" _
9072. "cactrpt: Create-Arc-Polar-Center Point" _
9073. "casktch: Create-Arc-Polar-Sketch" _
9074. "castart: Create-Arc-Polar-Start Point" _
9075. "caend: Create-Arc-Polar-End Point" _
9076. "caepts: Create-Arc-Endpoints" _
9077. "ca3pts: Create-Arc-3 points" _
9078. "catan: Create-Arc-Tangent" _
9079. "catan1: Create-Arc-Tangent-1 Entity" _
9080. "catan3: Create-Arc-Tangent-3 Entities" _
9081. "catanpt: Create-Arc-Tangent-Point" _
9082. "ca2ptcir: Create-Circle-2 Points" _
9083. "ca3ptcir: Create-Circle-3 Points" _
9084. "captrad: Create-Circle-Point/Radius" _
9085. "captdia: Create-Circle-Point/Diameter" _
9086. "captedge: Create-Circle-Point/Edge" _
9087. "crfillet: Create-Fillet" _
9088. "crspline: Create-Spline" _
9089. "crcurve: Create-Curve" _
9090. "ellipse: Create-Ellipse" _
9091. "ccconst: Create-Curve-Const Parameter" _
9092. "ccedge: Create-Curve-One Edge" _
9093. "ccinter: Create-Curve-Intersect" _
9094. "ccpatch: Create-Curve-Patch Boundaries" _
9095. "ccflow: Create-Curve-Flowline" _
9096. "ccproj: Create-Curve-Project" _
9097. "ccdynmic: Create-Curve-Dynamic" _
9098. "ccpart: Create-Curve-Parting Line" _
9099. "crsurf: Create-Surface" _
9100. "csloft: Create-Surface-Loft" _
9101. "cscoons: Create-Surface-Coons" _
9102. "csruled: Create-Surface-Ruled" _
9103. "csrev: Create-Surface-Revolved" _
9104. "csswept: Create-Surface-Swept" _
9105. "csdraft: Create-Surface-Draft" _
9106. "csfillet: Create-Surface-Fillet" _
9107. "csofst: Create-Surface-Offset" _
9108. "cstrim: Create-Surface-Trim" _
9109. "csblend: Create-Surface-2 Surface Blend"_
9110. "crrec: Create-Rectangle" _
9111. "rec1pt: Create-Rectangle-1 Point" _
9112. "rec2pts: Create-Rectangle-2 Points" _
9113. "crdraft: Create-Drafting" _
9114. "cddim: Create-Drafting-Dimension" _
9115. "crnote: Create-Drafting-Note" _
9116. "crlabel: Create-Drafting-Label" _
9117. "crleader: Create-Drafting-Leader" _
9118. "crwit: Create-Drafting-Witness Line" _
9119. "eddraft: Create-Drafting-Multi edit" _
9120. "crhatch: Create-Drafting-Hatch" _
9121. "chamfer: Create-Chamfer" _
9122. "crlets: Create-Letters" _
9123. "pattern: Create-Pattern" _
9124. "anzpt: Analyze-Point" _
9125. "anzonly: Analyze-Only" _
9126. "anzbpts: Analyze-Between points" _
9127. "anzang: Analyze-Angle" _
9128. "anzdynm: Analyze-Dynamic" _
9129. "anzarea: Analyze-Area Calculations" _
9130. "eamod: Entity Attributes (Apply)" _
9131. "anzscurv: Analyze-Surfaces-Curvature" _
9132. "anznorm: Analyze-Surfaces-Test Normals" _
9133. "anzbase: Analyze-Surfaces-Base Surfs" _
9134. "delchain: Delete-Chain" _
9135. "deldup: Delete-Duplicate" _
9136. "delonly: Delete-Only" _
9137. "delall: Delete-All" _
9138. "delgrp: Delete-Group" _
9139. "delreslt: Delete-Result" _
9140. "crptperp: Create-Point-Perpendicular" _
9141. "crptcirc: Create-Point-Small Circles _
9142. "undelete: Delete-Undelete" _
9143. " " _
9144. "filemrg: File-Merge" _
9145. "filesave: File-Save" _
9146. "fileget: File-Get" _
9147. "hardcopy: File-Hardcopy" _
9148. "browse: File-Browse" _
9149. "communic: File-Communications" _
9150. "convert: File-Convert" _
9151. "ascii: File-Convert-ASCII" _
9152. "cadl: File-Convert-CADL" _
9153. "dxf: File-Convert-DXF (pre-V9)" _
9154. "iges: File-Convert-IGES" _
9155. "vda: File-Convert-VDA" _
9156. " " _
9157. "renumber: File-Renumber" _
9158. " " _
9159. "shell: File-DOS Shell" _
9160. "levelrep: Levels-Report" _
9161. "trim: Modify-Trim" _
9162. "trim1: Modify-Trim-1 Entity" _
9163. "trim2: Modify-Trim-2 Entities" _
9164. "trim3: Modify-Trim-3 Entities" _
9165. "trim2pt: Modify-Trim-To Point" _
9166. "trimmany: Modify-Trim-Many" _
9167. "closearc: Modify-Trim-Close Arc" _
9168. "divide: Modify-Trim-Divide" _
9169. "break: Modify-Break" _
9170. "brkarcs: Modify-Break-Arcs" _
9171. "brkmany: Modify-Break-Many Pieces" _
9172. "brk2pcs: Modify-Break-2 Pieces" _
9173. "brklen: Modify-Break-At Length" _
9174. "brknote: Modify-Break-Draft/Line" _
9175. "brkhatch: Modify-Break-Hatch/Line" _
9176. "brkcdata: Modify-Break-Cdata/Line" _
9177. "join: Modify-Join" _
9178. "modnorm: Modify-Normal" _
9179. "modnbs: Modify-Cpts NBS" _
9180. "x2nbs: Modify-X to NBS" _
9181. "extend: Modify-Extend" _
9182. "drag: Modify-Drag" _
9183. "scrnctr: Screen-Center" _
9184. "initscrn: File-New" _
9185. "combvws: Screen-Combine Views" _
9186. "plot: Screen-Plot" _
9187. "xfmmir: Xform-Mirror" _
9188. "xfmrot: Xform-Rotate" _
9189. "xfmscale: Xform-Scale" _
9190. "xfmsqsh: Xform-Squash" _
9191. "xfmtrans: Xform-Translate" _
9192. "xfmofst: Xform-Offset" _
9193. "xfmoctr: Xform-Offset Contour" _
9194. "tpmenu: Toolpaths" _
9195. "contour: Toolpaths-Contour" _
9196. "drill: Toolpaths-Drill" _
9197. "pocket: Toolpaths-Pocket" _
9198. "ncflow: Toolpaths-Flowline" _
9199. "ncmsurf: Toolpaths-Surface" _
9200. "ncproj: Toolpaths-Project" _
9201. "nctrim: Toolpaths-Trim" _
9202. "***** not used *****" _
9203. "nccoons: Toolpaths-Coons" _
9204. "ncruled: Toolpaths-Ruled" _
9205. "ncswept: Toolpaths-Swept" _
9206. "ncrev: Toolpaths-Revolution" _
9207. "***** not used *****" _
9208. "manent: Toolpaths-Manual Entry" _
9209. "ncpoint: Toolpaths-Point" _
9210. "***** wire *****" _
9211. "ncutils: NC Utils" _
9212. "actour: Analyze-Contour" _
9213. "backplot: NC Utils-Backplot" _
9214. "***** not used *****" _
9215. "filter: NC Utils-Filter" _
9216. "pstmenu: NC Utils-Post" _
9217. "pstchg: NC Utils-Post-Change" _
9218. "pstrun: NC Utils-Post-Run" _
9219. "pstrev: NC Utils-Post-Reverse" _
9220. "deftls: NC Utils-Define Tools" _
9221. "setsht: NC Utils-Setup Sheet" _
9222. "***** not used *****" _
9223. "exefunc: Execute Function" _
9224. "prompt: Prompt Visible (Toggle)" _
9225. "gvtop: Gview-Top" _
9226. "gvfront: Gview-Front" _
9227. "gvside: Gview-Side" _
9228. "gviso: Gview-Isometric" _
9229. "gvnum: Gview-Number" _
9230. "gvlast: Gview-Last" _
9231. "gvent: Gview-Entity" _
9232. "gvrot: Gview-Rotate" _
9233. "gvmouse: Gview-Mouse" _
9234. "gvdymic: Gview-Dynamic" _
9235. "cporgn: Cplane-Origin" _
9236. "cp3d: Cplane-3D" _
9237. "cptop: Cplane-Top" _
9238. "cpfrnt: Cplane-Front" _
9239. "cpside: Cplane-Side" _
9240. "cpnum: Cplane-Number" _
9241. "cplast: Cplane-Last" _
9242. "cpent: Cplane-Entity" _
9243. "cprot: Cplane-Rotate" _
9244. "cpnorm: Cplane-Normal" _
9245. "cpmouse: Cplane-Mouse" _
9246. "cppxz: Cplane-XZ(+)" _
9247. "cpnxz: Cplane-XZ(-)" _
9248. "cppdz: Cplane-DZ(+)" _
9249. "cpndz: Cplane-DZ(-)" _
9250. "eamgr: Entity Attributes Manager" _
9251. "extsrf: Modify-Surface-Extend" _
9252. "clipbrd: Screen-To Clipboard" _
9253. "regen: Screen-Regenerate" _
9254. "slccrvs: Create-Point-Slice" _
9255. "slcsrfs: Create-Curve-Slice" _
9256. "catan2: Create-Arc-Tangent-2 Entities" _
9257. "circmill: Toolpaths-Circle Mill" _
9258. "sprlhlx: Create-Spiral/Helix _
9259. "crptgrid: Create-Point-Grid" _
9260. "crptbcir: Create-Point-Bolt Circle" _
9261. "fillet: Create-Fillet-2 Entities" _
9262. "filletc: Create-Fillet-Chain" _
9263. "mcplay: Macro-Playback (Toggle)" _
9264. "mcrec: Macro-Record (Toggle)" _
9265. "mcstop: Macro-Pause (Toggle)" _
9266. "anzsnrms: Analyze-Surfaces-Set Normals" _
9267. "crpolyg: Create-Polygon" _
9268. "clprppt: Create-Line-Perpendicular-Pt" _
9269. "clprpar: Create-Line-Perpendicular-Arc" _
9270. "clplldst: Create-Line-Parallel-Dist/Side"_
9271. "clpllpt: Create-Line-Parallel-Point" _
9272. "clpllar: Create-Line-Parallel-Arc" _
9273. "clbisect: Create-Line-Bisect" _
9274. "catancl: Create-Arc-Tangent-Center Line"_
9275. "undelent: Delete-Undelete-Single" _
9276. "hide: Hide" _
9277. "gridprms: Screen-Grid" _
9278. "catadyn: Create-Arc-Tangent-Dynamic" _
9279. "ramsaver: File-RAMsaver" _
9280. "chgattrs: Screen-Change Attributes" _
9281. "jobsetup: Toolpaths-Job Setup" _
9282. "oplist: Toolpaths-Operations Manager" _
9283. "namview: WCS / View Manager" _
9284. "cnv2arcs: Modify-Convert to Arcs" _
9285. "ccedges: Create-Curve-All Edges" _
9286. "studio: Screen-Surf Disp-Studio" _
9287. "clclose: Create-Line-Closest" _
9288. "autocur: AutoCursor (Toggle)" _
9289. "shadetog: Fulltime Shading (Toggle)" _
9290. "quitop: Delete-Last Operation" _
9291. "editlast: Modify-Last Operation" _
9292. "grnamed: Gview-Named" _
9293. "cpnamed: Cplane-Named" _
9294. "tpnamed: Tplane-Named" _
9295. "multiax: Toolpaths-MultiAxis" _
9296. "curve5ax: Toolpaths-Curve 5 Axis" _
9297. "drill5ax: Toolpaths-Drill 5 Axis" _
9298. "swarf5ax: Toolpaths-Swarf 5 Axis Floor" _
9299. "flow5ax: Toolpaths-Flow 5 Axis" _
9300. "rotary4x: Toolpaths-Rotary 4 Axis" _
9301. "grnormal: Gview-Normal" _
9302. "greqcpln: Gview-Equals Cplane" _
9303. "greqtpln: Gview-Equals Tplane" _
9304. "autodesk: File-Convert-AutoDesk" _
9305. " " _
9306. "dfregen: Draft-Regenerate-All" _
9307. "dfrgsel: Draft-Regenerate-Selected" _
9308. "dfrgaut: Draft-Regenerate-Auto (Toggle)"_
9309. "crdmhz: Create-Dimension-Horizontal" _
9310. "crdmvt: Create-Dimension-Vertical" _
9311. "crdmpll: Create-Dimension-Parallel" _
9312. "crdman: Create-Dimension-Angular" _
9313. "crdmdia: Create-Dimension-Circular" _
9314. "" _
9315. "crdmbsln: Create-Dimension-Baseline" _
9316. "crdmchn: Create-Dimension-Chained" _
9317. "crdmord: Create-Dimension-Ordinate" _
9318. "crdmpt: Create-Dimension-Point" _
9319. "dfvdate: Draft-Regenerate-Validate" _
9320. "sldhist: Create-Solids-History" _
9321. "sldmake: Create-Solids" _
9322. "hidemore: Hide-Hide More" _
9323. "unhdsome: Hide-Unhide Some" _
9324. "makebbox: Create-Bounding Box" _
9325. "setmain: Levels-Main (from entity)" _
9326. "gvbottom: Gview-Bottom" _
9327. "gvback: Gview-Back" _
9328. "gvleft: Gview-Left" _
9329. "***** wire *****" _
9330. "csblend3: Create-Surface-3 Surface Blend"_
9331. "csblendf: Create-Surface-Fillet Blend" _
9332. "csprim: Create-Surface-Primitive" _
9333. "csrfsld: Create-Surface-From Solid" _
9334. "tscurves: Modify-Surface-Trim-To Curves" _
9335. "tsplane: Modify-Surface-Trim-To Plane" _
9336. "tssurfs: Modify-Surface-Trim-To Surfs" _
9337. "tsfbnd: Modify-Surface-Trim-Flat Bndy" _
9338. "tsuntrm: Modify-Surface-Untrim" _
9339. "tsrbnd: Modify-Surface-Remove Bndy" _
9340. "tssplit: Modify-Surface-Split" _
9341. "dragnote: Modify-Drag-Note" _
9342. "dfshow: Draft-Show Assoc" _
9343. "cpbottom: Cplane-Bottom" _
9344. "cpback: Cplane-Back" _
9345. "cpleft: Cplane-Left" _
9346. "cpeqgviw: Cplane-Equals Gview" _
9347. "cpeqtpln: Cplane-Equals Tplane" _
9348. "transtog: Translucent Shading (toggle)" _
9349. "" _
9350. "gvdypan: Gview-Dynamic Pan" _
9351. "gvdyzum: Gview-Dynamic Zoom" _
9352. "attribs: Attributes" _
9353. "anznumbr: Analyze-Number" _
9354. "anzchain: Analyze-Chain" _
9355. "anzckmdl: Analyze-Surfaces-Check Model" _
9356. "anzsmall: Analyze-Surfaces-Small Surfs" _
9357. "anzcksld: Analyze-Surfaces-Check Solid" _
9358. "xfmstrch: Xform-Stretch" _
9359. "xfmroll: Xform-Roll" _
9360. "sldext: Solids-Extrude" _
9361. "sldrev: Solids-Revolve" _
9362. "sldsweep: Solids-Sweep" _
9363. "sldloft: Solids-Loft" _
9364. "sldflt: Solids-Fillet" _
9365. "sldchmfr: Solids-Chamfer" _
9366. "sldshell: Solids-Shell" _
9367. "sldbool: Solids-Boolean" _
9368. "sldprim: Solids-Primitive" _
9369. "slddrfac: Solids-Draft face" _
9370. "sldtrim: Solids-Trim" _
9371. "sldlayot: Solids-Layout" _
9372. "sldfeat: Solids-Find features" _
9373. "sldthick: Solids-Thicken" _
9374. "sldrmfac: Solids-Remove faces" _
Charlie, you can try using the SendKeys() method available in the Shell class for the WSH.
Dim objShell     ' WSH Shell object
' create a WSH Shell object
Set objShell = CreateObject("WScript.Shell")
' Send some keys
objShell.SendKeys "a" ' imitates pressing the 'A' key
objShell.SendKeys "{ENTER}" ' imitates pressing the ENTER key
objShell.SendKeys "{F1}" ' imitates pressing the F1 key
objShell.SendKeys "%c" ' imitates pressing ALT+C keys
' cleanup
Set objShell = Nothing
However, with Mastercam, I've noticed that SendKeys() doesn't always act as expected. Sometimes, you have to have your calls to SendKeys() in the reverse order that you'd normally perform them. Experiment and have fun cheers.gif
