I am trying to write a startup script for X and I am having a problem.
Start=AskString("Create a new file? (y or n)")
The prompt window appears and is blank as it should be. But I have to type the info (y or n) in & run the script again. Then it will be in the drop down. How do I get the options to load when the script starts the first time?
Leif
Dim Start
Dim LatheMill
'///////////////// My Global Variables //////////
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
If Start = "y" Then
LatheMill=AskString("Lathe or Mill?")
If LatheMill = "Mill" Then
SetLevelName 10, "Finished part"
SetLevelName 20, "Raw material"
SetLevelName 30, "Fixtures"
SetLevelName 40, "Plane geometry"
End If
If LatheMill = "Lathe" Then
SetLevelName 20, "Finished slice"
SetLevelName 21, "Raw slice"
SetLevelName 20, "Raw revolve"
End If
End If
If Start = "n" Then
Call RunMastercamCommand("OnFileOpen") 'Opens default MCX foulder at startup
End If
End Sub
On a different thing. I see a possbile problem:
End If
End If
You are setting the levles the same on a few of these item I think this might give you problems when you do get the other problem solved.
Sub Main()
Dim Start
Dim LatheMill
If askYesNo("Create a new file?") Then
If instr(Ucase(LatheMill),"MILL") Then
showstring ("mill")
End If
If instr(Ucase(LatheMill),"LATHE") Then
End If
Else
End If
End Sub
