Sign Project
I was given the task of cutting a sign for a friend of mine. Thankfully...I didn't have to paint it. I figured I'd share some pictures of the finished job. This was a result of Engraving, Mastercam Art, your standard 2D pocketing toolpaths and a little remachining. The material is MDF, unpainted. The engraved letters were cut with a 120 degree cutter, and the dog shape was roughed with a 1/2 endmill and finished with a 1/4 ball. I used the "Art Based Surface from Image" to create the surfaces to machine.
-Keith
No problem,
For the lettering, I used the engraving toolpath and a 120 degree cutter from Amana Tool and cut at a speed of 90 ipm and a SS of 13,000 rpm (I think). Max Z depth was -0.239, I just did a finish pass, no roughing.
For the textures on the dog, I used a “Parallel – Contained” Art toolpath. I roughed with a 0.50 in straight cutter, 200 IPM, 2 depth cuts at .187 each, 35% stepover, 0.05 stock to leave in Z. Finished it with a 0.250 ball, 10% stepover at a speed of 150 ipm. Shortly after I started this finishing pass I upped the speed because it was too slow. I forget what I changed it to.
I'd have to check what the tool coatings were, but nothing special. Hope this helps! I'll post more projects as they come along.
-Keith
Thanks CNC_KFB,
This helps, I have developed all of my speeds-feeds myself and just wanted to see what others were having sucess with.
At least 90% of what I cut is MDF laminated in 2.25 and 3.00 thick sheets. Some of the parameters I have tried take out tools quick, also some of the uncoated tools I use won't even last a day.
My current arsenal that I cut a large percentage with are ISCAR inserted tools, for instance: 3/4 2fl heliquad IC 325 coated inserts 22000 rpm 850 ipm .250 depth 55% stepover, this will last between 1 and 3 weeks as a rougher (we cut at least 4-6 of these 48" blocks a day) I make molds with them. I will share more if you're interested.
  • 4 weeks later...
