Lathe Post Help
Tony35
need a little help here
for some reason the post is moving my code to the next line
sample snippet
G50 S3500
G0 G95 X20. Z20. G96 S200
M41 TK3<<<<<<<<<<<<<<<<<<<<<<
T121212 M3 M9
G0 X2.846 Z.1
this is what i want
G50 S3500
G0 G95 X20. Z20. G96 S200 M41 TK3
T121212 M3 M9
G0 X2.846 Z.1
here is my post line
pbld, n$, *sg00, *xhome, *zhome, e$ # *sg95, REMOVED G95 TK 12/7/10
pbld, n$, "G50", *maxss$, e$
pbld, n$, *sg00, *sg95, *xhome, *zhome, pcss, pgear, "TK3", e$ # ADDED LINE TK 12/7/10>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
pcaxis_off_l #Postblock for lathe transition
pcom_moveb #Reset machine position, set inc. from last position
what am i missing here
any help or ideas would be great
TIA
jparis
you the man that was it
so do i have to force G50 in that line if i want it in there?
Depends on the output desired but yes at times, you'll break out the variables you want OR alter the post block, in your case removing the e$ in the post may well yield the result you're looking to get.
There is also the
pcssg50         #Output Constant surface speed clamp
     if css_actv$, pbld, n$, *sg50, *maxss$, e$
That post block handles the G50, but alot depends on what post and what it has.
removing the e$ didnt quite work but looking into the pcss i could use the right code (*sg9697, *speed,) now i just need it to output the speed (*speed)again jparis the man
sample
N80 G50 S2000
N90 G0 G95 X20. Z20. G96 S0 M42>>>>>>>>>>>no css
N100 T030303 M3 M8
N110 G0 X9.95 Z.041
N120 G96 S500
what does your pcss block look like now?
you might try putting the e$ back and adding the pgear callout in the pcss post block, instead of on the the other line
pcss            #Output Constant surface speed
     speed = g_speed
     if css_actv$, pbld, n$, *sg9697, *speed, spindle_l, !css_actv$, pgear, "TK3", e$
     !speed
John
that worked but now im getting a n block in the code now
code
N70 G0 X20. Z20.
N80 G50 S2000
N90 G0 G95 X20. Z20. N90 G96 S500 M42<<<<<<<<<<<<<<
N100 T030303 M3 M8
N110 G0 X9.95 Z.041
N120 G95 G1 Z-.059 F.01
edit
brain fart i just took out the n$ in pcss
thanks for all this help John
