multi start thread
Thoob
Hi guys. I am wondering if there is a way to set my multi start to not offset on each start. Reason I ask is because I am trying to do grease grooves but it has to be like a multi start thread except for the offset on the start. Can I set it different? I notice in the parameters, there is no such option.
Ok I posted out the program with default settings. The cycle is posting out something I'm not familar with. Can someone identify this code for me? The G0W.0588 move. What is that code? That an incremental move on the z?
G76P000060Q20R0.
G76X3.075Z-4.4688P625Q80R0.F.11765
G0W.0588
G76P000060Q20R0.
G97S136M03T505
Z-4.4674
G76P000060Q20R0.
G76X3.075Z-.4688P625Q80R0.F.11765
G0W-.0588
G76P000060Q20R0.
G76P000060Q20R0.
G0W.0588
G76P000060Q20R0.
G97S136M03T505
Z-4.4674
G76P000060Q20R0.
G0W-.0588
G76P000060Q20R0.
Yes "w" is incremental in Z and "U" is incremental in X
Yes I am. But will it make 2 threads 180 degrees from eachother still?
Your feeds and speeds are calculated based on the length of the groove from front to back. So taking the offset out WILL throw the timing off.
We do grease grooves all the time. We load these sub programs into the machine and have the main program call them up
O1000 (GROOVE SUB 1) first groove starting towards front of part
N1000 G32 U0.300 F3.064 <----calculated by length of groove times 2
N1005 G32 W-1.532,<-----length of groove towards chuck
N1010 G32 W1.532<------ length of groove back to front of part
N1015 G32 U-0.300
N1020 G00 U0.007
N1025 M99
O2000 (GROOVE SUB 2) second groove starting towards back of part Same as up top but reversed
N2000 G32 U0.300 F3.064
N2005 G32 W1.532
N2010 G32 W-1.532
N2015 G32 U-0.300
N2020 G00 U0.007
N2035 M99
Ok Thanks. I'll try that procedure out.
The structure of the program looks like this
(.250 WIDE FULL NOSE RAD I.D. GROOVE)
G50 S1118 M42
G55 G00 X0.0 Z0.0 T0 M08
G97 S26 T0808 M03<-------rpm is calculated by 140 divided by feedrate
G54 X2.444 Z1.0 <---"x" move is .300 under the finish dia of the bore
Z-.484 <---First start point
M98 P1000 L20 <---call up 1st sub program and repeat 20 times
G00 X2.444
Z-5.04<------Second start point
M98 P2000 L20<------call up 2nd sub program and repeat 20 times
G00 X2.444
Z1.0
G97 S799
G55 G00 X0.0 Z0.0 T0 MO9
M01
