VBScript - DoNest()
Select the code below and copy to the clipboard, open Mastercam and then the script editor, select new script and paste the contents of the clipboard into it. Note that you will lose all indentations but at least the process saves you a few steps and avoids any hidden characters getting in to the script.
size=2>
'// Author: VBS
'// Date: 28/04/2003 09:38 PM
'// File Name: Nesting Example.vbs
'// Description: This script demonstrates how to automatically nest toolpaths
'// using the Mastercam VBScript function DoNest() This function
'// takes a mcLink.ini text file argument that describes the
'// nesting parameters and the parts to nest.
'// Comments: Obviously you will need the nesting option installed.
'// NOTE: If you run this script then edit it and re-run the script
'// the call to DoNest() may fail, if it does close Mastercam, restart
'// Mastercam and then run the script and you should be fine.
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Dim strDATA
Dim strNestedDrw
' -- Build our path
strDATA = AddBackSlash(GetPath) & "Data"
' -- Clear the screen
Call NewMC(False)
' -- Make some parts
If MakeParts(strDATA) Then
' -- Make the Nestlist
If MakeMcLink(strDATA) Then
' -- Nest the parts
If Not DoNest(strDATA & "mcLink.ini") Then
ShowString "Failed to complete nest"
Else
' -- Build path to file
strNestedDrw = AddBackSlash(strDATA) & "NestEx.MC9"
' -- Fit screen
Call RepaintScreen(True)
' -- Save the nested drawing
If Not SaveMCAs(strNestedDrw, True) Then
' -- Inform user
ShowString "Nest complete but could not save nested drawing"
Else
' -- Tell user where the nested file is located
ShowString "Nest complete => " & strNestedDrw
End If
End If
End If
End If
Call NewMC(False)
End Sub
' Function Declaration
Function MakeMcLink(sData)
On Error Resume Next
' * This function will create the mcLink.ini nest list file for the
' * vbscript function DoNest()
Dim FSO
Dim fsoMcLink ' -- mcLink.ini file
Dim intParts
Dim i
' -- Assume success
MakeMcLink = True
Set FSO = CreateObject("Scripting.FileSystemObject")
' -- File must always be call mcLink.ini
Set fsoMcLink = FSO.CreateTextFile(sData & "mcLink.ini", True)
With fsoMcLink
' Header
.WriteLine "; Mastercam VB Script nesting description file"
.WriteLine "; File created on " & FormatDateTime(Date, vbShortDate) & " at " & _
FormatDateTime(Time, vbLongTime)
.WriteLine ";"
.WriteLine ";"
.WriteLine ";"
' Sheet Definition
.WriteLine "[sHEET]"
.WriteLine "Length=96"
.WriteLine "Width=48"
.WriteLine "Thickness=0.5"
' -- 0=Unlimited
.WriteLine "Quantity=0"
.WriteLine "Material= My Material Name"
.WriteLine ""
' Nesting Parameters
.WriteLine "[PARAMETERS]"
.WriteLine "SheetToSheetDistance=1"
.WriteLine "SheetToPartDistance=0.125"
.WriteLine "PartToPartDistance=0.0625"
.WriteLine "FitPartInPart=False"
.WriteLine "FillAllSheets=False"
' LowerLeft=1, LowerRight=2,
' UpperRight=3, UpperLeft=4
.WriteLine "StartingCorner=1"
.WriteLine "AddLabel=True"
.WriteLine "LabelHeight=0.25"
.WriteLine "AutoOrigins=True"
.WriteLine "GrainDirection=N"
.WriteLine "Accuracy=Medium"
' TrueShape or Rectangular
.WriteLine "Mode=TrueShape"
.WriteLine ""
' Part information
For intParts = 1 To 5
' -- Keep a running total
i = i + 1
' -- Write out the part information
' -- NOTE: No gap allowed PART1 not PART 1
.WriteLine "[PART" & i & "]"
' -- Part is assumed to reside in same folder as this file
.WriteLine "PartName=Part" & i & ".MC9"
.WriteLine "PartLabel=Part " & i
.WriteLine "Quantity=" & i
.WriteLine "StepAngle=0"
.WriteLine "Priority=1" ' 0=False 1=True
.WriteLine "Mirror=0" ' 0=False 1=True
.WriteLine "Grain=N" ' N=No Y=Yes
.WriteLine ""
Next
.WriteLine ";// EOF"
.Close
End With
' -- Check for any errors
If Err Then
ShowString Err.Description & " - Error creating mcLink.ini file"
Err.Clear
' -- Assume no file created correctly
MakeMcLink =False
End If
' -- Clean up
Set FSO = Nothing
Set fsoMcLink = Nothing
End Function
Function AddBackSlash(sPath)
If Right(sPath, 1) <> "" Then sPath = sPath & ""
AddBackSlash = sPath
End Function
Public Function MakeParts(sData)
' * This function will create the 5 parts to be nested
Dim i
Dim objRect
Dim intId
' -- Assume success
MakeParts = True
For i = 1 To 5 ' -- Make 5 parts
Call NewMC(False)
Set objRect = New McRe
With objRect
.X1 = 0
.Y1 = 0
.Z = 0
.X2 = 2 + i
.Y2 = 3 + i
End With
' -- Create the part
If CreateRectangle(objRect, mcCOLOR_RED, mcCONSTRUCTION_LEVEL_CURRENT) = mcENTITY_INVALID Then
ShowString "Could not create part #" & i
MakeParts = False
' -- Bail..
Exit Function
End If
' -- Chain it
If ChainAll(True, True, mcCONSTRUCTION_COLOR_CURRENT, mcCONSTRUCTION_LEVEL_CURRENT) = mcENTITY_INVALID Then
ShowString "Could not Chain part #" & i
MakeParts = False
' -- Bail..
Exit Function
End If
' -- Set some default parameters
Call InitParameters
Call SetDepth(False, -.5)
' -- Contour it
If MakeContour ("1/2 Outline route", 0.5, 0, 1, mcTOOL_FLAT, mcCUTTER_COMP_LEFT, mcCUTTER_ROLL_NONE, 100) = mcENTITY_INVALID Then
ShowString "Could not contour part #" & i
MakeParts = False
' -- Bail..
Exit Function
End If
' -- Zoom all
' -- Make sure we can saved it
If Not SaveMCAs(AddBackSlash(sData) & "Part" & i & ".mc9", False) Then
ShowString "Could not save part #" & i
MakeParts = False
' -- Bail..
Exit Function
End If
Next
Call NewMC(False)
If Err Then
ShowString Err.Description & " - Error creating part files (MakeParts)"
Err.Clear
' -- Assume we dont have any files
MakeParts = False
End If
End Function
[ 04-29-2003, 10:09 AM: Message edited by: VBS ]
