Capturing the Stock Type from Stock Setup
Hi Posts people,
I am trying to add the stock values for 3D simulation on the OSP control to the attached Okuma post. But I must be missing something and I am hoping that somebody there can give me a few minutes of their time.
My problem is that the Shape parameters do not seem to want to work for me
From the docs I can see that this is stored in 19133
So I have added the following to the post, I have called my string - ospstk
ospstk : -1 # OSP 3D Simulation stock - 0=square, 1=cylinder, 2=solid, 3=STL
pparameter$ # Run parameter table
if prmcode$ = 19133, ospstk = rpar(sparameter$, 1)
pwrttparam$ #Information from parameters
This should capture the value of the string to ospstk – (I think)
Then I want to use ospstk to out some code to the nc file, Basically if we have 19133 = 0 (Rect) do something if 19133 = 1 do something else
if ospstk = 0,
BLAH BLAH
OR
if ospstk = 1,
BLAH BLAH
And so on as I can see that the are 4 values that can be returned 0,1,2,3
I Also added this little line just as a check to see what value ospstk is
pbld, n$, " ", *ospstk, e$
The nc file always shows -1 which is what I set as a start value so I must be doing something wrong as all 4 options from the shape type return a value of -1
(DATE - 04-MAY-11)
(TIME - 16:36)
(8 | 10. BULL ENDMILL 0.5 RAD | H8 | D8 | D10.0000mm | R0.5000 | )
ospstk -1.
G00 G17 G21 G40 G80 G90
G30 P32
Any help will be appreciated
The fix is below, Thanks to Min
You need to use ‘rd_tlpathgrp$’ command in ‘psof$’ to enable to call to post block ‘pmachineinfo$’, in ‘pmachineinfo’ you can then put the code to capture the toolpath group parameters.
pmachineinfo$ #Machine information parameters postblock
# Start of File and Toolchange Setup
psof0$ #Start of file for tool zero
psof$
psof$ #Start of file for non-zero tool number
rd_tlpathgrp$
Hi Greg,
I also found an answer to the WCS Origin issue with the Stock Origin. I believe you mentioned (in an email) that you needed to get the WCS Origin values for X,Y,Z so you could compare them to the Stock Origin values. The WCS Origin values are loaded into the pre-defined variables: t_orgin_x$, t_orgin_y$, and t_orgin_z$. No need to extract them from Parameter read routines.
The only thing I'm extracting from the Parameter read right now is the value of 19133 (for Stock Type), and 19137, for the name of the STL file (if that is what is selected in Stock Setup), I get everything else I need from pre-defined variables. These are loaded from the NCI 1020 line (stock parameters) and NCI 1027 (WCS parameters).
Hope that helps. I'm actually doing something very similar to what you are doing now, I'm adding Stock Comment and Okuma Graphics codes to our Okuma OEM Post Processors. Would you be interested in helping me test them out? Please send me a PM if you are interested.
