Post out subprogram from main toopath
Hi,
I would like to be able to post my main programs like a subprogram shown below. Is there a reference that would help me do this? Can it be done without using transform toolpath?
Thank You
O1000 ( PROGRAM - MILL 6 )
N10 ( DATE - 01-07-11 TIME - 15:42 )
N20 G20
N30 G0 G17 G40 G80 G90 G94 G98
N40 G0 G28 G91 Z0.
N50 G0 G28 X0. Y0.
N60 ( TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA. - .5 )
( 5 - AXIS TABLE - HEAD VERTICAL )
( MACHINE GROUP-2 )
N70 T1
N80 M6
N90 G0 G54 G90 X-1.15 Y.3 C0. B0. S3056 M3
N100 G43 H1 Z.25
N110 Z.2
N120 G1 Z-.25 F24.45
N130 G41 D1 X-1.45 F48.9
M98 P1001
N210 M5
N220 G0 G28 G91 Z0.
N230 G28
N240 M01
N250 G0 G17 G40 G80 G90 G94 G98
N260 G0 G28 G91 Z0.
N270 ( TOOL - 2 DIA. OFF. - 2 LEN. - 2 DIA. - .375 )
( MACHINE GROUP-2 )
N280 T2
N290 M6
N300 G0 G54 G90 X4.225 Y-.6375 C0. B0. S4074 M3
N310 G43 H2 Z.25
N320 Z.2
N330 G1 Z-.25 F32.59
N340 G41 D2 Y-.4125 F65.18
M98 P1002
N430 M5
N440 G0 G28 G91 Z0.
N450 G0 G28 X0. Y0.
N460 G28
N470 M30
O1001
N140 G3 X-1.75 Y0. J-.3
N150 I1.75
N160 X-1.7471 Y-.0999 I1.75
N170 X-1.4305 Y-.3823 I.2995 J.0171
N180 G1 G40 X-1.131 Y-.3652
N190 Z-.05 F24.45
N200 G0 Z.25
M99
O1002
N350 G3 X4. Y-.1875 I-.225
N360 G1 X0.
N370 G2 X-.1624 Y-.0938 J.1875
N380 G1 X-2.1624 Y3.3704
N390 G3 X-2.4697 Y3.4527 I-.1948 J-.1125
N400 G1 G40 X-2.6646 Y3.3402
N410 Z-.05 F32.59
N420 G0 Z.25
M99
Question is what have you tired?
Yes it can do it, but if you did a search you would find a ton of information explaining what you just asked about.
I have tried two post that give me what I want. One is the Generic Fanuc 5axis and the other is the download from here called mpsubrepx post.
I am not sure how many places and what needs to be added and what needs to be over written when I copy from the mpsubrepx to the Generic 5axis which I already renmamed so I have a backup.
So far I have located the statement "if numsub" would it be correct that all data that is written in reference to that statement would be my only value I should search and cross reference?
Thank You
This is how I'm doing it in my 4ax post. Similar to mpsubrep. Mi1$ is the trigger Mi2$ is globally assigned to sub_offsets to output reps.
Here are the calls:
Entry point
ptlchg_com      #Tool change common blocks
     #if force_output | sof,
     if force_output,
       result = force(ipr_type,ipr_type)
       result = force(absinc$,absinc$)
       result = force(plane$,plane$)
     pcom_moveb
     pcheckaxis      #Check for valid rotary axis
     #ptoolcomment
     if sof & scomm_sav <> snull,
       spaces$ = 0
       n$, pspc, scomm_str, *scomm_sav, scomm_end, e$
       spaces$ = sav_spc
     if sof = 0, scomm_sav = snull
     comment$
     pcomment3
     pmisccheck
     pcan
     if stagetool >= zero,
       if omitseq$ = 1 & tseqno > 0,
         if tseqno = 2, n$ = t$
         pbld, *n$, e$
         pbld, *t$, "M6", ptoolcomm, e$
       else, pbld, n$, *t$, "M6", ptoolcomm, e$
     spaces$=0
     if output_z = yes$,
       preadbuf5
       if (opcode$ > 0 & opcode$ < 16) | opcode$ = 19,
         #n$, pspc, scomm_str, "CLEAR HEIGHT - ", *max_depth, scomm_end, e$
         n$, pspc, scomm_str, "MAX DEPTH - ", *min_depth, scomm_end, e$
     spaces$=sav_spc
     pstock
     if plane$ < 0 | opcode$ = 3 | opcode$ = 16, plane$ = 0
     sav_absinc = absinc$
     if wcstype > one, absinc$ = zero
     pindex
     if safe_index,
       if lock_codes = one & not(index) & rot_on_x, pbld, n$, *sunlock, sunlockcomm, e$
       pbld, n$, pgear, e$
       pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], pfspeedout, scoolant, pfcout, strcantext, e$
       if lock_codes = one & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, slockcomm, e$
       if convert_rpd$ = one,
         gcode$ = one
         feed = maxfeedpm
         ipr_type = zero
       pbld, n$, sgcode, [if gcode$ = 1, sgfeed], pfxout, pfyout, [if gcode$ = 1, *feed], e$
     else,
       pbld, n$, pgear, e$
         gcode$ = one
         feed = maxfeedpm
         ipr_type = zero
       pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], [if gcode$ = 1, sgfeed],
        pfcout, pfxout, pfyout, pfspeedout, scoolant, [if gcode$ = 1, *feed], strcantext, e$
     phsm1_on        #must remain before G43
     #pbld, n$, "G43", *tlngno$, pfzout, scoolant, pfspindleout, next_tool$, e$
     #Set bias
     if absinc$ = zero,
     local_z = zabs - bias
     else,
     local_z = zinc - bias
     pbld, n$, "G91", "G43", *tlngno$, *local_z, pfspindleout, next_tool$, e$
     pbld, n$, "G92", pfzout, scoolant, e$
     #pbld, n$, "G92", pfzout, e$
     pcan2
     pbld, n$, "G90",  e$
     #pcan2           #Added so M and G codes in canned text will output before phsm2_on
     phsm2_on        #must remain after G43
     sav_coolant = coolant$
     if coolant$ = 1, sm09 = sm09_0
     if coolant$ = 2, sm09 = sm09_1
     if coolant$ = 3, sm09 = sm09_2
     absinc$ = sav_absinc
     pcom_movea
     toolchng = zero
     c_msng$ #Single tool subprogram call
     ptool_sub_s    # <------------------------------------------------tool sub start
     plast
Exit point
pretract        #End of tool path, toolchange
     phsm_off
     absinc$ = one
     ptool_sub_e #<-----------------------  tool sub end
     coolant$ = zero
     pbld, n$, strcantext, scoolant, e$
#      if nextop$ = 1003, #Uncomment this line to leave coolant on until eof unless
#        [                 #  explicitely turned off through a canned text edit
       if all_cool_off,
         #all coolant off with a single off code here
         if coolant_on, pbld, n$, *sall_cool_off, e$
         coolant_on = zero
       else,
         local_int = zero
         coolantx = zero
         while local_int < 20,
           coolantx = and(2^local_int, coolant_on)
           local_int = local_int + one
           if coolantx > zero,
             coolantx = local_int
             pbld, n$, scoolantx, e$
           coolantx = zero
         coolant_on = zero
     #cc_pos is reset in the toolchange here
     cc_pos$ = zero
       gcode$ = one
       feed = maxfeedpm
       ipr_type = zero
     else, gcode$ = zero
     #pbld, n$, sccomp, *sm05, psub_end_mny, e$
     pbld, n$, sccomp, psub_end_mny, e$
     pbld, n$, sgabsinc, sgcode, [if gcode$ = 1, sgfeed], *sg28, "Z0", "M19", [if gcode$ = 1, feed], scoolant, e$
     #if lock_codes = one & rot_on_x, pbld, n$, *sunlock, sunlockcomm, e$
     #pbld, n$, *sg28, "X0", "Y0", protretinc, e$
     #if lock_codes = one & rot_on_x & cuttype = 0, pbld, n$, *slock, slockcomm, e$
     if abs(fmtrnd(cabs)) > 360 & nextop$ <> 1003 & not(index),
       if lock_codes = one, pbld, n$, *sunlock, sunlockcomm, e$
       rotretflg = 1
       pbld, n$, `sg28, protretinc, e$
       rotretflg = 0
       if lock_codes = one & cuttype = 0, pbld, n$, *slock, slockcomm, e$
     coolant$ = sav_coolant
Here are the postblocks called
psub_st_s$       #Header in sub level
     result = nwadrs(stro, sub_prg_no$)
     spaces$ = 0
     sub_ext = sub_prg_no$
     *sub_prg_no$," (", s_progname, *sub_ext, "..SP", ")", e$
     [if scomm_sav <> snull, scomm_str, *scomm_sav, scomm_end], e$     #adding comment to the sub line makes it show up on the control
     spaces$ = sav_spc
     pbld, n$, sgabsinc, e$
     result = force(gcode$,gcode$)
psub_end_s$      #End in sub level
     spaces$ = 0
     pbld, n$, "(", s_progname, *sub_ext, ")", e$
     spaces$ = sav_spc
     n$, "M99", e$
     prv_absinc$ = -1
# Custom post blocks - Subprograms by tool
ptool_sub_s  # Start Toolpath Sub
   if mi1$ = 1,
       pcust_call_s
       spaces$ = 0
       result = workofs$
       counter = sub_offsets - 1
       while counter > 0,
         workofs$ = workofs$ + 1
         pfbld, n$, pwcs, e$
         pfbld, prpt_call_2, e$
         counter = counter - 1
   workofs$ = result
   !workofs$
   subout$ = 1
   psub_st_s$
   pbld, n$, pfxout, pfyout, e$
   spaces$ = sav_spc
ptool_sub_e  # End Toolpath Sub
   if mi1$ = 1,
   psub_end_s$
   subout$ = 0
pdrlcst_sub_s  # Start Custom Drill Sub
       if mi10$ = 0,
       pcust_call_s
       subout$ = 3
       psub_st_s$
pdrlcst_sub_e  # End Custom Drill Sub
       if mi10$ = 0,
       psub_end_s$
       if mi1$ = 1, subout$ = 2
       else, subout$ = 0
prpt_call_2
       sub_prg_call = sub_prg_no$
       pbld, n$, "M98 ", *sub_prg_call, e$
Personally, I think transform is alot easier.
If you ask your reseller, they can email you a copy of the post ref guide. Look at the subout$ command and how it allows you to switch output streams.
Keep in mind that if you output subs this way, you won't be able to use non-transform subs like depth cuts and drill point subs.
