variable for operation number in ops manager
Jeremy,
Yes there is a way for you to set that up. If you are using the MpMaster post, there is a variable called "tseqno" set the variable to 1. Then in the control definition file, go to the NC output in the control topics list, and uncheck the box for output sequence numbers.
tseqno : 1 #Output sequence number at toolchanges when omitseq = yes
#0=off, 1=seq numbers match toolchange number, 2=seq numbers match tool number
Don't forget that if you open the control def from the settings drop down instead of opening the machine def first, you will need to replace the existing machine def in the machine group properties. Just do a file replace as if you're changing posts and replace it with itself. That will reset the control def to the new settings.
Here is the format statement...
fmt  "N"   		4	opnumber # N#= opnumber
Here is the pparam line...
  	if prmcode$ = 15240, opnumber = rpar(sparameter$,1)
And this is the line in the ltlchg postblock
      	pbld, *opnumber, *sgcode, pfxout, pfyout, pfzout, *gltlno, "M00", e$
I just replaced the "n{:content:}quot; with "*opnumber"
Let me know how it works...
I have it set as you described above and it works fine. The problem I have is that most of my files are so big and have so many toolpaths that if I post say toolpaths 1-50 because that is all I can fit in the control at once and then I post 50-100, then 100-150 and so on, each program is n1-n50, I want my N numbers to macth the op number in the operation manager so if I post toolpath 50-100 I would get N50-N100. That way if my operator comes and tells he has a problem with a toolpath in program 3, toolpaths 100-150 I know which one it is without counting. Sorry, If I was not clear earlier.
Jeremy,
Right in the pparameter postblock.
pparameter$  	#Information from parameters
 	#"pwrttparam", ~prmcode$, ~sparameter$, e$
 	if prmcode$ = 15145, metvals   = rpar(sparameter$,1)
 	if prmcode$ = 15346, comp_type = rpar(sparameter$,1)
 	if prmcode$ = 20103, stinsert2 = sparameter$
 	if prmcode$ = 20110, stholder2 = sparameter$
 	if prmcode$ = 10124, g71type = rpar(sparameter$,1)
 	#if prmcode$ = 10080, srefz = sparameter$
 	if prmcode$ = 10080, srefz = rpar(sparameter$,1)
 	if prmcode$ = 10081, srefx = rpar(sparameter$,1)
 	if prmcode$ = 13356, sgroovy = rpar(sparameter$,1)
 	if prmcode$ = 20102, aonecomp = rparsngl(sparameter$, 8)
 	result = fprm (abs(lathecc))
The last one there.
This is what your looking for right?
(TOOL - 12  - OFFSET - 12  - INSERT - DNMG-432 - HOLDER - MDJNR-204D)
(TOOL - 1   - OFFSET - 1   - INSERT - NONE - HOLDER - NONE)
(SET X .005 FROM FIXTURE OD LEFT SIDE)
N32G00X12.5Z5.H12M00                                                        	<<<<<<<<<<op 32
T12H12(TNR = 0.0313)
M41C120.S200.M05
G00X-12.2865Z0.
Z-10.9
M00
Z5.
X12.5
(SEMI FINISH TOP .010 AWAY)
N33G00X12.5Z5.H12M00                                                    	<<op 33
M41C200.S200.M03
G00X9.823Z-3.5126
Z-3.7552
G01X10.1568E.01
G03X10.1756Z-3.7363I.0001K-.019
G01Z-3.658
X10.1954Z-3.6502
G02X10.2844Z-3.6332I-.089K.225
X10.3605Z-3.6455I0.K.2419
G01X10.4225
M9
G00Z5.
X12.5
(FINISH TOP)
N34G00X12.5Z5.H12M00                                 			<<<<<op 34
M41C200.S200.M03
G00X9.8177Z-3.5332
Z-3.7652
G01X9.923E.01
X10.1568
G03X10.1856Z-3.7363I.0001K-.029
G01Z-3.6641
X10.2064Z-3.6567
G02X10.2844Z-3.6432I-.078K.2184
X10.3968Z-3.6723I0.K.2319
G01X10.406Z-3.6774
X10.504
M9
G00Z5.
X12.5
(SET Z 10.0 FROM TABLE)
N35G00X-8.Z5.H01M00                                                      	<<<<<<<<op 35
T01H01(TNR = 0.0315)
M41C120.S200.M05
X-6.0311
Z.0615
M00
X-8.
Z5.
(SET X .005 FROM FIXTURE OD)
N36G00X-8.Z5.H01M00                                                	<<<<<<<<op 36
I knew there was a reason I could not find it. The pparameter lines are in my .psb file. I inserted this in my post file:
# Parameter read postblocks:
pwrttparam$ #Information from parameters
if prmcode$ = 15240, n$ = rpar(sparameter$,1)
and it works but I get this error when I post:
14 Jul 2011 06:08:46 PM - <2> - PSB LINE (-1,4903) - Duplicate assignment of label
Anything to worry about?
