Help please.
Reseller should be able to get you going.
What are the machines capabilites?
Multi turret and multi-spindle machine generics are available as part of the install.
Description: WT 100
Multi-tasking compact machine featuring state of the art capabilitise
* Up to 22/15kW cutting power available for turning shaft-work with synchronized spindles.(Motor power 11/7.5kW per spindle)
* Driven-Tool Motor Power 7.1/2.2kW,for heavy cutting with small tools.
* With upper / lower turret construction,4-axis machining as well as various other machining combinations possible on either spindle
* With upper / lower turrets and opposed two-spindle construction,cycle time balancing and reduction is possible.
* With up to 24-tools per turret,48 tools can be permanently available.
regards
MC
I think you could certainly start with one, I would likely pick the
MULTI - AXIS MILL / TURN LATHE 2 - 2
To get started but I think there will be ALOT of editing to be done.
