Tap/Feed calculations
I have my post setup to double check the correct feeds/speeds are output for the tap. This works great for inch taps but metric I'm getting rounding errors.
Here's the post line
if n_tap_thds$ > 0,
     if feed <> (speed/n_tap_thds$), [if mprint(stapfeed, 1) = 1, exitpost$] #Tap Feedrate check
So basically I convert my metric taps to inch in the tool definition.
M5x0.8
To get TPI I type into the field
0.8/25.4=0.031496(pitch)
1/0.031496=31.750064(TPI)
Now if I type 200RPM I get a feedrate of 6.3IPM
Now when the post does its calculation:
200/6.3=31.74603175
This alarms out.
How can I simplify this so it has a percentage or rounding effect in the equation?
Josh-
What's the format statement for "n_tap_thds$"
Not sure but if you format it to only 2 decimal places it might do the rounding for you....
Also,
I have never used it but I saw this in the V9 post ref guide...
fmtrnd
Formula Type Advanced Math Functions
Description Returns the rounded value of the argument. The format statement (fs)
for the variable is used for rounding. If no format assignment was
given, the format statement one (fs 1) is used. This does not modify the
internal state of the argument value.
Form function argument
Argument numeric variable, value (scalar)
Return Type numeric variable (scalar)
Formula Code Ex. real_result = fmtrnd(x)
Boolean Code Ex. if fmtrnd(x) <> prv_x, “CURRENT VALUE DOES NOT EQUAL PREVIOUS”
Notes Nested return values are stored internally to the post executable. This
formula is normally used to compare rounded values (updated variable)
to un-rounded values
The fmtrnd function may be what you are looking for.
