lead in/out with line-angle and no radius
tboiesan
Sometimes I need lead in/out with line at an angle and no arc sweep in between contour and entry-exit line.
Presently if I set arc radius to 0, sweep angle is ignored and considered 0 also. (or 90 deg if line is set to perpendicular)
To achieve needed results I have to add geometry for entry/exit mooves.
I would like to be able to use sweep angle with 0 arc radius to set entry line slope.
The post knows to convert small rads to linear based on some settings in the post.
arccheck : 1 #Check for small arcs, convert to linear
ltol : .002 #Length tolerance for arccheck = 1
With arccheck set to 1 if the circumfrence of the arc is less than .002" it would linearize it.
