Misc Integer help
Hi Guys.
I have an Okuma Vtl twin spindle post. All we do in this machine is turn impellers from castings(Stainless, and Iron). When the operator gets done roughing, he wants me to park the tool and open the door so he can check the inserts.It looks like this:
N500 G1 Z-1.0379
N505 X5.8676 Z-1.0079
N510 G0 Z10.
N515 G0 X30. Z20. M9
N520 M102
N525 M5 G4F5.
N530 M91
N535 M0
(*********PROGRAM STOP TO CHECK INSERT******)
(*******FINISH FORM SHROUD*********)
N540 M90
NT4000
N545 G0 T0121
N550 G50 S585
N555 G96 S400 M4
N560 M8 M101
Also, we park the tool on centerline to check the thickness of the shroud. It looks like this:
N165 G0 Z10.
N170 G0 X30. Z20. M9
N175 M09 M102
N180 M5 G4F5
N185 M91
N190 M0
(***** CHECK INSERT *****)
N195 M90
NT1000
( ********TOUCH OFF CENTERLINE OF PIECE*********)
N200 G0 X30. Z20. M4 S200
N205 G0 T0101
N210 G0 X12.4 Z2.
N215 G0 Z-3.
N220 M5 G4 F5.
N225 M91
N230 M0
(***** CHECK THE LOCATION OF THE TOOL EDGE WITH)
( THE CENTERLINE OF THE PIECE. *****)
(***** RESET 'Z' IF NESSECARY AS PER THE SET-UP)
N235 M90
N245 T0121
N250 G0 X12.4 Z-2.4063
N255 M91
N260 M0
(ADJUST OFFSET #21 TO MAINTAIN SHROUD THICKNESS.)
(ADJUST ONLY IF SHROUD WILL BE THIN.)
(ROUGH FORM SHROUD)
N265 M90
N270 T0121
N275 G50 S585
N280 G96 S350 M4
N285 M8 M101
Can anyone help me to put a misc. Integer to make the retract to what I need for above. Also, can you help me to make a misc. Integer to check centerline.
I have tried, but I can't get it to work.
Thanks guys,
Todd
What post are you using to run this machine?
Also, please clarify as to exactly which lines of code need to be added to differentiate the new code from what the post is already producing.
I'm assuming that when checking the shroud thickness the coordinates are going to vary from part to part. Are you going to edit the values after posting or are you wanting the values setup as misc reals?
When setting the misc values, are you wanting the insert check/shroud check to appear after the operation the value is set (ie around the retract) or before the operation? Will this only apply when changing tools or also in between operations with the same tool?
Chris,
We are using an Okuma VTL mill/turn post. We purchased it thru "Optipro" our Reseller.
As for the Code I am looking for, right now, the post kicks out this:
G0 Z10. <---Retract Z
G0 X30. Z26. <---Go Home Command
M09 M102 <----High Pressure Coolant off
M5 <----Spindle off
M1 <----Option Stop
What I'd like is to have the option thru Misc. Integer to kick out this:
G0 Z10.
G0 X30. Z26.
M09 M102
M5
M91 <---Door open
M0<---Program Stop
( *******CHECK INSERTS **********) <---these comments are constants
M90 <-----Door Closed
NT2000<-----Start up Block
or this:
G0 Z10.0
G0 X30. Z26. M9
M09 M102
M5
M1
( ********TOUCH OFF CENTERLINE OF PIECE*********) <---these comments are constants
NT2000
G0 X30. Z26. M4 S200
G0 T0101
G0 X11.4 Z2.<---this X could be *mr2$
G0 Z-2.1875 <---this Z could be *mr3$
M5
M91
M0
(CHECK THE LOCATION OF THE TOOL EDGE WITH) <-----these comments are constants
(THE CENTERLINE PIECE.) <----these comments are constants
(RESET 'Z' IF NECESSARY AS PER SET-UP INFO) <----these comments are constants
M90
T0121
G0 X11.4 Z-1.75<----this Z could be *mr4$
M91
M0
(ADJUST OFFSET #21 TO MAINTAIN SHROUD THICKNESS.) <---these comments are constants
(ADJUST ONLY IF SHROUD WILL BE THIN.) <----these comments are constants
As far as the Shroud thickness, it does vary from part to part and yes I would like to set the Misc. Reals for this. I will add a point to the geometry for the shroud thickness that the programmers can pick.
I would like it to be a retract option. You know, like:
if mi4$ = 0, retract1 <----normal retract with option stop
else,
if mi4$ = 1, retract1a<----retract to check insert
else,
if mi4$ = 2, retract 1b<---retract to centerline of part to check thickness/shroud thickness.
something to that effect.
Thanks Chris
With out seeing the post, here is the basic code that needs to be applied:
#declare variables
nt    : 0
last_mi4 : 0
last_mr2 : 0
last_mr3 : 0
last_mr4 : 0
#format variables - 2 is the default format for coordinates, 4 for integers
fmt X 2 mr2$
fmt Z 2 mr3$
fmt Z 2 mr4$
fmt "NT" 4 nt
#Code - put this after the retract (likely pretract, pretract0 or ptoolend), I don't know where to put this without seeing your post.
if last_mi4, nt = nt + 1000
if last_mi4 = 1,
 pbld, n$, "M91", e$
 pbld, n$, *sm00, e$
 pbld, n$, "( *******CHECK INSERTS **********)"
 pbld, n$, "M90", e$
 pbld, n$, *nt, e$
if last_mi4 = 2,
 pbld, n$, "( ********TOUCH OFF CENTERLINE OF PIECE*********)", e$
 pbld, n$, *nt, e$
 pbld, n$, *sg00, *x_home, *z_home, "M4", "S200", e$
 pbld, n$, *sg00, "T0101", e$
 pbld, n$, *sg00, *last_mr2, "Z2.", e$
 pbld, n$, *sg00, *last_mr3, e$
 pbld, n$, *sm05, e$
 pbld, n$, "M91", e$
 pbld, n$, *sm00, e$
 pbld, n$, "(CHECK THE LOCATION OF THE TOOL EDGE WITH)", e$
 pbld, n$, "(THE CENTERLINE PIECE.)", e$
 pbld, n$, "(RESET 'Z' IF NECESSARY AS PER SET-UP INFO)", e$
 pbld, n$, "M90", e$
 pbld, n$, "T0121", e$
 pbld, n$, *sg00, *last_mr2, *last_mr4, e$
 pbld, n$, "M91", e$
 pbld, n$, *sm00, e$
 pbld, n$, "(ADJUST OFFSET #21 TO MAINTAIN SHROUD THICKNESS.)"
 pbld, n$, "(ADJUST ONLY IF SHROUD WILL BE THIN.)", e$
#update values in plast post block
plast
 last_mi4 = mi4$
 last_mr2 = mr2$
 last_mr3 = mr3$
 last_mr4 = mr4$
If you bought the post, why not go back to your reseller for edits??
Chris,
Thank you I will try it and repost. 2 reasons why
I don't go to the reseller.
1. They are already working on one post that is completely wrong, so I don't have time to wait.
2. I am trying to learn to do these things on my own, I have done this stuff before with the old Version 8 and 9 posts. But since "x" I struggle a little because it seams there are more variables in the post now than before.
Todd
