Lathe post problem
Hello all,
I downloaded mplmaster from here and started customizing for our needs. Everything works perfectly for us except the Pattern repeat canned cycle (G73) . I get a double post for my tool end section but I do not know why.
Anybody have an idea?
Here is what the program looks like:
(1)
N0090 G00 X[#148] Z[#149]
N0100 M00 (MONTER OUTIL MANUELLEMENT)
N0110 (* T06 FAPT #604, 0.094R - OUTIL #E037, HOLDER #U1492)
N0120 (* INSERT -  TNMG 436 #CASIER1420, SHIM #737SP)
N0130 (* HOLDER -  MTJNRS204, #E037 - HOLDER #U-1492)
N0140 (- USINER PARTIE DU MILIEU A +.100")
N0150 M32
N0160 G00 T0101 U0. W0.
N0170 G95
N0180 G90 G00 X53.7407
N0190 Z-3.7198
N0200 G92 S40
N0210 G96 S500 M03
N0220 X53.111
N0360 G73 U.2 W.05 R2
N0370 G73 P380 Q410 U.2 W.05 F.02
N0380 G00 X52.6439
N0390 G01 X52.15 Z-4.6914
N0400 Z-67.8524
N0410 X52.711 Z-68.8992
N0010 G00 Z-3.7698
N0020 M09
N0030 M05
N0040 G00 T0100 U0. W0.
N0050 M01
N0010 M09                                  <  --- DOUBLE LINE
N0020 M05                                  <  --- DOUBLE LINE
N0030 G00 T0100 U0. W0.           <  --- DOUBLE LINE
N0040 M01                                  <  --- DOUBLE LINE
(1.2)
N0050 (- USINER PARTIE DU BAS A +.100")
N0060 G00 T0101 U0. W0.
N0070 G00 X53.2549
N0080 Z-3.7698
N0090 G96 S500 M03
N0100 Z-81.86
N0210 G73 U.2 W-.1 R2
N0220 G73 P230 Q250 U.2 W.1 F.02
N0230 G00 Z-69.6398
N0240 G01 X52.15 Z-70.9551
N0250 Z-81.76
N0010 G00 X52.8549
N0020 M09
N0030 M05
N0050 M01
N0010 M05                                 <  --- DOUBLE LINE
N0020 G00 T0100 U0. W0.          <  --- DOUBLE LINE
N0030 M01                                 <  --- DOUBLE LINE
N0040 M30
Attached is a Z2G of the file.
CANNED CYCLE.Z2G
Looks like you've been doing a little post editing in the ptoolend$ post block!
This is a function of the pattern repeat cycle that is passing through the ptoolend$ post block twice per operation with a null toolchange. The nci file gives the post this direction.
You need to add logic in the ptoolend$ post block to look after the repeat instances. I would suggest using op_id$ to try and limit the output in ptoolend$. A quick test has this get the correct output, though it may need to be a little more sophisticated to deal with the specific operation type rather than all operations.
       else, #Null toolchange
         if op_id$ = prv_op_id$,
           #if n1_posttype <> posttype$, pcan1, pbld, n$, pnullstop, strcantext, e$
           pbld, n$, *sall_cool_off, e$
           coolant_on = zero
           toolno = t$ * 100
           if home_type = -1,
             prv_gcode$ = c9k
             #pbld, n$, `sgcode, toolno, e$
             pbld, n$, "G00", "T0100", "U0.", "W0.", e$
           else, pbld, n$, "G00", *toolno, "U0.", "W0.", e$
           else, pbld, n$, "G00", "T0100", "U0.", "W0.", e$
           pbld, n$, "M01", e$
         !op_id$
