Okuma Lathe Work Offsets
Joe,
In Auto: Extend, Restart, N1234, Write
At this point the machine will begin to "run" the program in its mind, as you'll see by the cursor moving. When the cursor stops (make sure you are in single block with the feedrate override turned all the way down) push the Sequence Restart button (should have a little ridge around the edges). The turret may index and the machine will want to move to where it "should" be, so be alert at this point. Once you get where you're going, push Cycle Start and you're good to go.
I think there's also a Number Search button that may work like a Fanuc, but we NEVER use it
C
Dan, I have never used the Shift column (we write to the WOFS Z in every program (VZOFZ=V182+V183+POFP+V1) and use Common Variable #1 as a shift value, but that is more complicated than what you asked for) but on the Zero Offset line, go to the Z column and Add, -.125, Write
