Mazak SQT250MSY.640T Subspindle transfer
Zoffen
I want to do it all!!!lol
It has a 640T control on it.
This is the sequence of events i'm trying to achieve:
(Main spindle program)
Open subspindle
Position sub to pickoff position
clamp sub
unchuck main
move sub away from main with the material still being held by the sub
clamp sub
sync spindles
proceed with cutoff operation
(Sub spindle program)
basically i'm wondering how to sync both spindles and cutoff while held by both spindles.
thanks!
I don't know if this can be useful, but try to program it as you want it in Mazatrol, run the program and check the M and G codes which are used! They are usually shown in the position window on the right side of the "buffer move" and "remaining move", when you run the program! Else take a look on your M and G gode list or contact your local Mazak, they are usually very helpful with info in the cases I have had with correction of post processors etc...
HTH....
This is from an Integrex with a Matrix control, but the code should be the same...
(THIS FIRST IS JUST SO I CAN USE THE MAZATROL SET UP INFO PAGE)
#997=5.46894 (***HEAD 1 Z OFFSET***)
#998=-55. (***PICKOFF POS - MANUALLY BRING SUB-SPIDLE OVER ON FIRST PART TO WHERE YO WANT TO GRAB PART AND THIS A MACHINE POSITION***)
#999=[[#997]+[ABS[#998]]] (***HEAD 2 OFFSET - THIS KEEPS MY PART ZERO THE SAME SO I NEVER MOVE MY PART IN MASTERCAM***)
#990=6.199 (***W-AXIS PULL AMOUNT - THIS HOW MUCH YOU WANT TO PULL OUT THE PART ***)
#996=[[#997]+[#990]](***SYCHED OFFSET - THIS KEEPS MY PART ZERO THE SAME SO I NEVER MOVE MY PART IN MASTERCAM***)
(TRANS-CHUCK)
(*****UPPER TURRET*****)
N8000
M901 (SELECT HEAD 1)
M202 (TURNING MODE HEAD 1)
G53 X0.0 Y0.0 Z0.0 (HD-1-SIDE UPPER TURRET POSITION-Z)
M302 (TURNING MODE HEAD 2)
T19.02 M6 (CUTTING-OFF-TOOL)
G123.1 (DIAMETRICAL PROGRAMMING MODE)
G53 Z-20.0 (ESCAPE POSITION-Z)
M200 (C-AXIS ENGAGE HEAD 1
M300 (C-AXIS ENGAGE HEAD 2)
G53.5 Z[#998] (CALLS MY CUT-OFF POSITION OFFEST)
G00 C0.0 (ORIENT HEAD 1)
G110 C2 (CROSS CONTROL TO HD2)
G00 C0.0 (ORIENT HEAD 2)
G111 (END COMMANDS TO HD2 C-AXIS)
M306 (OPEN HD2 CHUCK)
G0 G53 W[#998+5.] (MOVE SUB SPINDLE TO PICK POSTITON + 5.)
G98 (INCHES PER MINUTE)
G01 W[#998+.10]F10.0 (MOVE SUB SPINDLE TO PICK POSTITON + .1 AT A FASTER FEEDRATE)
G01 W[#998]F1.0 (MOVE SUB SPINDLE TO PICK POSTITON AT A SLOWER FEEDRATE)
M307 (CLOSE HD2 CHUCK)
G98 G04 X0.5 (DWELL)
M206 (OPEN HD1 CHUCK)
G01 G53 W[[#998]+[#990]]F10.0 (PULL PART OUT)
M207 (CLOSE HD1 CHUCK)
M511 (SYNCH HD1 AND HD2 FOR TURNING WITH HEAD 1 IN CHARGE)(M512 WOULD BE HEAD 2 IN CHARGE)
G97 G99 S100 M04 (START BOTH SPINDLES)
S500 M4
G18
(DO THE CUTOFF) (**** THIS A CUT-OFF, BUT YOU COULD HAVE WHATEVER TURNING YOU WANTED HERE)
G53.5 Z[#996] (PART OFF Z OFFSET)
G00 Z-6.051 (CUTTING-OFF POSITION-Z)
G00 X3.2
(******* PART OFF HERE *******)
M08
G75 R.1
G75 X-.02 P0.2 S500. F0.002 M04
G98 G01 X3.2 F10.
(****** END PART OFF CUT ********)
M05 M09 (STOP THE SPINDLES)
G53 X0.0 Y0.0 (TAKE HD1 HOME IN X AND Y)
M513 (UN-SYNCH HD1 AND HD2)
G00 B0.0 (W AXIS GO HOME)
G53 X0.0 Y0.0 Z0.0 (HD-1 GO HOME)
HTH.
Let me know if you have questions.
:thumbsup:
