MAZAK M CODE
VelocityMach
From manual...
M131 High-pressure through-spindle (machining center spindle) coolant ON (option)
For the high-pressure through-spindle (machining center spindle) coolant system with two selectable
pressure levels, M131 is used to select high pressure level. To select low pressure level, specify M51.
If the coolant system does not have the pressure level selection function although the high-pressure
through-spindle (machining center spindle) coolant system is installed, it is possible to turn on the highpressure
coolant by specifying M51.
