Lathe Groovine Finish Path Dwell
When we use the lathe grooving finish path corner dwell (added in X4 mu1 I think) our post does not output anything to the G code File.
Our dealer tells us our post could be an older one that does not provide for this setting.
Maybe someone will be kind enough to answer some questions.
Can anyone tell us if an explicit command is placed in the NCI file for the finish path corner dwell as it is for the rough path dwell?
If not is it calculated in the post or definitions from x and z moves?
Thank you
We are using Mastercam X5 mu1
Thank you
Try using the Generic Fanuc 4X MT_Lathe Post. Here is some code output from this stock post. Note: I entered '11' for the back offset number for cutter compensation. The Finish Dwell codes are output to the NCI file, so this is just an issue with your post not picking up the change...
O0000
(PROGRAM NAME - T)
(DATE=DD-MM-YY - 08-03-12 TIME=HH:MM - 15:04)
(MCX FILE - T)
(NC FILE - C:\USERS\CMG\DOCUMENTS\MY MCAMX5\LATHE\NC\T.NC)
(MATERIAL - STEEL INCH - 1030 - 200 BHN)
G20
(TOOL - 41 OFFSET - 41)
(OD GROOVE CENTER - NARROW  INSERT - GC-4125)
G0 T4141
G18
G97 S703 M03
G0 G54 X-1.0863 Z-.5017
G50 S3600
G96 S200
G99 G1 X-.5665 F.002
G0 X-1.0863
Z-.4333
G1 X-.5665 F.0025
X-.5939 Z-.447
G0 X-1.0863
Z-.5701
G1 X-.5665
X-.5939 Z-.5564
G0 X-1.0863
Z-.365
G1 X-.5665
X-.5939 Z-.3786
G0 X-1.0863
T4111
G97 S200
Z-.2893
X-1.0277
G1 X-.8863 Z-.36 F.002
X-.5565
G4 P.5
G1 Z-.415
G0 X-1.0277
T4141
Z-.6458
G1 X-.8863 Z-.5751
X-.5565
G4 P.5
G1 Z-.52
G0 X-1.0277
G28 U0. V0. W0. M05
T4100
NCI code for reference:
050
14 43 0 0 0 0 0 0 T
999
62 0 1
1051
MULTI - AXIS MILL / TURN LATHE 2 - 4
1053
Machine Group-1
1011
0. 0. 0. 0. 0. 0. 0. 0. 0. 0.
1012
2 0 0 0 0 0 0 0 0 0
1013
0 0.01 0. 0 5 0. 0. 0. 103 OD GROOVE CENTER - NARROW
1014
0. 1. 0. 0. 0. 1. 1. 0. 0.
1016
1 2 62 1 0. 0. 0. 42 0 0 0 0 0. 41 1 1 1 8
1017
1. 0. 0. 0. 1. 0. 0. 0. 1.
950
0 0 0 45 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1025
1027
1. 0. 0. 0. 1. 0. 0. 0. 1. 0. 0. 0.
1020
0. 0. 0. 0. 0. 0. 0 0. 0. 0. 0. 0 5000 STEEL inch - 1030 - 200 BHN
20010
TOP
20011
20012
LATHE UPPER LEFT [TOP] 1
20013
20014
TOP
20015
20016
20017
MEDIUM CARBON
20018
Toolpath Group-1
20019
20001
20002
NONE
20100
1 2 1 0 0. 1 41 41 41
20101
0.0025 82 0.002 200 1 100. 100. 1 8 0 82
20102
1 0. 90. 0.125 0. 0.01 0.01 0 0.
20103
GC-4125
20104
110 0. 0.5 0.01 0.188 0 2 0
20105
0 0. 0. 0. 0. 0. 0.
20106
0 0 0 0. 0. 0. 0. 0. 0. 0. 0. 0
20107
0.125 0.093 0. 0. 0. 0.1 0.01 0.05 0. 0.
20108
0 0. 0. 0. 0. 0. 0. 0 0. 0. 0. 0. 0. 0
20109
0 0. 0. 0. 0. 0.
20110
NONE
20111
83 6. 0.5 1. 1. 0.75 0.093 0. 0. 0. 45. 0 0 1 0
20112
C:\USERS\PUBLIC\DOCUMENTS\SHARED MCAMX5\LATHE\TOOLS\NONE
20800
0.
20600
3 D47A78E7-FBBA-11DA-991B-001111AFFC59 "" "" Machine Base
20600
4 D47A78E9-FBBA-11DA-991B-001111AFFC59 "Z" "Z" Lathe Right Spindle Z Axis (<--+)
20600
5 840561EF-2294-11E1-A2F0-F04DA2626321 "" "" Lathe Chuck
20600
6 D47A78EB-FBBA-11DA-991B-001111AFFC59 "C" "C" Lathe Right Spindle C Axis
20600
7 D47A78ED-FBBA-11DA-991B-001111AFFC59 "" "" Lathe Chuck
20600
8 D47A78EF-FBBA-11DA-991B-001111AFFC59 "Z" "Z" Lathe Left Spindle Z Axis (-->+)
20600
9 D47A78F1-FBBA-11DA-991B-001111AFFC59 "X" "X" Lathe Upper Turret X Axis
20600
10 D47A78F3-FBBA-11DA-991B-001111AFFC59 "Y" "Y" Lathe Upper Turret Y Axis
20600
11 D47A78F5-FBBA-11DA-991B-001111AFFC59 "" "" Lathe Upper Turret
20600
12 D47A78F7-FBBA-11DA-991B-001111AFFC59 "Z" "Z" Lathe Left Spindle Z Axis (-->+)
20600
13 D47A78F9-FBBA-11DA-991B-001111AFFC59 "X" "X" Lathe Lower Turret X Axis
20600
14 D47A78FB-FBBA-11DA-991B-001111AFFC59 "Y" "Y" Lathe Lower Turret Y Axis
20600
15 D47A78FD-FBBA-11DA-991B-001111AFFC59 "" "" Lathe Lower Turret
20600
16 D47A78FF-FBBA-11DA-991B-001111AFFC59 "C" "C" Lathe Left Spindle C Axis
20600
17 D47A7901-FBBA-11DA-991B-001111AFFC59 "" "" Lathe Chuck
20600
18 D47A7903-FBBA-11DA-991B-001111AFFC59 "Z" "Z" Lathe Right Spindle Z Axis (<--+)
20600
19 D47A7905-FBBA-11DA-991B-001111AFFC59 "X" "X" Lathe Upper Turret X Axis
20600
20 D47A7907-FBBA-11DA-991B-001111AFFC59 "Y" "Y" Lathe Upper Turret Y Axis
20600
21 D47A7909-FBBA-11DA-991B-001111AFFC59 "" "" Lathe Upper Turret
20600
22 D47A790B-FBBA-11DA-991B-001111AFFC59 "Z" "Z" Lathe Right Spindle Z Axis (<--+)
20600
23 D47A790D-FBBA-11DA-991B-001111AFFC59 "X" "X" Lathe Lower Turret X Axis
20600
24 D47A790F-FBBA-11DA-991B-001111AFFC59 "Y" "Y" Lathe Lower Turret Y Axis
20600
25 D47A7911-FBBA-11DA-991B-001111AFFC59 "" "" Lathe Lower Turret
20600
26 2ED2A535-77B4-11E0-840C-00A0D525D254 "" "" Tailstock
20601
45 D47A7922-FBBA-11DA-991B-001111AFFC59 0 Left/Upper
20601
48 D47A792D-FBBA-11DA-991B-001111AFFC59 0 Left/Lower
20601
51 D47A7938-FBBA-11DA-991B-001111AFFC59 0 Right/Upper
20601
54 D47A7943-FBBA-11DA-991B-001111AFFC59 0 Right/Lower
20700
0 0 0 0 0 0 0 0 0 0
1001
0 100 2 41 41 5000 1 -200 -0.0025 0 0.54314441 0. -0.50169464 5. 0. 10. 1 0.
0
0 0.54314441 0. -0.50169464 1000. 0
1
0 0.28325347 0. -0.50169464 -0.002 3000
0
0 0.54314441 0. -0.50169464 1000. 40000
0
0 0.54314441 0. -0.43333212 1000. 40000
1
0 0.28325347 0. -0.43333212 -0.0025 0
1
0 0.29692597 0. -0.44700462 -0.0025 0
0
0 0.54314441 0. -0.44700462 1000. 40000
0
0 0.54314441 0. -0.57005717 1000. 40000
1
0 0.28325347 0. -0.57005717 -0.0025 0
1
0 0.29692597 0. -0.55638466 -0.0025 0
0
0 0.54314441 0. -0.55638466 1000. 40000
0
0 0.54314441 0. -0.3649696 1000. 40000
1
0 0.28325347 0. -0.3649696 -0.0025 100
1
0 0.29692597 0. -0.3786421 -0.0025 200
0
0 0.54314441 0. -0.3786421 1000. 40000
1011
1012
2 0 0 0 0 0 0 0 0 0
1013
0 0.01 0. 0 5 0. 0. 0. 102 OD GROOVE CENTER - NARROW
1014
1016
1017
950
1025
1027
1020
20010
TOP
20011
20012
20013
20014
TOP
20015
20016
20017
MEDIUM CARBON
20018
Toolpath Group-1
20019
20800
0.
1000
0 100 2 41 11 5000 1 200 -0.002 0 0.54314441 0. -0.28925892 5. 0. 10. 1 0.
0
0 0.54314441 0. -0.28925892 1000. 0
0
0 0.51385509 0. -0.28925892 1000. 0
1
0 0.44314441 0. -0.3599696 -0.002 52000
1
0 0.27825347 0. -0.3599696 -0.002 1000
4
0.5 200 1
1
0 0.27825347 0. -0.41501338 -0.002 300
0
0 0.51385509 0. -0.41501338 1000. 40000
1011
1012
2 0 0 0 0 0 0 0 0 0
1013
1014
1016
1 2 62 1 0. 0. 0. 41 0 0 0 0 0. 41 1 1 1 8
1017
950
1025
1027
1020
20010
TOP
20011
20012
20013
20014
TOP
20015
20016
20017
MEDIUM CARBON
20018
Toolpath Group-1
20019
20800
0.
1000
0 100 2 41 41 5000 1 200 -0.002 0 0.51385509 0. -0.64576785 5. 0. 10. 1 0.
0
0 0.51385509 0. -0.64576785 1000. 0
1
0 0.44314441 0. -0.57505717 -0.002 52000
1
0 0.27825347 0. -0.57505717 -0.002 1000
4
0.5 200 1
1
0 0.27825347 0. -0.52001338 -0.002 300
0
0 0.51385509 0. -0.52001338 1000. 40000
1003
5. 0. 10.
I don'tsay tht I know for sure, but I rhink that it has nothing with post but with program window in MC. as you can see for rough param. you have "Dwell Time" and for finish parm. you have "Corner Dwell". I think that they didnt tuned those things corectly in MC. probably if your groove is a little bit wired shape " Corner Dwell" will not work corectly.
I am not saying I know for sure either but I think I agree it is a mastercam problem.
I ran some test grooves for comparison.
One aspect the the groove shape caused the finish path corner dwell to fail every time no matter what post I used.
I know what to expect now so I am going to call it mystery solved.
Thanks to all.
