Manual Entry
Good morning everyone,
I am having a problem placing the manual entry toolpath in my programs. Is there a reason it posts between the tool comment and operation comment? i would like to see it post before or after, instead of in between.
(TOOL - 1 - 80 DEG ROUGH TURN AND FACE - OFFSET - 1 - INSERT - CNMG 543 - HOLDER - DCLNR-205D)
(TOOL - 7 - 1.5" DIA ROUGH BORE - OFFSET - 7 - INSERT - CNMG-433 - HOLDER - A16-DCLNL4)
(TOOL - 2 - 55 DEG. FINISH TURN - OFFSET - 2 - INSERT - DNMG-432 - HOLDER - DDJNL-164D)
(TOOL - 10 - 1.5" DIA FINISH BORE - OFFSET - 10 - INSERT - CNMG-432 - HOLDER - A16-DCLNL4)
(TOOL - 12 - 13/32 MZS DRILL - DIA. - .40625")
G20 G18 M69
(TOOL - 1 OFFSET - 1) tool comment
(80 DEG ROUGH TURN AND FACE INSERT - CNMG 543) manual entry to...
(SETUP OP1:CHUCK ON 9.500 ID. TURN 14.750 / 14.740 DIAMETER,)
(FACE HOLDING THE 1.534 / 1.529 DIMESION AND BORE 5.750 / 5.752 DIAMETER THRU.)
(DRILL [20] 13/32 DIAMETER HOLES.)
(G54)
(X ZERO: CENTER)
(Z ZERO: FACE) manual entry.
(ROUGH FACE [Z+.01]) operation comment
G54
N1 T0101
G99
M46
G97 S286 M03
G0 X20. Z.5 M8
thanks for any and all help!!!
You might have comment$ AFTER the ptoolcomment postblock, this is how my post looks:
psof$...
     pcan
     pbld, n$, *t$, sm06, ptoolcomment, e$ #Moved ptoolcomment from line 944 WJ. 07/15/10
     comment$<------------------------------------------- I actually want this as it helps force the operator to actually read the comment.
     pbld, n$, sopen_prn, *stpgrpname, sclose_prn, e$
You might want to move it above the prior line like this:
psof$...
     pcan
     comment$<---here
** At the toolchange block also
ptlchg$...
     comment$<----here
     pbld, n$, *t$, sm06, ptoolcomment, e$ # Moved ptoolcomment from line 1041 WJ. 07/15/10
Both of these should move the comment above the toolchange line. This is nothing but a guess, I dont know what post you have.
