M09 Turn Off Coolant Sooner
What is the best way to alter the Generic Fanuc post to turn off the coolant on the same line as the retract to Clearance Plane at the end of a tool cycle?
O1234
( T1 | 1/2 FLAT ENDMILL | H1 | DIA. - .5 )
G00 G17 G20 G90
G40 G49 G80
N100 T1 M6 ( 1/2 FLAT ENDMILL | DIA. - .5 )
G00 G90 G54 X.125 Y-.5 S1069 M03
G43 H1 Z2.5 M08
Z.2
G01 Z-2. F6.4
Y-.375
G03 X0. Y-.25 I-.125 J0.
G01 X-1.
G03 X-1.125 Y-.375 I0. J-.125
G01 Y-.5
Z.2
G00 Z2.5
M05
G91 G28 Z0. M09 (Original Location)
G28 Y0.
O1234
G00 G17 G20 G90
G40 G49 G80
G43 H1 Z2.5 M08
Z.2
G01 Z-2. F6.4
Y-.375
G01 X-1.
G01 Y-.5
Z.2
G00 Z2.5 M09 (Desired Location)
M05
G91 G28 Z0.
G28 Y0.
I dont think you can place it directly there as it would involve the pzout variable and it might output a coolant code on every line there is a Z, however I placed it next to the M05 which is the line right below what you wanted and this is on a separate block.
pbld, n$, sccomp, *sm05, scoolant, psub_end_mny, e$ <------- added scoolant here
The code looks like
N124 Z.2
N126 G0 Z.25
N128 M5 M9 <-----M9 before the move home !
N130 G91 G28 Z0.
N132 A0.
N134 M01
Guest SAIPEM
The code looks like
N124 Z.2
N126 G0 Z.25
N130 G91 G28 Z0.
N132 A0.
N134 M01
There are a good number of CNC systems that don't allow more than one M-code on the same line.
Double check.
For machines with under-powered coolant pumps I've created an M09 custom M-Code alias
that has a 1 or 2 sec dwell to ensure the coolant is off on the return home.
I do the same in reverse for the M08 to make sure the tool has a sufficient coolant wash
as it begins the operation.
The MPMaster Post Processor outputs the code where we need it. I'll look into how they're doing it tomorrow and see if the code can be added to the Fanuc post. Having (2) M codes on 1 line was a concern of mine. I'll double check our machine manuals and see if it's supported.
I hardcoded an M09 into the pretract postblock. Doesn't hurt a thing.
Find the line Greyman shows (below) and add this line just above it.
pbld, n$, "M09", e$
You may also want to add that line to the null toolchange retract postblock as well. (pretract0)
Problem solved and forgotten about in less that a minute!
