Which is Which? Please be pacific, thank you...
Hi,
I got a preloadwcs instruction from this forum but I don't know which belongs which please help. Which section belongs to postblock? Which section belong wpc and where do I insert exactly? I tried but they failed may be I put into wrong section. I bold the first section and assum they are one section but where do I put? postblock? How about the other sections? Do we have a better way to present this easier to for understanding?
Thounsand words of "Thank yous and appriciations",
Steven.L
# Buffer 6 - G10 work offset preloads write, sort, read, output routines
#This section is designed to write the work offsets preloads to a buffer file, then sort them
#into accesding order and eventually output the preloads to the NC output files. These sections
#only get called if the use_g10wcs flag is on.
# Work offset preload buffer
test : 0 #Result variable
cnt1 : 0 #Loop counter number 1 for sort
cnt2 : 0 #Loop counter number 2 for sort
wc6 : 1 #Initial count for write buffer 6
rc6 : 1 #Initial count for read buffer 6
size6 : 0 #Buffer 6 size
tox3 = tox6 #Figures X Offset from machine zero
toy3 = toy6 - 25.5905 #Figures Y Offset from machine zero
toz3 = toz6 #Figures Z Offset from machine zero
fmt W 4 workofs6 #Buffer 6
fmt P 4 pofs6 #Buffer 6
fmt X 2 tox6 #Buffer 6
fmt Y 2 toy6 #Buffer 6
fmt Z 2 toz6 #Buffer 6
fmt B 15 cabs6 #Buffer 6
fmt X 2 tox3 #Buffer 2 X Offset from machine zero
fmt Y 2 toy3 #Buffer 2 Y Offset from machine zero
fmt Z 2 toz3 #Buffer 2 Z Offset from machine zero
workofsn : 0 #Temporary data for swap in buffer2
pofsn : 0 #Temporary data for swap in buffer2
toxn : 0 #Temporary data for swap in buffer2
toyn : 0 #Temporary data for swap in buffer2
tozn : 0 #Temporary data for swap in buffer2
coutn : 0 #Temporary data for swap in buffer2
fbuf 6 0 6 0 0 #Buffer 6
preloadwcs #Output G10 preloads from Buffer6
#This postblock is called from the PSOF postblock and is designed to output the WCS
#preloads to the beggining of the NC output file and only if the use_g10wcs flag is
#active.
pg10sort #Sort preload buffer in accesnding order before output
#read preload buffer and output preloads
rc6 = 1
size6 = rbuf (six, 0)
#"(***********************************************)", e$
*e$
"(*********** WORK COORDINATES START **********)", e$
while rc6 <= size6,
workofs6 = rbuf (six, rc6)
#"workofs6 = " *workofs6, e$ #debug
#"*pofs6 = ", *pofs6, e$ #debug
if workofs6 < 6,
pofs6 = pofs6 + 6
pbld, n$, *sgabsinc, "G10", "L2", *pofs6, *tox3, *toy3, *toz3,
"(", *cabs6, ")" e$ #Offsets G54 - G59
else, pbld, n$, *sgabsinc, "G10", "L20", *pofs6, *tox3, *toy3, *toz3, "B0.", "(", *cabs6, ")", e$
#Extended offsets g54.1 P1 - P48
*e$
"G11", e$
"(*********** WORK COORDINATES END **********)", e$
pg10sort #Sort preload work offsets in accending order
#This postblock is designed to sort the wcs preload buffer in accending order. This
#postblock is called
#from the preloadwcs postblock. DO NOT MODIFY this post block unless you are
#absolutely sure of what you
#are doing.
rc6 = 1
cnt1 = 1 #intialize counters
cnt2 = 1 #intialize counters
while cnt1 < size6, #loop 1 - loop 1 time less than the size of the buffer
while cnt2 <= size6 - cnt1, #loop 2 - loop 1 less every time
rc6 = cnt2 #set buffer read counter to current loop counter value
#(Current record to read)
workofs6 = rbuf (six, rc6) #Read current and next record from buffer
workofsn = rbuf (six, rc6)
if workofsn < workofs6, #Check and swap records if next offset is less
#than current
wc6 = cnt2 #initalize write counter to current loop counter value
#(current record to write)
workofsn = wbuf (six, wc6) #Swap records by writing back into buffer.
#Next into current, current into next
workofs6 = wbuf (six, wc6)
cnt2 = cnt2 + 1 #increment loop counter 2
cnt2 = 1 #Reset loop counter 2 to start at record 1
cnt1 = cnt1 + 1 #increment loop counter 1
pg10wcs_writbuf #Buffer 6 works offset preload buffer
#This postblock is called from pwrtt and only if the use_g10wcs flag is active.
#This postblock is designed to write out the WCS and tool origin information to the
#preload buffer. The preload buffer will be scanned and checked to see if the WCS was
#already
#written to the buffer, if not the wcs is written to the buffer.
test = 0
size6 = rbuf(six, 0) #Get size of buffer
#read buffer and compare current workofs value with one read from buffer.
#If current workofs matches one already in buffer set flag to not process.
while rc6 <= size6,
if workofs$ = workofs6, test = 1
#If workofs doesn't match one in the buffer, write it to the buffer
# with the P value and tool origin.
if test = 0,
cabs6 = atan2 (m7$, m9$)
workofs6 = workofs$
pofs6 = workofs$ - 53
if workofs6 < 54, pofs6 = workofs$ -5 #Extened offsets P1 - P48
tox6 = tox$
toy6 = toy$
toz6 = toz$
#cabs6 = cout
rc6 = 1 #reset read counter for next pass
