Posting with unwanted G93 Inverse Time Feed
The post for our mill-turn Mori MT1500 (based off MPLMASTER) outputs G93 in unexpected places, for example during an op where the only rotary moves are C-axis positioning. It seems to only happen once the C-axis moves past C270. Here's a code example (from a simple mill op that is transformed with a tool plane rotate around the C-axis). I'm happy with the moves at C269 & C270, but at C271 or higher a G93 is used instead of G98:
G00 C269.
G98 G01 X4. F6.
Z-1.
G00 X5.
Z0.
G00 C270.
G98 G01 X4. F6.
Z-1.
G00 X5.
Z0.
G00 C271.
G93 G01 X4. F.417
Z-1. F.42
Here's some switches I've tried changing in my post to fix the issue:
#C axis and Index switches
use_frinv : 1 #Use Inverse Time Feedrates in 5 Axis, (0 = no, 1 = yes)
I set 'use_frinv' to 0, but this had no effect.
rot_feed : 1 #Use calculated rotary feed values
#0 = no, 1 = yes - code coords, 2 = yes - virtual coords for fiveax_comp : 0
I set 'rot_feed' to 0, the problem goes away, but I think this will break rotary milling toolpaths.
ctol : 270 #Tolerance in deg. of inc. move before 'rev' flag changes
I set 'ctol' to 360, the problem goes away. However, will this break something else?
Anyone have feedback on the changes I tried or any other ideas?
Dana
Dana, you have to try some of these things and see the results they will Yield. Sometimes it is just a simple tweak to get what you need and other times it is full blown dig a trench and see where the parts lay.
Do some tests and see what happens. Set the X axis above and run some trial cuts and see how the machine reacts. I have see two Integrex's maxhine same make model and control do 2 different things with the same code. It took some tweaking at the machine with parameters to get them to act the same. People want a bullet proof post and most times the only bullet proof post is one that has been tried trued and tested especially on these complex machines.
