If - or statement?
So I am looking to have an option set with a MI to have a slow tool change. I would like to have a flag to have it then do a slow tool change to remove the tool also, so for my tool changes, I am looking to have a flag and on my tool change have a logic that goes something like this:
If MIxx = 1 and/or Flag = 1 M306
else M6
If MIxx = 1, Flag =1
else flag = 0
How can I format that?
Ok, here is what I came up with....using mpfan...
First define your "flag" variable. (I used dsv)
# Toolchange / NC output Variable Formats
fmt "T" 4 t$ #Tool number
fmt "T" 4 first_tool$ #First tool used
fmt "T" 4 next_tool$ #Next tool used
fmt "D" 4 tloffno$ #Diameter offset number
fmt "H" 4 tlngno$ #Length offset number
fmt "G" 4 g_wcs #WCS G address
fmt "P" 4 p_wcs #WCS P address
fmt "S" 4 speed #Spindle Speed
fmt "M" 4 gear #Gear range
fmt 4 dsv #hold last value of mi4
Then start with the psof postblock.... you can see what I added between the ####################
psof$ #Start of file for non-zero tool number
pcuttype
toolchng = one
if ntools$ = one,
#skip single tool outputs, stagetool must be on
stagetool = m_one
!next_tool$
pbld, n$, *smetric, e$
pbld, n$, *sgcode, *sgplane, scc0, sg49, sg80, *sgabsinc, e$
sav_absinc = absinc$
if mi1$ <= one, #Work coordinate system
absinc$ = one
pfbld, n$, sgabsinc, *sg28ref, "Z0.", e$
pfbld, n$, *sg28ref, "X0.", "Y0.", e$
pfbld, n$, sg92, *xh$, *yh$, *zh$, e$
absinc$ = sav_absinc
pcom_moveb
pcheckaxis
ptoolcomment
comment$
pcan
if mi4$ = 1,
pbld, n$, *t$, "M306", e$
else,
pbld, n$, *t$, sm06, e$
if mi4$ = 1,
dsv = 1
else,
dsv = 0
pindex
if mi1$ > one, absinc$ = zero
pcan1, pbld, n$, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfcout,
[if nextdc$ <> 7, *speed, *spindle], pgear, strcantext, e$
pbld, n$, sg43, *tlngno$, pfzout, scoolant, pstagetool, e$
pbld, n$, sgabsinc, e$
pcom_movea
toolchng = zero
c_msng$ #Single tool subprogram call
Then do the ptlchg postblock, I added what you see between the ################
ptlchg$ #Tool change
pcuttype
toolchng = one
if mi1$ = one, #Work coordinate system
if prog_stop = 1, pbld, n$, *sm01, e$
if prog_stop = 2, pbld, n$, *sm00, e$
pcom_moveb
pcheckaxis
ptoolcomment
comment$
pcan
result = newfs(15, feed) #Reset the output format for 'feed'
if mi4$ = 1 | dsv = 1,
else,
if mi4$ = 1,
dsv = 1
else,
dsv = 0
pindex
pcom_movea
toolchng = zero
!xnci$, !ynci$, !znci$
Here is what I get....
O0000(TEST)
(DATE=DD-MM-YY - 10-08-12 TIME=HH:MM - 11:26)
(MCX FILE - C:\DOCUMENTS AND SETTINGS\KEITHG\MY DOCUMENTS\DOWNLOADS\TEST.MCX-6)
(NC FILE - C:\DOCUMENTS AND SETTINGS\KEITHG\MY DOCUMENTS\MY MCAMX6\MILL\NC\TEST.NC)
(MATERIAL - ALUMINUM INCH - 2024)
( T157 | 3/4 DRILL | H157 )
( T122 | LTR. R DRILL | H122 )
( T227 | 1-3/4-5 TAPRH | H227 )
N100 G20
N102 G0 G17 G40 G49 G80 G90
N104 T157 M6
N106 G0 G90 G54 X-.9149 Y.4969 A0. S356 M3
N108 G43 H157 Z.1
N110 G99 G81 Z0. R.1 F4.28
N112 X-1.066 Y.7908
N114 G80
N116 M5
N118 G91 G28 Z0.
N120 A0.
N122 M01
N124 T122 M306
N126 G0 G90 G54 X.5405 Y.7435 A0. S788 M3
N128 G43 H122 Z.1
N130 G99 G81 Z0. R.1 F4.16
N132 X.9587 Y.3703
N134 G80
N136 M5
N138 G91 G28 Z0.
N140 A0.
N142 M01
N144 T157 M306
N146 G0 G90 G54 X-.9036 Y-.6018 A0. S356 M3
N148 G43 H157 Z.1
N150 G99 G81 Z0. R.1 F4.28
N152 X-.5794 Y-1.2038
N154 G80
N156 M5
N158 G91 G28 Z0.
N160 A0.
N162 M01
N164 T227 M6
N166 G0 G90 G54 X1.1746 Y-1.1551 A0. S152 M3
N168 G43 H227 Z.1
N170 G99 G81 Z0. R.1 F30.56
N172 X1.3114 Y-1.4064
N174 X1.2166 Y-1.5877
N176 G80
N178 M5
N180 G91 G28 Z0.
N182 G28 X0. Y0. A0.
N184 M30
mi4 was set to 1 in the second operation.....
I didn't do anything with the null toolchange postblock, let me know if you have trouble with that.
HTH!
Here's all the
Formula descriptions.
= (assignment)
Formula Type Basic math functions
Description Assignment
Form result assignment argument
result assignment function argument
result assignment argument operator argument
Return Type Depends on formula
Formula Code Ex. x = y
x = y + z
c = atan2(x, y)
Boolean Code Ex. Not interpreted in conditional branching statement
Notes These are the basic assignment forms. They may be combined as
required.
Description Addition
Form argument operator argument
First Argument numeric variable, value (scalar)
string variable
Second Argument numeric variable, value (scalar)
string variable
Return Type numeric variable (scalar)
string variable
Formula Code Ex. x = y – z
string1 = string2 + string3
Boolean Code Ex. if (x + y) = 2, p_action
if (string1 + string2) = string3, p_action
Notes Argument types must match. A maximum of 10 string variables may
be added (concatenated) in a single formula.
Description Subtraction
Boolean Code Ex. if (x – y) = 2, p_action
Notes
– (unary)
Description Unary minus
Form operator argument
First Argument numeric variable (scalar)
Second Argument numeric variable (scalar)
Formula Code Ex. x = –y
x = y * (–z)
Boolean Code Ex. if -x = 2, p_action
Notes Do not use multiple unary operators, for example, – – –x.
Description Multiplication
Formula Code Ex. x = y * z
Boolean Code Ex. if (x * y) = 2, p_action
Notes
Description Division
Formula Code Ex. x = y / z
Boolean Code Ex. if (x / y) = 2, p_action
Notes Avoid having a denominator of 0. This condition generates a fatal
“divide by zero” error.
Description Power. Raises the first argument to the power of the second argument.
Formula Code Ex. x = y ^ z
Boolean Code Ex. if (x^ y) = 25, p_action
Notes
= (Boolean)
Formula Type Logic operators
Description Logical comparison. True if values are equal.
string variable
string variable
Return Type numeric variable (Boolean result)
string variable
Formula Code Ex. real_result = x = y
real_result = string1 = string2
Boolean Code Ex. if x = y, p_action
if string1 = string2, p_action
Notes Argument types must match. The return is 0 if false and 1 if true.
Nested return values are stored internally to the post executable.
Description Logical comparison. True if first argument is less than second
argument.
Formula Code Ex. real_result = x < y
Boolean Code Ex. if x < y, p_action
Notes The return is 0 if false and 1 if true. Nested return values are stored
Description Logical comparison. True if first argument is greater than second
argument.
Formula Code Ex. real_result = x > y
Boolean Code Ex. if x > y, p_action
Description Logical comparison. True if first argument is less than or equal to the
second argument.
Formula Code Ex. real_result = x <= y
Boolean Code Ex. if x <= y, p_action
Description Logical comparison. True if first argument is greater than or equal to
Formula Code Ex. real_result = x >= y
Boolean Code Ex. if x >= y, p_action
Description Logical comparison. True if values are not equal.
string variable
string variable
Formula Code Ex. real_result = x <> y
real_result = string1 <>string2
Boolean Code Ex. if x <> y, p_action
if string1 <> string2, p_action
Description Logical “and”.
Arg1 Arg2 Result
1 1 1
1 0 0
0 1 0
0 0 0
Formula Code Ex. real_result = x & y
Boolean Code Ex. if x & y, p_action
Description Logical “or”.
Arg1 Arg2 Result
1 1 1
1 0 1
0 1 1
0 0 0
Formula Code Ex. real_result = x | y
Boolean Code Ex. if x | y, p_action
Notes The return is 0 if false and 1 if true. This character is the “pipe”
character (ASCII decimal equivalent 124). Nested return values are
Formula Type Precedence function
Description Open and close parentheses are used to control the precedence of
operation. Depending on the nesting levels, the formulas nested
deepest are evaluated first.
Form operator argument operator
Formula Code Ex. real_result = (x * (2 + y)) ^ z / (x – y)
Boolean Code Ex. if (x > 2 & x <> 3) | (fmtrnd(y) & fmtrnd(z)), p_action
Notes Nesting parentheses must always match the open parenthesis to the
closing parenthesis. Do not confuse the parentheses used in the
formula functions (for example, abs(x)) with those used for precedence
nesting.
abs
Formula Type Advanced Math Functions
Description Returns the absolute value of the argument.
Form function argument
Return Type numeric variable (scalar) as a positive value
Formula Code Ex. real_result = abs(x)
Boolean Code Ex. if abs(x) < mtol, “THIS IS A SMALL NUMBER”
Notes Nested return values are stored internally to the post executable.
acos
Formula Type Trigonometric function
Description Arc cosine. Returns the ratio of the adjacent angle to the hypotenuse of
a right triangle.
Return Type numeric variable (angle)
Formula Code Ex. real_result = acos(x/y)
Boolean Code Ex. if acos(x/y) > 45, p_action
and
Formula Type Binary function
Description Bitwise and operation. Converts the two arguments to binary and then
performs the “and” comparison on the individual bits.
Bit Bit Result
1 1 1
1 0 0
0 1 0
0 0 0
The return value is the resulting value.
Form function argument, argument
Formula Code Ex. real_result = and(real_var1, real_var2)
Boolean Code Ex. if and(real_var1, real_var2) = 2, p_action
Notes Integer values are expected. Nested return values are stored internally
to the post executable. This form of “and” is rarely used.
asin
Description Arc sine. Returns the ratio of the opposite angle to the hypotenuse of a
right triangle.
Formula Code Ex. real_result = asin(x/y)
Boolean Code Ex. if asin(x/y) > 45, p_action
atan
Description Arc tangent. Returns the ratio of the opposite angle to the adjacent
angle of a right triangle.
Formula Code Ex. real_result = atan(x/y)
Boolean Code Ex. if atan(x/y) > 45, p_action
atan2
Description Arc tangent (two arguments). Returns the angle (0 to 360 degrees) of
the arguments passed to the formula. The second argument axis
indicates the axis for the zero angle position. The first argument axis
indicates the direction from the second argument axis (which defines
the zero angle) is in the positive angle direction. These arguments are
signed to indicate choice.
First Argument numeric variable, value (scalar), represents positive direction
Second Argument numeric variable, value (scalar), represents zero angle
Formula Code Ex. real_result = atan2(x, y)
Boolean Code Ex. if atan2(x, y) >180, p_action
axb
Formula Type 2D vector math function
Description Planar cross product. The formula takes the product of the arguments
(unitized vectors) and returns the sine of the angle between them.
First Argument numeric variable (3D vector, unitized)
Second Argument numeric variable (3D vector, unitized)
Formula Code Ex. real_result = axb(v3_x1, v3_x2)
Boolean Code Ex. Not allowed as a Boolean statement
Notes This is a 2D function. It is recommended that 3D vectors be used and
the last element in the implied array remains 0.
brksps
Formula Type String function
Description Breaks a string variable before the index position (one-based) specified
by the value in the first argument. The original string variable (second
argument) holds the start of the broken string and the return string
variable holds the remainder of the string.
Second Argument string variable
Return Type string variable
Formula Code Ex. real_var1 : 8
string1 "one two three four"
string2
pblock # A postblock
string2 = brksps (real_var1, string1)
In this example, string1 = "one two" and string2 = " three four".
Notes
cos
Description Cosine. Returns the ratio of the adjacent angle to the hypotenuse of a
right triangle.
Argument numeric variable, value (angle)
Formula Code Ex. real_result = cos(angle)
Boolean Code Ex. if cos(angle) > .7071, p_action
So I didn't have time to get to editing my post until this morning. Thanks guys! Heres what I did and the logics I used, in case anyone needs to do something like it in the future and finds this thread.
in the post variables i created a variable,
slowtc : 0
In the Tool change I replaced the M6 line with the logic
If mi6 = 99 | slowtc = 1
M306
else
M6
if mi6 = 99,
slowtc = 1
else
slowtc = 0
Then, in my end of file, I added a line before my M30
if slowtc = 1, M306
That makes sure my heavy or sensitive tool comes back out slow and doesn't get slammed around by the high speed tool change at the start of the next program.
