How do I make G94 appear in tap mode but not in drill cycle?
Hi,
I have problems with pitch tap which must have G93 to starts cyle and ends with G94. Please see below these dotted lines
N4 ( 7/32 DRILL)
G0 G17 G40 G49 G53 G80 G90 Z0
T4 M6(DRILL FOR ROLL TAP)
M8(LOC = Z-1.25)
G0 G90 G54
X1. Y-1. S2500 M3
G43 H4 Z2. T5
Z.1
G99 G83 Z-1.25 R.1 Q.065 F10.
Y-4.
X9.
Y-1.
G0 G80 Z2. M9
G40 G53 Z0 M19
M1
N5 ( 1/4-20 TAPRH)
T5 M6(1/4-20 ROLL TAP ONLY)
M8(LOC = Z-1.)
G0 G90 G54
X1. Y-1.
G43 H5 Z2. T6
Z.1
G93 S300
G99 G84 Z-1. R.1 F.05 P300.
Y-4.
X9.
Y-1.
G94 <------------------------------------- (I would like G94 appears here, please help)
G0 G80 Z2. M9
G40 G53 Z0 M19
M1
Hi PcRobotic,
You will have to force the string sgfeed, for tapping operations only (drillcyc$ = 3), in the post block pcanceldc$ right before the G80 output.
if drillcyc$ = 3, pbld, n$, *sgfeed, e$
if drillcyc$ <> 8, pcan1, pbld, n$, "G80", scoolant, strcantext, e$
sgfeed is the target string for a string select table, so it will only output G94 if the selector variable, ipr_type, is set properly.
Hope this helps.
Thank you Ivan, it works.
Hi PcRobotic,
Hope this helps.
Thanks for the tips Colin. By the way, did you recive my private message of which i just sent you a few minutes ago?
Since 'sgfeed' is a string select variable, the output will depend on the value of 'ipr_type'. Instead of 'sgfeed', I would use 'sg94' in it's place. That way you are always forcing "G94" explicitly.
