Manual Entry Question
jeff
Using MPOkuma.pst.
I have a program where I need a bunch of Manual Entry's.
Seems like it doesn't matter if I post as Code or Comment, they are both in Parentheses.
Why would "code" be in parentheses?
ex:
G00Z20.
X-20.Y20.
M00(MY COMMENT HERE) <--This is how it should look
(G00Z20.)
(X-20.Y20.)
(M00(MY COMMENT HERE)) <--- this is the output
my post:
pcomment2 #Comment from manual entry
scomm$ = ucase (scomm$)
if gcode$ = 1007, "(", scomm$, ")"
else, *n$,"(", scomm$,")", e$
If I remove the "(" and ")" my N lines don't have the comment in parentheses.
What am I doing wrong?
There are a couple of different gcodes you need to look at. 1005 is output for manual entry as comment, 1006 is for as code, 1007 is for as comment with no line return, 1026 is for as code with no line return
Mpfan has this all setup for each of the different comment gcodes which should give you a starting point:
pcomment2 #Output Comment from manual entry
if gcode$ = 1005, sopen_prn, scomm$, sclose_prn, e$ #Manual entry - as comment
if gcode$ = 1006, scomm$, e$ #Manual entry - as code
if gcode$ = 1007, sopen_prn, scomm$, sclose_prn #Manual entry - as comment with move NO e$
if gcode$ = 1026, scomm$ #Manual entry - as code with move NO e$
if gcode$ = 1008, sopen_prn, scomm$, sclose_prn, e$ #Operation comment
if gcode$ = 1051, sopen_prn, scomm$, sclose_prn, e$ #Machine name
if gcode$ = 1052, sopen_prn, scomm$, sclose_prn, e$ #Group comment
if gcode$ = 1053, sopen_prn, scomm$, sclose_prn, e$ #Group name
if gcode$ = 1054, sopen_prn, scomm$, sclose_prn, e$ #File Descriptor
Using MPOkuma.pst.
ex:
G00Z20.
X-20.Y20.
(G00Z20.)
(X-20.Y20.)
my post:
If you remove the Bottom "(" & ")" at the else line, you should see them when you select comment in the manual entry parameters. They will disappear when you select code, if you remove "(" & ")" on the if line then you are telling it to remove the parenthesis when it actually is a comment.
I removed them from the else line,and it worked,
BUT
it also removed the parentheses from my N lines...for example N100(FACEMILL) turns into N100FACEMILL
BUT
Something is up because gcode$=1007 is for Manual Entry Comments Only, I remember I had this issue before un til I added the other definitions like Chris McIntosh ^^ mentioned.
Particularly this: if gcode$ = 1008, sopen_prn, scomm$, sclose_prn, e$ #Operation comment, I would also fire up the debugger and do a breakpoint where it generates the commented output and watch the values of the gcode$ parameter. Also you might want to do a search in your post to see if sopen_prn and soclose_prn are defined in your post as ( & ) respectively; you have two choices either define them yourself or simply replace it for "(" & ")".
Yeah, I haven't had time yet today to try the stuff Chris suggested.
I've altered my post many times over the years since it's only my machine that uses it and I'm anal about how I like my programs to look, so it's highly possible that I've deleted some stuff.
