You-Ji VTL need Q on each line for G83
Hi,
We have a You-Ji vertical live tooling lathe.. I need the post to put a Q on each line when using G83 peck drilling cycle.. Where in the post is this controlled? I am not sure what the original post was or came from..
Here is the top of the post
POST_VERSION] #DO NOT MOVE OR ALTER THIS LINE# V15.00 P2 E1 W15.00 T1337895755 M15.00 I0 O0
# Post Name : YOU JI
# Product : LATHE
# Machine Name : YOU JI
# Control Name : OI
# Description : YOU JI C-AXIS POST
# Mill/Turn : YES
# 4-axis/Axis subs. : YES
# 5-axis : NO
# Subprograms : YES
# Canned Cycles : YES
# Executable : MP 10.0
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
# Associated File List$
# GENERIC FANUC 4X MT_LATHE.control
This is what it posts out now for G83 peck drill..
N1 M01(17/32 DRILL)
G00 G18 G40 G80
( DRILLS WITH 17/32 DRILL )
G00 T1010 M06
M69
M22
M41
M66
G00 G54 X9.
Z.1
C0.
M08
G97 S1500 M33
G98 G83 Z-1.675 R.1 Q.1 F5.
C90. <------------------------------------------------------ Need a Q.1 on each line ----------------------------------->
C135. <----------------------------------------- Here -------------------------------------------------->
C180. <----------------------------------------- Here -------------------------------------------------->
C270. <----------------------------------------- Here -------------------------------------------------->
C315. <----------------------------------------- Here -------------------------------------------------->
X0. C90. <----------------------------------------- Here -------------------------------------------------->
G80
M09
G00 Z2.0
M35
M21
G28 W0. U0.
H0.
T0000
Hi Darin,
First, make a backup copy of your post. Then, try replacing your 'mpeck_2$' post block with the following post block code:
mpeck_2$	   #Canned peck drill cycle repeat, mill
  pdrlcommonb
  pcan1, pbld, n$, pxout, pyout, pzout, pcout, prdrlout,
  *peck1$, dwell$, pfr, strcantext, e$
  pcom_movea
Hope that helps,
Colin
Hi Darin,
 pdrlcommonb
 pcom_movea
Hope that helps,
Colin
Perfect thanks that was it.. :fun:
Hi Darin,
 pdrlcommonb
 pcom_movea
Hope that helps,
Colin
I just found out the Q needs to be Q1000 not Q .1... Where do I change this at?
Hi Darin,
You need to change the Format Assignment line for the 'peck1$' variable. First, search the post for 'peck1$'. There is usually a 'fmt' line that looks like this:
fmt  "Q" 2  peck1$	  #First peck increment (positive)
fmt  "W" 2  peck2$	  #Subsequent Peck value (positive)
fmt  "D" 2  peckclr$    #Pecking clearance (from top of hole)
fmt  "Q" 2  shftdrl$    #Fine bore tool shift
fmt  "R" 2  refht_a	 #Reference height
fmt  "R" 2  refht_i	 #Reference height
The number specified after the "Q" string is '2', which is normal 4/3 place decimal output. You need to create a new 'Format Statement' that will format the numeric portion of the variable. For now, change that '2' to an unused number, let's use '40'. so your new line would look like so:
fmt  "Q" 40  peck1$	  #First peck increment (positive)
Now, search up in the post for the 'fs2' lines. after the last one (before the 'Toolchange NC output formats' section), create a new line, starting in the first column, something like so:
# This format statement is used for sequence number output
# Number of places output is determined by value for "Increment Sequence Number" in CD
# Max depth to the right of the decimal point is set in the fs statement below
fs2 21  0^7 0^7	  #Decimal, 7 place, omit decimal if integer value
fs2 22  0^3 0^3	  #Decimal, 3 place, omit decimal if integer value
fs  40  0 4t		 #Omit Decimal, force 4 place trailing (Q parameter)
# Toolchange / NC output Variable Formats
I just added the 'fs 40 0 4t' line in the sample above. That Format Statement (type1) tells MP to omit the decimal point, and force 4 trailing zeros in the output. So your 'Q.1' should now output 'Q1000'.
Hope that helps,
Colin
Hi Darin,
Hope that helps,
Colin
Thanks again Colin you have been very helpful... That worked perfect.. You wouldn't happen to know how to change the R in a canned cycle to post R.0 always? The VTL's use a weird canned cycle where the R can't be bigger or the same as the Z before it.. So they just put a R.0 and it works every time...
