I am currently using a Renishaw LP2DD probe with a stylus that is 100mm in length and has a 10mm ruby ball, the shaft is 4mm. My search speed is 10mm/s. I am using an external kinematic system with a part mounted onto the system, the probe is fixed. I cut my part and I am .017" off in my x direction and .015" in my Y direction. I am currently using no probe deflection offset. Is there a way to calculate this with out using CMM software?
Thank you for you help
-Austen
I have come up with a method to measure the value of my "electronic probe radius" by measuring a block with a known value in one direction (axis X) .
Basically if my block is 75 mm and i measure the front and I get a value of 500 and i measure the back and i get a value of 584.98, i can then subtract the 2 numbers and get 84.98 subtract my block from that(75mm) = 9.98 for a diameter.
My question is should there be a different value for x and y? or should they be the same?
I also am yet to come up with a solution to find the electronic probe length.
Thank you,
Austen
I don't know if this will work but back in the day when I used a tracer. > You have to be over 40 to know what that is> I put an indicator on my stylus and measured the deflection when the stylus touched my template. If it was .008 then I doubled that and added it to the diameter of my stylus. If my stylus was .250 because i was using a .250 rad tool then i made one .266.
no idea what a tracer is... under 30 here.
This is a waterjet application with a robot bringing the part to the probe and the jet nozzle. also what do you mean by an indicator?
This kind of indicator which when mounted and set to your Ruby ball will measure the amount of deflection you get. I bet your deflection is around .008. Mount it with a mag base and zero it out and then see how much it moves when the ruby ball hits your part.
