Haas Rotary Parameters
Hello,
Has anyone messed with Haas A-axis parameter no 104 - "In Position Limit"?
I have a HRT160-P1(purchased in 2012) rotary table used on a VM-3 (2008). The factory-set value for parameter 104 was 4000. I had to change it to 21000 (!!!) to get reasonable feedrate for Mastercam-generated 4axis rotary toolpath. With the original 4000 value it ran very very very slow. When tried to increase feed - it was mega-jerking....
I used inverse feed - the max I was able to pull out of it was F200 (with no jerking) - It took about 30 seconds to make one full 360deg rotation - the diameter of the part is 3.07" (78mm).
I tried G187 at P1 (rough), P2 (medium) and P3 (finish) - no noticable effect.
Toolpath tolerance set to 0.0008", filter tolerance to 0.002"
When I changed the mentioned parameter to 21000 (more than 5 times the original value) - the toolpath movement became about 4-5 Times faster with ZERO jerking. It ran perfectly and the SPEED was satisfactory.
My concern is - will the change of this parameter impact the accuracy of the A-axis positioning / table life or any other thing? Has anyone tested this? Maybe someone from HFO or HAAS factory could help me with this on the forum?
Big Thanks in advance.
