Fanuc VMC 4th Axis Job Help
Hello Every one Im New to emastercam Forum and biginner for 4axis machining parts .
So here is my problem And i really need your help and advises to resolve this issue.
in my Work place we got 4 axis Fanuc VMC and during the last 3 years (since We purchase it) we Didn't use the 4th axis at all .because We always machined parts that can be finished With X Y Z axis Combination .so The 4th axis was unclamped and kept away from the machine .
And last week We received a part like this (please see the attachment ) Fanuc VMC 4th Axis Job Help-capture.png
and i decide this needs the help of the 4th axis and just fix it to the table and the axis seems working properly in manual mode , when we input some value to A 4th axis is rotating well without any alarm .
We usually programming with mastercam ( X5 ) and get the tool path properly .when we simulate the tool path in mastercam it seems ok .Fanuc VMC 4th Axis Job Help-capture1.png
Now the problem .. after post the program and feed to the cnc machine it does not work properly (fanuc 4axis post processor )
and one another thing our machine rotary axis is just go beyond 360.00 is that a problem ?
i noticed when we running the machine ,4th axis is rotating same direction, it just doesnt change cw ccw ) as a example
Now A valuve is A80.000 and then it rotate to A95.00 and again comes a line with A90.00 it doesnt change the direction it rotate the same way .that seems the problem .
please help to solve this issue thanks verymuch
below i will post the part of the cnc code
O0000(PART1)
(DATE=DD-MM-YY - 22-11-13 TIME=HH:MM - 18:40)
(MCX FILE - C:\USERS\ASD\DESKTOP\PART1.MCX-5)
(NC FILE - C:\USERS\ASD\DOCUMENTS\MY MCAMX5\MILL\NC\PART1.NC)
(MATERIAL - ALUMINUM MM - 2024)
( T215 | 6. FLAT ENDMILL | H215 )
N100 G21
N102 G0 G17 G40 G49 G80 G90
N104 T215 M6
N106 G0 G90 G54 X122.94 Y0. A-95.946 S1591 M3
N108 G43 H215 Z75.
N110 Z60.
N112 G1 Z49.166 F79.5
N114 X142.549 A-103.789 F567.5
N116 X150.254 A-106.872
N118 X165.623 A-113.019
N120 X173.725 A-116.26
N122 X173.86 A-116.313 F556.7
N124 X173.957 A-116.349 F533.
N126 X174.053 A-116.384 F514.8
N128 X174.148 A-116.416 F482.1
N130 X174.242 A-116.446 F462.6
N132 X174.335 A-116.474 F443.
N134 X174.427 A-116.501 F423.9
N136 X174.517 A-116.525 F390.2
N138 X174.607 A-116.548 F369.
N140 X174.696 A-116.568 F337.7
N142 X174.784 A-116.587 F324.5
N144 X174.87 A-116.604 F297.7
N146 X174.956 A-116.62 F270.9
N148 X175.041 A-116.633 F234.
N150 X175.125 A-116.645 F218.4
N152 X175.208 A-116.656 F190.3
N154 X175.291 A-116.664 F149.7
N156 X175.372 A-116.671 F134.8
N158 X175.453 A-116.677 F106.6
N160 X175.533 A-116.681 F68.3
N162 X175.612 A-116.683 F37.5
N164 X175.691 A-116.684 F15.1
N166 X175.768 A-116.683
N168 X175.833 A-116.681 F41.4
N170 X176.054 A-116.667 F97.1
N172 X176.246 A-116.644 F180.9
N174 X176.425 A-116.612 F267.6
N176 X176.593 A-116.572 F351.3
N178 X176.751 A-116.524 F441.7
N180 X176.899 A-116.469 F526.2
